Fluid Film
Discussion in 'Sequoia Builds' started by farnsrocket, Nov 9, 2021.
  1. Nov 9, 2021 at 7:00 AM
    farnsrocket
    farnsrocket [OP] New Member
    Just Fluid Filmed the beast! Stuff is pretty sweet! Used a spray gun off Amazon and a gallon of Fluid Film black. I was surprised how clean it went on and barely got on me or the driveway. Just filled my spray gun cup up and heated it up a little with a heat gun. Used about a little over 3/4 of the gallon. Didn’t have time to take a lot of pics. Tac’d out my spray gun with a flashlight!
    Felt bad hitting my new pretty Dobinsons springs and shocks but it’ll help them last I guess.
    Fluid Film
    Fluid Film Black Non-Aerosol,... https://www.amazon.com/dp/B08R1GHVNN?ref=ppx_pop_mob_ap_share
    Spray gun
    TCP Global Air Rust Proofing and... https://www.amazon.com/dp/B07QR18BT7?ref=ppx_pop_mob_ap_share
    Vr0ck, S. Equoia, Luckydog and 3 others like this.
  2. Nov 9, 2021 at 7:07 AM
    DZ_
    DZ_ New Member
    Frederick Co., MD
    2019 Tundra Crewmax Limited TRD DadWagon
    Does it dry or remain greasy like the regular aerosol stuff? Does it burn off the exhaust piping?
    Nice GS!
    farnsrocket[OP] likes this.
  3. Nov 9, 2021 at 7:10 AM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    Interesting, cool & makes me glad I live outside the rust belt!
    farnsrocket[OP] and Desert Dog like this.
  4. Nov 9, 2021 at 7:14 AM
    Looks like you got just about everything. I'm hoping you were careful around rubber bits, as fluid film can cause it to swell. Bushings and such are something to avoid if possible.
    It's best to avoid spraying it on anything that gets hot. Not sure it will catch fire, but it will definitely smell.
  5. Nov 9, 2021 at 7:14 AM
    Desert Dog
    Desert Dog Nobody rides for free
    2001 SR5 AC 2WD 4.7l
    Bilstein 5100's, SPC UCA's, ATS HD leaves
    X2
  6. Nov 9, 2021 at 7:18 AM
    BecauseRacecar
    BecauseRacecar New Member
    Ohio
    '20 Tundra SR5 DC 4x4 Magnetic Gray
    I haven't noticed any issues with rubber swelling in about 5 years of use, but that's only 5 years service time. At this point though, the rust is so bad on my wife's 6 year old Mazda 3 that the bushings look like they'd be on their way out even if we weren't using fluid film.
    Definitely want to avoid spraying on hot stuff, like exhaust parts, but mainly because of smell and it will stain the steel after a few heat cycles. No concerns about things like gearboxes though. I'd avoid moving parts like pulleys on the engine though, and the engine entirely...
    But don't forget the brake lines near the ABS unit in the engine bay! Those are surprisingly coated in salt on every one of our vehicles.
  7. Nov 9, 2021 at 7:52 AM
    farnsrocket
    It stays greasy I believe……my first time using it. Yeah it’s hard to avoid the exhaust with the overspray and it did smoke/cook off and I can still smell it on day 3. Someone told me it takes about a week to go away.
    Thanks, that’s my main travel vehicle to work as long as the roads aren’t icy and when I can get time to take the wife out on a ride!
    DZ_[QUOTED] and GODZILLA like this.
  8. Nov 9, 2021 at 7:56 AM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    Looks good.
    I did Corrosion Free this year, first time doing any undercoating. I was careful not to spray directly on exhaust etc, but it definitely got on with overspay and smelled for a couple weeks of the little driving I do.
    It's all gone now. A week of normal driving should get rid of it.
  9. Nov 9, 2021 at 8:01 AM
    bwh
    bwh New Member
    How long did it take you to do the truck tip to tail?
  10. Nov 9, 2021 at 8:06 AM
    Luckydog
    Luckydog New Member
    Dominic
    2015 DC TRD Offroad.
    Ranch Hand Summit front and rear bumpers. Diamondback SE tonneau cover. Rigid DOT fogs. LED headlight/fog replacement bulbs. Matt Gecko hood, and bed LED's. Foot well led's, and interior LED buld replacement. (warm) Broke the front shock of the 3" spacer lift, so replaced with 6112/5160 and 1' block rear. KO 2's. Speaker replacement, added amp and (2) 10's under seat. Weathertech floor mats. Salex organizers. Ziebart undercoating. RCI front, transmission/diff, and gas tank skids received, waiting for spring install. Compustar remote starter. front/rear dash cam.
    The black FF looks great!
  11. Nov 9, 2021 at 8:08 AM
    It's just a caution that is on Fluid Film cans and such.
