FNG Hello all!
Discussion in 'New Member Introductions' started by lackeycc, Jul 4, 2018.
  1. Jul 4, 2018 at 8:01 AM
    lackeycc
    lackeycc [OP] New Member
    Cody
    Louisiana
    2015 TUNDRA CM SR5
    S&B CAI Raptor lights OME 612 Cooper STT PRO 295/60R20 5% Tint Husky Liners Rigid D2 Fogs on OEM Switch
    I’ve been looking for the most in depth topic across any forum... the dreaded “what can I fit if...” I know it’s like beating a dead horse just haven’t found anyone trying to do the exact same thing I was curious about. So here it goes 15 CM 4x4 TSS 20” 50offset with OME 612 in the front alone with Cooper STT pros 295/60r20. Those are my wheels just in case I have the dems wrong on them.
    If anyone has done this please chime in. I tried to read through everything over the past couple of days and nothing. Thanks
  2. Jul 4, 2018 at 8:28 AM
    atrinh15
    atrinh15 New Member
    495-93 area
    2018 PLATNIUM White CM
    Ready lift 3/2 Fuel Mavericks 22x9.5 Nitti Terra Grappler G2 - 285/55/22 K/N air filter TRD sway bar SS Fisher plow Mesh grill painted to match Rear bumper painted white
    Welcome from Mass! And what is your exact question?
    Coolhardy likes this.
  3. Jul 4, 2018 at 8:40 AM
    Welcome from CO.
  4. Jul 4, 2018 at 8:40 AM
    Which came first? The chicken or the egg?
    4x4_Angel and Black Wolf like this.
  5. Jul 4, 2018 at 8:44 AM
    MatthewPTguy
    MatthewPTguy Not a new member
    Eugene, Oregon
    2017 Tundra 5.7 DC TRD MGM
    Borla dual cat back exhaust system, K&N replacement air filter, Headlight Revolution 40" Stealth LED light bar, Headlight Revolution LED fog light replacement bulbs, Line X bed liner, de-badge
    Welcome from Oregon!
  6. Jul 4, 2018 at 9:01 AM
    Welcome from Texas
  7. Jul 4, 2018 at 9:03 AM
    lackeycc
    Cody
    Louisiana
    2015 TUNDRA CM SR5
    I see where that could be confusing. So first things first I’m doing an OME 612 in the front alone, secondly I have the factory TSS wheels and was curious if I could run Cooper STT Pros @ 295/60r20 without spacers. The spec sheet I’ve looked at says they are 34.29 with a width of 11.5. Thanks in advance.
    Mountun Goat likes this.
  8. Jul 4, 2018 at 9:33 AM
    Hondoman
    Hondoman New Member
    Jeff
    Dfw Texas
    2015 SR5 CM 4x4
    I think you will be fine. I have the same truck and wheels, but 295 55 20 toyo oc rts and bilstein 5100s on the top setting. I had a slight rub on the skid plate at full lock on the drivers side. Bent it up a little and no more rubbing.
  9. Jul 4, 2018 at 9:36 AM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Welcome from Colorado
  10. Jul 4, 2018 at 9:38 AM
    ardnutoz
    ardnutoz
    OZ
    SE-PA
    2018 Black TRD OR CM Limited
  11. Jul 4, 2018 at 9:38 AM
    TXMiamiFan
    Jose
  12. Jul 4, 2018 at 9:41 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Should be OK with that setup.
  13. Jul 4, 2018 at 9:42 AM
    lackeycc
    Cody
    Louisiana
    2015 TUNDRA CM SR5
    Those are showing a 32.8 dia. and 12.2w Vs a 34.3 dia. 11.5w that’s my only concern. I don’t mind/expect to remove the mud flaps just don’t want them to get here and not even be close.
  14. Jul 4, 2018 at 9:44 AM
    "OME 612 in the front alone"?........You are talking about the 2.5 OME shock with 612 assembly right? If so you will most likely have to move front fender liner forward a bit. Semper Fi!
    By the way I got almost 3" with my OME setup.
    lackeycc[QUOTED][OP] likes this.
  15. Jul 4, 2018 at 9:44 AM
    Larmand
    Larmand SSEM #6
    Lucas
    Fort Worth, TX
    Welcome to the party!!
  16. Jul 4, 2018 at 9:47 AM
    Grumpy Uncle
    Pat
    CO
    Welcome from CO.
  17. Jul 4, 2018 at 9:48 AM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Width is more of an issue than height in this case. You'll hit the skid like mentioned but it's easy to bend out of the way.
  18. Jul 4, 2018 at 10:20 AM
    Steve6
    Steve6 New Member
    Tucson
    Welcome from Arizona.
  19. Jul 4, 2018 at 10:21 AM
    lackeycc
    Cody
    Louisiana
    2015 TUNDRA CM SR5
    Yut! I have 285/55r20 BFGs right now and they are 2/10ths wider than the 295 coopers so I figured I’d be fine on the width since they are somehow narrower than stock, according to Cooper and Goodrich’s specs.
  20. Jul 4, 2018 at 10:22 AM
    lackeycc
    Cody
    Louisiana
    2015 TUNDRA CM SR5
    Just wanted to have the experts critique before I pull the trigger and feel like a moron.
    Black Wolf likes this.
  21. Jul 4, 2018 at 10:24 AM
    You will really like those Coopers!!
  22. Jul 4, 2018 at 10:29 AM
    lackeycc
    Cody
    Louisiana
    2015 TUNDRA CM SR5
    I had them on my Tahoe and loved them. I only put about 2k on them. Then got my whits about me and bought a truck.
  23. Jul 4, 2018 at 10:37 AM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Welcome from Nevada
  24. Jul 4, 2018 at 12:40 PM
    nk1794
    nk1794 Always torque to spec
    San Jose, CA
    Welcome from CA
  25. Jul 4, 2018 at 12:42 PM
    4x4_Angel
    Bree
    Funky Town, Texas
    2014 SR5 CM Silver Sky
    Welcome from Texas
  26. Jul 4, 2018 at 12:46 PM
    Landman500
    Landman500 New Member
    joseph
    2016 Tundra double cab limited try off road
    Hello CT
  27. Jul 4, 2018 at 3:48 PM
    Welcome from Ohio!
  28. Jul 4, 2018 at 3:49 PM
    ardnutoz
    ardnutoz
    OZ
    SE-PA
  29. Jul 4, 2018 at 3:51 PM
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    WELCOME
  30. Jul 4, 2018 at 4:27 PM
    lackeycc
    Cody
    Louisiana
    2015 TUNDRA CM SR5
    Pulled the trigger hopefully I won’t regret it. Ordered the Cooper STT PRO 295/60r20 and the OME 612 lift with a diff drop so I have my fingers crossed. Thanks for the help.
