Fog light switch
Discussion in '1st Gen Tundras (2000-2006)' started by Volt92, Nov 12, 2019.
  1. Nov 12, 2019 at 12:16 PM
    Volt92
    Volt92 [OP] New Member
    Tulsa, Oklahoma
    2011 White Tundra RW
    2.5” level kit. 35” KO2
    I’m trying to figure out what the individual pins go to(purpose) on the push button fog light switch for a 2000-2003 tundra. A wiring diagram would be the best but I can’t find it anywhere. I’m not looking for a fog light mod or using existing wiring harness or relay. I am wiring a separate light relay and harness for some led lights but I can’t find the wiring diagram anywhere for the 6 pin fog light switch. What’s gonna be my ground my power etc thank you!08D5EF03-AC17-44F9-A78F-18B1569927CA.jpg0B18F2E3-3B16-478F-8CAB-84FA66291E08.jpg
    because_wumbo-truck likes this.
  2. Nov 12, 2019 at 2:42 PM
    Volt92
    Tulsa, Oklahoma
    image.jpg image.jpgUpdate. I went into Toyota and had talked with the service manager and had one of there technicians pull up a wiring schematic. They said there is only two wires running off of the fog switch. I showed them the harness wiring and they look confused. They atleast told me that red yellow wire is power and black green should be ground. Getting close. I might wire it up to a battery and run some tests. I’ll look for an old light I have to hook it up and get back shortly.
  3. Nov 12, 2019 at 2:45 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    The other wire will be ground and probably a dimmer or light circuit.
    edison likes this.
  4. Nov 12, 2019 at 2:45 PM
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    Power, ground, source, and then illumination to switch. If you know what is power and ground then connect ground and test 2 remaining wires to see which one lights up the switch
  5. Nov 12, 2019 at 8:45 PM
    Volt92
    Tulsa, Oklahoma
    @FrenchToasty @fisherman951 thank you. That’s exactly what I did. Figured it out. Red/yellow was hot, grey with silver was ground the other two(green black, green white) I connected as an accessory wire to the relay. Now I have a push button factory fog light switch operating my fog lights and led light bar I have coming in. I will post some pics tomorrow. Thanks
    NewImprovedRon likes this.
  6. May 22, 2020 at 3:35 PM
    NMR@ider76
    NMR@ider76 New Member
    Jesse
    2006 DC Tundra
    5 inch tuff country 35” coopers on mayhem wheels TRD CAM exhaust K&N JET flash
    Thank you for the post. Just picked up a switch for my 06 tundra from an 03 access cab. Had to do a little trimming, but it worked out. Now, I have fog lights off the light switch arm and fog light switch for my Vision X light bar.
  7. Feb 14, 2022 at 7:15 AM
    Rampage7
    Rampage7 New Member
    James
    2004 Tundra double-cab SR5 4WD V8
    1/3 of the way to swapping out interior bits to make him an SR5+ (Swapped out radio bezel, inner door panels and center cup holder insert… just need to find NM power leather seats… likely never living the full dream of a power sunroof, but alas
    @NMR@ider76
    So when you say trimming, was it because the button was a slight bit bigger on the ‘03 switch, or is that a flip-switch that needed a tad more up/down room?
    I have a 2004 DC that doesn’t have the column mount option but does have a dummy button where you installed your switch (this is where I’m looking to put mine)[/QUOTE]
  8. Feb 14, 2022 at 7:25 AM
    Rampage7
    Rampage7 New Member
    James
    This is what I’m working with; I don’t know for sure, but I think that the blank spot on the 04-06 was intended for those AC 115V things that I’ve seen on some models, but obviously the switch can physically fit
  9. Feb 14, 2022 at 8:35 AM
    Huh. I'm curious to hear more about this. I wasn't aware of a power inverter features for our trucks. Maybe a DC-only feature? I know they also got custom a/v jacks on the back of their center console to boot.
  10. Feb 14, 2022 at 8:59 AM
    Rampage7
    Rampage7 New Member
    James
    This is what I’m referring to
    The blank spot on mine is where this member’s AC 115v is located. Everything else about their little panel there is the exact same as mine
    As far as I’m becoming aware, though it may just be for DC, the fog lights control would be on the headlight/turn signal stalk on the steering column if that option was installed. Again, I could very much be wrong
    However I’m under the impression that the switch and button off of a different sub model and/or year should fit that slot, though the fog light logo would be tilted a little to one side… which might prove to be too annoying for me because according to my friends and family… I’m “overly particular” with ~certain~ things, but not most anything else —__—
    shifty` likes this.
  11. Feb 14, 2022 at 9:03 AM
    Rampage7
    Rampage7 New Member
    James
    I plan to pop that area off on mine later today and see what’s behind it. That will likely tell me what options I do or do not have, but I’m hopeful that I can use that blank for some sort of button/toggle switch
    I don’t know why, but I don’t want to replace the whole turn signal stalk if I have a perfectly good button location that’s not doing anything
  12. Feb 14, 2022 at 9:07 AM
    Rampage7
    Rampage7 New Member
    James
    @Volt92
    I know it’s been a few years, but did you ever get that switch & button put in? If you still have the vehicle could you post a pic of the finished work?
