Fog / Driving light wiring diagram?
Discussion in '2nd Gen Tundras (2007-2013)' started by Dalandshark, Dec 3, 2020.
  1. Dec 3, 2020 at 8:48 PM
    Dalandshark
    Dalandshark [OP] Infected with 5G
    Northwest
    2007 Tundra SR5 5.7 Longbed
    Eibach Level LIft
    DC SR5 w/o factory fogs. Anyone have the wiring diagram for the fog light circuit? Searched and couldn't find it. Lots of threads but not really what I'm looking for.... I want to intercept the wires that go to the connector for the not installed switch on the turn signal stalk. I plan to use the factory wiring but use the switch that came with my fog light kit, which fits in a blank. I realize this will mean that they won't work on high-beam which is fine, I bought yellow lens fog lights and you shouldn't have high beams on at same time anyway - for fog/snow. Thanks ahead.
  2. Dec 4, 2020 at 11:29 AM
    Dalandshark
    Northwest
    Eibach Level LIft
    Took a bit to find the diagrams (2007-2010)... download... convert...search through and find them. Looks like I need to find the Pink wire, grounding that through the switch should activate fog relay once installed. I can grab back light power from another switch or something.
  3. Dec 23, 2020 at 4:26 PM
    Eroc1313
    Eroc1313 New Member
    Erk
    2010 Tundra
    Where is a36 plug on the diagram? I get power to one fog light plug.
