Fog light issues got an easy fix for converting led head and fog lights from ebay
Discussion in '1st Gen Tundras (2000-2006)' started by Hidock86, Dec 14, 2019.
  1. Dec 14, 2019 at 12:43 PM
    Hidock86
    Hidock86 [OP] New Member
    Ok so I saw a guy had a problem with his fog lights not working after installing new led head lights well I had the same problem today I honestly do not know what causes this issue but it’s not a fuse or relay or ground nor is it a switch easy they just won’t work I believe it’s due to the headlight bulbs and being high low beam or the current any way run a positive wire to your fog lights on driver side splice another to the passenger side run that wire from your interior fuse box on the 15 amp fuse that says fog lights and you should be good if this is hard to understand I’ll due my best to answer your question and or any other questions you have this is my 4th Toyota Tundra and I know quite a bit about the 2005s
