Fog lights Boys
Discussion in 'Lighting' started by 5.7Literdreamer, Sep 16, 2016.
  1. Sep 16, 2016 at 7:15 PM
    5.7Literdreamer
    5.7Literdreamer [OP] New Member
    Brooks
    2011 4.6l. Procomp lift with 20" XD series Rockstars. I have the amp step boards wich I love. Bone stcok motor, K&N drop in filter.
    Yeah buddy, I figured out how to use the factory harnes to install some fog lights. Anyone who needs to install them, like if you're truck didn't come with them from the factory, it's easy.! My truck is green, so I got the yellow lenses.
    jdm11, TXMiamiFan and Backslider like this.
  2. Sep 19, 2016 at 11:57 PM
    jdm11
    jdm11 New Member
    Josh
    Is there a write up somewhere that you followed? I'm about to try this
  3. Sep 20, 2016 at 5:07 PM
    5.7Literdreamer
    Brooks
    Kinda, I can help you along . Did your truck come with blanks like mine did?
  4. Sep 20, 2016 at 5:08 PM
    5.7Literdreamer
    Brooks
    There is still one modification that I need to do in order to operate them independent of the low beams. The fog lights go off when you turn your lights on
  5. Sep 22, 2016 at 9:42 AM
    olsin6
    olsin6 New Member Vendor
    Joey
    Mesa, AZ
    2010 White DCSB Tundra
    35" Toyo MT w/ 17" Method Standards Body Mount Chop SDHQ Sliders
    I'd love to see how you wired these with the factory stuff. I did a rock warrior bumper swap and plugged it into the factory harness. Long behold, I found out that I needed the headlight switch that requires the extra turn for the fog lights. I am not paying $512 for it. haha.
    NewImprovedRon likes this.
  6. Sep 22, 2016 at 5:59 PM
    5.7Literdreamer
    Brooks
    You don't need that, you just need to order the kit that I got. The relay you'll need is 20 bux at the Toyota dealership
  7. Sep 22, 2016 at 7:30 PM
    ToyotaTundraMike
    2015 Tundra
    So what do you have to do to make em work if your truck didnt come with fogs?
  8. Sep 22, 2016 at 9:41 PM
    5.7Literdreamer
    Brooks
    Relay, and dash switch
  9. Sep 28, 2016 at 5:57 PM
    Davinson77
    Davinson77 New Member
    Tundra 2016
    Hi I will like to do this ... Can u please explain what we need to get done!! Thanks
