Fog Light Install
Discussion in '1st Gen Tundras (2000-2006)' started by Titan4299, May 9, 2020.
  1. May 9, 2020 at 12:21 PM
    Titan4299
    Titan4299 [OP] New Member
    2003 White Tundra SR5 2WD 4.7L V8
    Polk Audio Component Front Speakers Polk Audio 6 1/2s rear speakers Pioneer Deck with Custom Install Kit Truck Box Chrome Side Step Rails
    I have a 03 SR5, and am installing a fog light kit, I went to put in the after market switch and need to know which plug was meant for the fog lights. Anyone have any ideas? I will have to splice in the new one.
  2. May 9, 2020 at 4:16 PM
    Titan4299
    For some reason I keep reading there is a fog switch on the Turning Signal Switch. Can anyone confirm this for me???
  3. May 9, 2020 at 4:21 PM
    Welcome from NY.
    Hopefully a 1st gen guy/gal will chime in with the answer.
  4. May 9, 2020 at 4:48 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  5. May 9, 2020 at 4:50 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    What you have probably been reading is that when you hit your high beams, the foglights turn off. With OEM function of course. You might run yours to be on all the time with lights.
    NewImprovedRon likes this.
  6. May 9, 2020 at 5:02 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    I think what he’s referring to is; some trucks have a push button on dash, some have a lil twistie on the turn signal stalk
  7. May 9, 2020 at 5:04 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    OH! I did not know that!
  8. May 9, 2020 at 5:10 PM
    Titan4299
    Im just trying to see about if the factory switch was an actual push button or the twisty switch on the turn signal stick. I've seen others use the push button but the two videos on youtube show a totally different wire plug then the ones I have, so im confused in this and what to do.
  9. May 9, 2020 at 5:18 PM
    Professional Hand Model
    Hand Protectors
    The 2002 has a push button to the left of steering column on dash just below corner vent.
  10. May 9, 2020 at 11:16 PM
    RR60
    RR60 New Member
    2003 SR5 Tundra long bed
    I added them to my 2003 SR5 Tundra. It was easy plug and play. But I had to replace my turn signal switch. That is where the wires where.
    So oem is on turn signal. If I remember right I just got a used whole turn signal switch from https://www.car-part.com/ had it shipped to me.
    Below the corner vent is my button for side view mirror defrosters. Seems before 2003 that space was used for the fogs.
    You would have to use a mulitmeter to see if they also still had a plug there for foglights. But dont see them putting it at 2 places.
    TheFixer likes this.
  11. May 9, 2020 at 11:38 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    i believe starting in 03 they moved the fogs to the turn signal stalk. You will need to get a turn stalk with fog lights to use the factory fog light system
    the plugs you have there will be for heated mirrors, TVIP security Glass breakage sensor and the other for a power rear sliding window
    now knowing what wires you have you can now upgrade to heated mirrors and possibly a power sliding rear window! the TVIP thing is hard to come by.. ive been hunting for a while.
  12. May 10, 2020 at 3:54 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    According to the 2003 FSM, it's on the turn signal stalk !
  13. May 10, 2020 at 10:42 AM
    Titan4299
    Thank you BubbaW! Guess I'll have to order the new signal stalk to complete this install! Thank you as well to everyone else for the help!!!
    Tundra2 likes this.
  14. May 10, 2020 at 11:03 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    I went the cheap way on my 04. The valance already had the lights installed but there was no other wiring. My truck was totalled and rebuilt so I'm guessing they found a deal that included the lights.
    I used a 9006 headlight relay harness and tied the relay trigger to the drivers headlight fuse.
    You could do the same but use the switch you bought as the relay trigger.
  15. May 10, 2020 at 11:23 AM
    empty_lord
    05 rollover special
    I bought a used turn stalk for like 20 bucks. Works great.
  16. May 10, 2020 at 8:30 PM
    Titan4299
    Ordered a new one off Amazon, on its way!! Hopefully this will complete this upgrade for me! Which all in all only spent $210 for the upgrade! Still cheaper then buying directly from dealer and then having them install. Will add photos when done!
    Tundra2 and empty_lord like this.
  17. May 19, 2020 at 10:32 PM
    Titan4299
  18. May 19, 2020 at 10:36 PM
    Titan4299
    The Lights took maybe 15 minutes to install, the plugs pop right out and the factory has the cables already there n ready to hook up! Tne relay is simple less then a min to pop in! The turn signal took 20 minutes only because I needed to watch a video to find the hidden screws behind the steering wheel to get the cover off, after that it was easy enough, the savings was worth it for a DYI project!!!
  19. Jan 22, 2021 at 7:13 PM
    AV8R4AA
    AV8R4AA New Member
    Greg
    Justin Texas
    2005 Tundra XSP
    How do I get the steering column covers off?
  20. Jan 22, 2021 at 7:16 PM
    FrenchToasty
    Mo
    Bone stock
    Turn the wheel and you will find 2+ screws, have to go right, then left to see them
  21. Jan 22, 2021 at 7:25 PM
    empty_lord
    05 rollover special
    theres a 3rd screw at the bottom too.
  22. Jan 22, 2021 at 7:25 PM
    AV8R4AA
    AV8R4AA New Member
    Greg
    Justin Texas
    2005 Tundra XSP
    Does the steering wheel need to be removed?
  23. Jan 22, 2021 at 7:26 PM
    FrenchToasty
    Mo
    Bone stock
    No, just turn it with the truck on or wheels in the air, and then you can see them
  24. Jan 22, 2021 at 7:32 PM
    AV8R4AA
    AV8R4AA New Member
    Greg
    Justin Texas
    2005 Tundra XSP
    I see the torx screws, take out?
  25. Jun 9, 2021 at 5:34 PM
    saxwatch
    saxwatch New Member
    2005 sr5 double cab
    i have an 05 SR5 double cab. I'm thinking about adding fogs. Where did you get the lights?
  26. Jun 9, 2021 at 6:06 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    @bmf4069
    I ordered my original lights from Amazon the first time around. The second set of lights were already on @FirstGenVol's old bumper when I got it.
    bmf4069 likes this.
  27. Jun 9, 2021 at 7:05 PM
    AV8R4AA
    AV8R4AA New Member
    Greg
    Justin Texas
    2005 Tundra XSP
  28. Jun 10, 2021 at 1:23 PM
    saxwatch
    saxwatch New Member
    2005 sr5 double cab
  29. Jun 10, 2021 at 7:32 PM
    AV8R4AA
    AV8R4AA New Member
    Greg
    Justin Texas
    2005 Tundra XSP
    Those look great. Should be perfect for you
  30. Jun 13, 2021 at 7:18 PM
    MNtundra
    MNtundra New Member
    Tony
    Minnesnowta
    01' Tundra AC 4x4, 04' CRV 4WD
    Bilstein 5100's, 4runner Wheels 31" BFG, Rear Seat Delete
    For Those that activate fogs via panel 00-02', I pulled a few switches from some at the parts yard and you can utilize OEM switches to active 2 separate sets of lights (Fogs + Light Bar in bumper) where the blank insert panel fillers are now. That's what I plan to do!
