Fog light housing loose due to no brackets
Discussion in 'Lighting' started by grichg, Aug 25, 2021.
  1. Aug 25, 2021 at 8:27 PM
    grichg
    grichg [OP] New Member
    rich
    Hello,
    I put the Diode Dynamics on my truck and the lights are ok for me.
    The issue is that they go into the Stock Housing and the Housing is all Loosey Goosey due to no brackets etc.
    What options you guys have installed etc.
    thanks
  2. Aug 25, 2021 at 9:21 PM
    Roborob70
    Roborob70 New Member
    Robert
    18 Toyota Tundra TRD
    fabricate your own.
  3. Aug 25, 2021 at 11:48 PM
    OnespeedTRD
    OnespeedTRD New Member
    Don
    San Diego
    2020 Tundra Limited TRD Off-Road
    275/70r18 Cooper AT3 XLT on SCS Ray 10s, Eibach Coilovers, DD 12" Exhaust, AJT Blackout Kit, Truxedo Pro X15, paint match/chrome delete.
    I'm installing some DD SS3 Pros this weekend, so I'll have to figure out how to get them mounted up so they don't move.
    Apparently its a common/known issue... most folks run a ziptie through the housing and bracket to some other bracket underneath there and it firms it up. My passenger side factory fog shakes visibly so I know its an issue already.
  4. Aug 26, 2021 at 3:52 AM
    AGuyFromNC
    AGuyFromNC New Member
    Nick
    2020 Tundra CM TRD Offroad
    My oem fog housings shook when the truck was brand new. A few heavy duty zip ties around the bumper brackets and they do t move anymore. Should we have to do this to fix the fogs? No. Is it easier than going to the dealer and having them install the exact same plastic housing that will shake again? Yes.
    Buildn and NewImprovedRon like this.
  5. Aug 26, 2021 at 4:28 AM
    trucknut
    trucknut New Member
    2021 Cav blue SR5 TRD Off Road
    Agreed about the zip ties. The housing is known to be looser on the plastic caps than on the chrome ones.
  6. Aug 26, 2021 at 8:53 AM
    Buildn
    Buildn 2022 Tundra Limited CM 6.5 Bed TRD Off Road
    Medina, Ohio
    TRD Air Filters, Front door windows tinted to match the rears. Wheel locks, Talons Garage cat shield, Tyger Automotive soft tonneau cover, WeatherTech floor mats with Tuff Skinz Custom Emblem kit, Toyota OEM Emblem Black Out kit. AVS vent covers on all four doors, Red Tundra letters on front bumper & TRD highlighted in Red on front grille. Tailgate Tundra Letters in Black.
    I put a couple of dabs of clear silicone to the metal tabs that hold the housing and than ran a small bead around the housing. Now mine are tight and don’t move at all.
    grichg[OP] likes this.
  7. Aug 26, 2021 at 9:31 AM
    grichg
    rich
    Thanks for the response and I have zips on the lights with mounting bracket. My Housing that fits into the Bumper is moving all over the place.
    Maybe some Silicone will help
    Nic146 likes this.
  8. Sep 16, 2021 at 8:38 AM
    TruPatriot
    TruPatriot New Member
    Lee
    Northeast Texas
    2020 TRD Pro MGM Mall Crawler & Trail Riding Queen
    I just installed DD Pro's and ran two zipties from the bracket to the truck. The fog light bezel moves no more.
  9. Sep 16, 2021 at 8:42 AM
    Nic146
    Nic146 New Member
    Probably stuck somewhere
    2016 Barcelona Red TRD CM
    Has anyone done this and have a thread/post to show? I’m curious to see.
  10. Sep 16, 2021 at 8:45 AM
    Oey12
    Oey12 New Member
    Joey
    New York
    2020 SR5 TRD OFFROAD
    Heavy duty zip ties…. Zero shake or wiggles.
  11. Sep 16, 2021 at 5:10 PM
    grichg
    rich
    Just did the Zip Tie method and worked like a charm. No mess....
    Oey12 likes this.
  12. Sep 16, 2021 at 5:15 PM
    TruPatriot
    Lee
    Northeast Texas
    Sweet!
    grichg[QUOTED][OP] likes this.
