Fluid question?
Discussion in '2nd Gen Tundras (2007-2013)' started by SJP2012TUNDRA, Nov 13, 2023.
  1. Nov 13, 2023 at 7:10 PM
    SJP2012TUNDRA
    SJP2012TUNDRA [OP] New Member
    2012 Tundra TRD 4x4 double cab
    3” Toytec lift ( bilstien shocks, springs and spacer ) 285/70R18 Toyo AT’s
    For differentials, transfer case and transmission is there an advantage/disadvantage to oem oils vs an aftermarket such as Lucas / Amsoil?
    thanks.
  2. Nov 13, 2023 at 7:12 PM
    TundyMcTunra
    TundyMcTunra Irrational people are not often convinced by facts
    Lost in the PNW
    2010 Tundra Limited Crew Max 4x4, 2018 Tacoma Inferno TRDORDCSB, 2019 Rav4 Lunar Rock, 1991 4Runner Crawler. Ivan Stewart Edition
    Nope. You can now close this thread
  3. Nov 13, 2023 at 7:12 PM
    For your 2012? Probably not. There were no LSD options for that year so any reputable, spec appropriate fluid should suffice.
  4. Nov 13, 2023 at 7:13 PM
    TundyMcTunra
    Lost in the PNW
    Pretty much what said. Thread will close in 3...2.....1..
  5. Nov 13, 2023 at 7:22 PM
    AZBoatHauler
    So.Arizona
    I wouldn’t mix transmission fluids so I stick with Toyota WS. I put amsoil in the diffs.
    CMikeB likes this.
  6. Nov 13, 2023 at 7:28 PM
    MEWaters
    MEWaters New Member
    Maine
    07 2UZFE TRD OR; previous 02 AC 323k
    Eibach pro suspension Nitro 4.88 with Auburn Pro LSD and PTFE diff bushings Level 8 MK6 18x9 SAIS bypass JBA cat back Scangauge 2 Diode dynamic fogs. LED heads Husky liners
    It’s not uncommon for Toyota dealers to not even use WS transmission when servicing
    KNABORES likes this.
  7. Nov 13, 2023 at 7:29 PM
    Many will use Valvoline Max life WS fluid
  8. Nov 13, 2023 at 7:37 PM
    AZBoatHauler
    So.Arizona
    Guess it’s good I’m the only one that services it.
    MEWaters likes this.
