Fluid(s) change
Discussion in '1st Gen Tundras (2000-2006)' started by AMan805, Sep 26, 2023.
  1. Sep 26, 2023 at 10:20 PM
    AMan805
    AMan805 [OP] New Member
    Austin
    06 TUNDRA 4X4 DOUBLE CAB
    Thinking of getting all fluids changed(drain/fill) and getting it done professionally. I just changed my oil last weekend. What fluids does that include(components)? I know of brake,power steering, trans, coolant(what else?), Also when I take it in, any advice? Should i tell them to use certain fluids for each component? Or perhaps even buy the liquids and just ask for them to drain/fill for me?
    Austin
  2. Sep 27, 2023 at 4:47 AM
    JasonC.
    JasonC. ¯\_(ツ)_/¯
    TX
    2001 4x4 4.7L “Best Cab”/AC Limited 50k mi
    In addition to what you mention:
    • Front and rear differential (might not be the same fluid if rear is limited slip)
    • Transfer case (you’re a 4WD I see)
    Can’t think of anything else. Fluid types and levels are in your owner’s manual (see the sticky post by shifty if you don’t have yours).
  3. Sep 27, 2023 at 5:09 AM
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    Coolant - Toyota pink (Super Long Life)
    Transmission - Toyota WS or equivalent
    Power steering - Dexron III
    Front diff & transfer case - 75W-90 GL-5 gear oil
    Rear diff - depends on which one your truck has - 75W-90 (limited slip) or 75W-140 (open)
    How many miles are on your truck? Do you know when the timing belt was last replaced?
  4. Sep 27, 2023 at 5:30 AM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    Maybe order some of the hex head diff plugs from lexus. Supposedly they dont round out as easy as the allen headed plugs.
    Everything except the trans should be easy enough if you spread it out over a couple weekends. I say trans because the later trucks dont have a dipstick & i dont know how the fill works.
    Mike59 likes this.
  5. Sep 27, 2023 at 5:36 AM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    I'd ask before you bring it in what they use and if you can change it (if they don't use OEM fluids).
  6. Sep 27, 2023 at 5:42 AM
    Don’t forget the blinker fluid. Never hurts to have fresh. BMWs specifically have a leak and are always low.
    Dad01, Reddawg1100 and Mike59 like this.
  7. Sep 27, 2023 at 8:20 AM
    AMan805
    Austin
    124k, just changed timing belt a couple weeks ago
  8. Sep 27, 2023 at 8:20 AM
    AMan805
    Austin
    ok thanks man, ill be sure to get that done.
    Austin
  9. Sep 27, 2023 at 9:04 AM
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    When the timing belt was done, its possible that the coolant was changed then. This might be less of a priority than the other items.
    If your brake fluid is looking dark or if its never been done, it wouldn't hurt to change it out.
    It sounds like you have a nice, low mileage truck.
  10. Sep 27, 2023 at 10:20 AM
    AMan805
    Austin
    I believe the coolant was done then.
    The ps and brake fluid is looking black.
    thoughts on this method for ps? https://www.google.com/search?q=chr...ate=ive&vld=cid:482fdf95,vid:VuPALAnHjRM,st:0
  11. Sep 27, 2023 at 10:23 AM
    AMan805
    Austin
    I got a haynes manual for my truck, i think you just fill till it stops coming out of the drain plug (or something like that)
  12. Sep 27, 2023 at 10:26 AM
    AMan805
    Austin
    ill try to do it myself, only ever done oil before. researching....
  13. Sep 27, 2023 at 10:55 AM
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    The transfer case and differential gear oil refills are simplified by using the bag containers instead of bottles and pump. Valvoline and Amsoil are the two that I know of that use them.
  14. Sep 27, 2023 at 12:52 PM
    I started wrenching with Haynes and Chiltons more moons ago than I'll disclose. Skip them on this truck. Grab this, save a copy to your computer.
    Grease is a thick fluid, I would add greasing all zerks across the truck into the swing of things.
