Fog light mod similar to Tacoma relay
Discussion in 'Lighting' started by bj46-taco-tundra, Aug 21, 2016.
  1. Aug 21, 2016 at 1:52 PM
    bj46-taco-tundra
    bj46-taco-tundra [OP] New Member
    Mark
    Bj46 taco and now a tundra
    First of all I have found several write ups on the forum about the anytime fog light mod, but none of them seem to be as simple as the one I did to my 09 Tacoma.
    On my Tacoma all I did was bend up a terminal on the fog light relay and run an add a fuse wire to an ignition switched power source. 30 sec and I was done.
    I'm just a big baby who doesn't want to alter or cut anything.
    Come on tundra owners, who will make this work
    650h1 and Viper3G like this.
  2. Aug 21, 2016 at 2:15 PM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    Clever. Seems like that should work. The tundra relay gets its ground from the BCU (fog relay pin #2), when the foglight switch is turned on. It gets its coil power from the tail-light relay (fog relay pin #1). Seems like running pin 1 to an ignition source instead, would be just the ticket.
  3. Aug 26, 2016 at 7:13 AM
    15TRDPro
    15TRDPro New Member
    Jeremy
    NorCal
    2015 Inferno Tundra TRD Pro
    TRD Supercharger
    I did the same thing when I had my 06 Tacoma. it would be nice if this mod would work for the tundra.
    1st2014TSS and 650h1 like this.
  4. Aug 26, 2016 at 7:16 AM
    650h1
    650h1 New Member
    2013 Rock Warrior C/M
    Im getting wet thinking about this working for our trucks... did it on my tacoma and it took like not even 5 mins..
  5. Aug 26, 2016 at 7:38 AM
    TTU19
    TTU19 Wreck 'Em
    Wes
    Tx
    2021 TRD Sport
    If I could turn my fog lights on with the headlights off, so same as the DRLs, I'd do that in a heartbeat. It has their own on and off, why not make it work that way without turning the full headlights on.
    650h1 likes this.
  6. Aug 26, 2016 at 10:05 AM
    650h1
    650h1 New Member
    so, what we could do if this is a possiblity, is wire in a jumper from the power prong of the fog light relay to the DRL fuse. That way, whenever the DRLs come on, if you choose, you could have the fog lights on as well. I think the DRLs stay on as long as the truck is on, right? I cant remember if they stay on with headlights or not, but I think they do.
  7. Aug 26, 2016 at 10:46 AM
    TTU19
    TTU19 Wreck 'Em
    Wes
    Tx
    2021 TRD Sport
    I think so, but they are also the blinker. Would that interfere with the fog light? Humm. Maybe not since that is not its function, it's just bypassing the power on.
  8. Aug 26, 2016 at 11:07 AM
    650h1
    650h1 New Member
    So the directional wires are separate from the DRL wires if you look behind your headlight. But either way, I'm talking about tapping the jumper wire from the fog relay into a fuse. So I'm thinking the DRL fuse should be good...
  9. Aug 26, 2016 at 12:05 PM
    TTU19
    TTU19 Wreck 'Em
    Wes
    Tx
    2021 TRD Sport
    You'd think more people would have done this already to chime in. Has to be something simple. All you need to do is supply constant power to it and use the on/off on the steering column. Or so you'd think.
    650h1 likes this.
  10. Aug 26, 2016 at 12:06 PM
    650h1
    650h1 New Member
    Yeah, I'd want ignition power though so I don't forget about them and kill my battery all the time... If I knew what prong on the relay I need to tap I'd do it right now and report back. Let me do some digging...
  11. Aug 26, 2016 at 12:09 PM
    TTU19
    TTU19 Wreck 'Em
    Wes
    Tx
    2021 TRD Sport
    Yeah, that's what I meant. Power when the truck is on. Ok, let us know.
    650h1 likes this.
  12. Aug 26, 2016 at 12:09 PM
    650h1
    650h1 New Member
    I gotta figure out which pole on the relay we need to bend... Hmm
  13. Aug 28, 2016 at 9:39 PM
    bj46-taco-tundra
    Mark
    Anyone played with this over the weekend.