  13. Feb 14, 2022 at 10:01 AM
    Rampage7
    Rampage7 New Member
    James
    Alright, so yeah… there is nothing behind the dummy. No leads, no connections
    but that’s fine since @Volt92 and the others laid out the groundwork for running the wires.
    I may just admit defeat and get a salvage stalk that has the fog control… but we’ll see
    Either way this has been a very VERY useful thread
    shifty` likes this.
  14. May 30, 2022 at 6:20 PM
    Vallejo206
    Vallejo206 New Member
    Rob
    Everett, WA
    02 SR5 V6 AWD
    Finally got my switch from a Toyota salvage yard.
    I was excited and hooked up the OE leads in the number and plug my new switch in.
    Put the fog light relay in the fuse box under the hood..and the fogs didn’t work?
    the switch was actually operating my LED headlights switching them from high beam to low beam.. anyone that has any input will be appreciated.
    EBB07F1D-408F-46E6-B66E-672BA7E4336A.jpg D1D2A42F-E207-441D-9EA0-30E76173E049.jpg
  15. May 30, 2022 at 8:44 PM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Led headlights will make things get funky with your fog lights.
    You need one of these from @daveeasa to start with.
    Link
    The fog lights are controlled partially by the headlights and when there is a low load on the system (from LED headlights) they don't work right.
    Vallejo206[QUOTED] likes this.
  16. May 30, 2022 at 8:47 PM
    Vallejo206
    Rob
    Everett, WA
    02 SR5 V6 AWD
    thank you. I’ll look into that product you linked. I still have my regular head light bulbs. I’ll plug those in and post my results
  17. May 30, 2022 at 8:47 PM
    NickB_01TRD
    Nick
    KY
    That should work as well for testing.
  18. May 31, 2022 at 5:23 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    I'd also check and see if there is a 20A Fog Light fuse underhood for the Fog Light relay.
    Vallejo206 likes this.
  19. May 31, 2022 at 2:12 PM
    Vallejo206
    Rob
    Everett, WA
    02 SR5 V6 AWD
    Yeah I checked that fuse and it looked good, not Fouled up or anything.
  20. Jun 1, 2022 at 11:26 AM
    Vallejo206
    Rob
    Everett, WA
    02 SR5 V6 AWD
    Plugged in my halogen lights. And bam! 3D2AB0F5-C767-48B8-A417-367188E8545B.jpg
    thanks again for the quick info on my LEDs messing with my fog lights
    I also bought that harness you linked
    Just cause I can’t pass up on accessories made for my truck
    NickB_01TRD[QUOTED] likes this.
  21. Jan 5, 2025 at 3:36 PM
    kulldox
    kulldox New Member
    Bellevue WA
    2001 Black Tundra AC Limited 4WD TRD
    This is a weird one.
    So, my truck already has fog ligts, I'm not messing/touching that one.
    I have already installed some hood flood lights which work fine, but the round switch which comes with them doesn't really fit the blank spot. So I thoght I'll just pick up another fog light switch from the junk yard and put that in the blank space, and use that instead. Well, for some reason every time I try it, it blows my flood lights 15A fuse. I'm commenting here since this thread helped me to figure out the switch pinout.
    So:
    - pin 6 - Yellow/Red is the positive -> going to the red wire on the flood lights harnes
    - pin 3 - Green/Black (or in my case Green/Red in the same 3rd pin) is the negative -> going to the black wire on the flood lights harnes
    the rest of them are just illumination, so no connection for now.
    Tested with the multimeter and indeed only pin 6 and pin 3 are connected/disconnected.
    I don't get it why with the included switch the flood lights work fine but with the OEM FogLigts switch it doesn't. Maybe the OEM switch has some higher internal resistance or something? Weird. Anybody knows? :)
    ---- Nevermind- Update ----
    Who would've thought that actually the white wire is the negative? :)
    Now the OEM switch works perfectly fine :)
  22. Jan 6, 2025 at 7:26 AM
    I literally just helped another member with this exact pinout tracing via PM. @Bed Tundy maybe this helps you also?
    Bed Tundy likes this.
  23. Jan 18, 2025 at 11:22 PM
    kulldox
    kulldox New Member
    Bellevue WA
    It is weird how the buttons have the contacts for the second bulb which indicates if the button is pressed or not, but the wires are not connected to them. They even have the empty bulb plastic holder/socket :)
  24. Mar 24, 2025 at 1:47 PM
    kulldox
    kulldox New Member
    Bellevue WA
    Anybody has any idea how the bulb for on/off for these buttons is supposed to work? Which Tundra model would have it hooked up?
  25. Mar 25, 2025 at 6:22 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    Mine (00-02 in dash switch) have no on/off bulb. The only bulb is to illuminate the switch when the lights are on. If the switch is flush with the panel, it's in the "on" position. When it's protruded, it's in the "off" possition.
  26. Mar 26, 2025 at 9:38 AM
    kulldox
    kulldox New Member
    Bellevue WA
    Yes, the bulb is not there, but the socket and pin is there, it is just not connected to anything. I tested it with a multimeter, it does connect the pin when it is pressed. I was just wondering in which car models this is actually used and how does it look like :)