  12. Nov 9, 2021 at 8:14 AM
    farnsrocket
    Probably a couple hours. Used a floor jack to get one side up high so I could crawl under…..a lift would be so nice. I also had to remove my cat converter anti-theft plate, so that took a little time. I didn’t take off my front skid plate and am debating if I should to get back under there and remove it. I sprayed what I could see into that underside from the back of the skid plate and figured it protected most of that area. I don’t think there is much else, just engine. I dunno.
    Next year I’ll probably put the whole truck up on jackstands and take both plates off and maybe wrap the exhaust in old sheets or something.
    BravoDeltaRomeo likes this.
  13. Nov 9, 2021 at 8:15 AM
    jomikepa
    jomikepa New Member
    O-H-I-O
    21 black truck
    I just ordered this, is it best to tape off the exhaust and such? Or just try to avoid direct hits, seems like the over-spraying will be messy.
  14. Nov 9, 2021 at 8:23 AM
    farnsrocket
    It’s not as bad as I thought but it still gets hit with some spray. Next year I’ll probably wrap some of the exhaust in some pieces of old sheets and/or use a big piece of cardboard to hold against the exhaust as I spray.
  15. Nov 9, 2021 at 11:41 AM
    Luckydog
    Luckydog New Member
    Dominic
    I have never covered exhaust. It burns off quick. Did you take the wheel well liners off? I bought a big bag of fasteners off Amazon after my first time taking out liners. Much easier to break them off than try to reuse them. I take wheels off to do this. I try to spray twice a year. One thorough application, and one touch up. I also like to get a couple aerosol cans and an extra long straw to get in doors. I also like to spray heavy in the frame rail, and drop the spare to get under it and the tire lowering mechanism, and the spare rim.
  16. Nov 9, 2021 at 11:50 AM
    farnsrocket
    Nice man! I didn’t get that detailed since it was my first time using it. I was more worried about the gun working and how messy it might get. Next year I’m definitely gonna get it up on jack stands, take the wheels and skid plates off and cover a lot more area and get into the frame. Thanks for the ideas!
    Luckydog[QUOTED] likes this.
  17. Nov 9, 2021 at 11:59 AM
    Luckydog
    Luckydog New Member
    Dominic
    It’s addictive, and oddly satisfying. Somehow I have grown to enjoy the smell. Haha
  18. Nov 9, 2021 at 12:03 PM
    Ckatz53
    Ckatz53 Newish
    MD
    2020 Cement Tundra CM Limited 4x4
    www.fouroneodetailing.com
    Take aluminum foil and wrap the exhaust piping next time. Easy on, easy off.
  19. Nov 9, 2021 at 12:16 PM
    farnsrocket
    Genius!! :thumbsup:
    Ckatz53[QUOTED] likes this.
  20. Nov 10, 2021 at 5:09 AM
    Trdwillie14
    Trdwillie14 New Member
    Billy
    2014 trd off road
    2.5 fox 2.5 ads triple bypass T/C uppers Nfab front bumper Westin rear Bajas Rci skids All pro sliders Icon rxt leafs Stt pros Method 701s 37 Mickey Thompson
    Check out mattgecko led dude just did it to my bike it’s a huge upgrade
  21. Nov 10, 2021 at 5:14 AM
    Ckatz53
    Ckatz53 Newish
    MD
    My lady won't ride with me. Said she doesn't like feeling like a badass all the time traveling at Mach Jesus speeds.
  22. Nov 10, 2021 at 5:19 AM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    I just got a gallon of woolwax and the spray gun is on the way. I couldn’t decide between FF and woolwax. I’ve use less FF before in spray cans and figured I’d try woolwax this time. I’ll admit the smell of FF was a factor. I’ll have to report back on how it applies.
  23. Nov 10, 2021 at 5:57 AM
    farnsrocket
    Wow, never saw that before…..looks amazing!
    I had Cyclops LED bulbs in the bike when I bought it and one burnt out so I just put some Amazon LED bulbs in there pretty bright, that Mattgecko is a whole other level. Speaking if upgrades, have you seen this?
    https://sales.nightrider.com/AF-XIED-for-BMW-R1200_p_59.html
    Totally transforms your bike!! Better throttle response, keeps bike rich, more power……just awesome!!!
  24. Nov 10, 2021 at 5:57 AM
    farnsrocket
    So sweet!
  25. Nov 10, 2021 at 6:10 AM
    Trdwillie14
    Billy
    2014 trd off road
    Sweet I’ll have to check that out.
  26. Nov 10, 2021 at 6:43 AM
    farnsrocket
    Very cool, is that version#2?
  27. Nov 10, 2021 at 6:53 AM
    Trdwillie14
    Billy
    2014 trd off road
    Just ask for the one with a more oem fit I don’t remember lol