  14. Aug 28, 2016 at 11:06 PM
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    Interested I did this on my 09 Tacoma as well
  15. Sep 22, 2016 at 7:07 AM
    bj46-taco-tundra
    Mark
    Has anyone made any headway ?
  16. Sep 22, 2016 at 7:14 AM
    650h1
    650h1 New Member
    I looked at the fuse box the other day, and it is the same relay as the Tacoma has. The issue I am having is what fuse to tap into... I want the fogs to come on with ignition, just like DRL, but I'm hesitating to tap the DRL circuit because idk how it is effected when the headlights come on... idk what to do. I don't want them to come on with parking lights because as soon as I turn my parking lights on my NAV goes into night mode and you can't see it during the day.
  17. Sep 22, 2016 at 7:39 AM
    TRD FreddieZ
    TRD FreddieZ New Member
    2010 Sliver SR5 TRD Tundra
    Did mine fog light mod on Sunday. 2010 Tundra, splice pink wire and gray wire and all good to go. took like 5mins.
  18. Sep 27, 2016 at 6:24 PM
    4RNR
    4RNR トヨタ
    America
    16 Tundra SR5 CM
    Switched from 16 Taco
    Subd
  19. Sep 28, 2016 at 8:26 AM
    xtyfighterx
    Ty
    North Idaho
    Then tap the ignition fuse
  20. Sep 28, 2016 at 8:27 AM
    650h1
    650h1 New Member
    Just sucks that you get rid of the functionality of your fog lights though wouldn't you? I mean they're on when the key is on, and I'm not sure if the switch on the stalk would still work
  21. Oct 1, 2016 at 9:14 AM
    TTU19
    TTU19 Wreck 'Em
    Wes
    Tx
    2021 TRD Sport
    Just passed a guy going the opposite direction on the highway who had his DRLs and fogs on only. So has to be a way. One of those times you wish you could flag a guy down to ask, ha.
    650h1 likes this.
  22. Oct 1, 2016 at 12:59 PM
    650h1
    650h1 New Member
    Well with the way the mod everyone does you can do that too. Since our DRL's are our parking lights. The issue for people like me is that I don't want to drive around with my NAV in night mode all the time because it goes into night mode when you turn on the Parking lights...
  23. Dec 11, 2016 at 1:50 PM
    Nick1716
    Nick1716 New Member
    Anyone try this yet?
  24. Dec 11, 2016 at 2:40 PM
    1BadTundra
    1BadTundra New Member
    Clinton
    2010 TRD Rock Warrior Crewmax
    Too Much to List
    So by tapping this relay, is your switch on the stalk still functional... Or, is it useless and the fogs are always on?
  25. Dec 11, 2016 at 5:33 PM
    650h1
    650h1 New Member
    If it works like the Tacoma, switch still works. The mod just makes you able to turn on the fogs with parking lights instead of needing headlights to be on
  26. Dec 12, 2016 at 7:57 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Flyinryank likes this.
  27. Dec 12, 2016 at 7:59 AM
    650h1
    650h1 New Member
    The Tacoma mod is so much easier and you get the same result... just need someone to Guinea pig it for us...
  28. Dec 12, 2016 at 8:04 AM
    jtav2002
    jtav2002 Retired Adult Film Sound Man
    Josh
    Reading, PA
    2019 GMC Sierra 1500 AT4 6.2
    I think the above posted is how I did it on my 2013. I forget. I did it 2 years ago. Was a little bit of a pain IIRC just because of the small length of wires you work with. I wish it was as simple as it was on my Tacoma but it was pretty easy.
  29. Dec 12, 2016 at 8:06 AM
    jtav2002
    Josh
    Reading, PA
    I certainly could be wrong, but with the number of people who come from Tacos to Tundras if the same process would work I would think by now someone would have done it already and that would be the widely used method for doing so. Who knows.
    NewImprovedRon likes this.
  30. Dec 12, 2016 at 8:06 AM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Yes, the switch on the stalk still works too. While I was at it, I unceremoniously chopped the amber drl. I cut the drl wire at the back of the bulb (purple I think). The turn signals work fine but no more amber drl. I've got the led drl strip in my headlights and though the amber was redundant.
