Fluid Torque Specs
Discussion in '2.5 Gen Tundras (2014-2021)' started by RenegadeX, Aug 21, 2024.
  1. Aug 21, 2024 at 9:12 AM
    RenegadeX
    RenegadeX [OP] New Member
    2019 Tundra TRD Sport
    Good afternoon,
    I've got the fluid specs for these, but looking for torque specs for drain and fill plugs on a 2019 Tundra TRD Sport 4x4 Crew. I have the washers for each from the dealer (with exception of the the Transfer Case which appears not to require any)
    Engine Oil Pan drain plug.
    Transmission drain and fill plugs
    Front Differential drain and fill plugs
    Transfer case drain and fill plugs
    Rear Differential drain and fill plugs
    Thanks for considering!
  2. Aug 21, 2024 at 11:42 AM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    Using a torque wrench on drain plugs can lead to over tightening. Unless you're someone who has a tendency to over do it i never suggest torque wrenches on those. I serviced all those mentioned and it's pretty easy to tell when it's tight enough and you can just check for leaks after.
  3. Aug 21, 2024 at 12:57 PM
    JrJrOffroad
    JrJrOffroad Somewhere in the west
    Anthony
    Monument, CO // Cave Creek, AZ
    +1
    Dont put yourself in a tight spot literally when you cant access them in the future.
  4. Aug 21, 2024 at 1:28 PM
    Retired...finally
    Why oh why don't manufacturers give wet torque numbers for drain plugs?
    Maybe they do?:monocle:
  5. Aug 21, 2024 at 7:48 PM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    My previous service, I didn’t even bother dealing with torque specs of these bolts and nothing has leaked.
    Tighten it enough to where you need to use a bit of muscle to open it next time, but not to the point of where you’ll need a 3ft cheater bar to open it up again.
    reywcms likes this.
  6. Aug 22, 2024 at 5:50 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    0.5 ugga dugga
  7. Aug 22, 2024 at 5:53 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Wet torque must be 30% less, so about 1/3 ugga dugga.
    Jaypown[QUOTED] likes this.
