Fluid Film Uses and directions
Discussion in 'General Tundra Discussion' started by csuviper, Apr 6, 2016.
  1. Apr 6, 2016 at 6:17 PM
    csuviper
    csuviper [OP] Moderator Staff Member
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    I purchased some fluid film based on recommendation. Haven't ever used it. For those that have used it I'm curious on how to use it?
    What can it be used on? Types of material?
    Can it be used on shock body's?
    What prep needs to be done before?Spray and let dry?
    How many coats?
    Does it dry like a clear coat or is it a wet feel?
    Do you need to follow up with additional costs down the road?
    Tips and tricks?
  2. Apr 6, 2016 at 6:23 PM
    csuviper
    Broomfield, CO
  3. Apr 6, 2016 at 6:27 PM
    I've heard of Fluid Film but have absolutely zero experience, so of no help. Wheelers'/Amazon sells this stuff too. Ever heard of it? Appears to be a very similar product: upload_2016-4-6_19-27-52.jpg
    YotaDan likes this.
  4. Apr 6, 2016 at 6:44 PM
    I bought this from @YotaDan to help repel water from my shocks. Wonder if it can help prevent rust?
  5. Apr 6, 2016 at 6:56 PM
    YotaDan likes this.
  6. Apr 6, 2016 at 10:15 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    I have used it and I think it has done a great job with rust prevention on my Tundra. I sprayed it on metal including my shock bodies, frame, UCA's, pumpkin, etc., basically the entire undercarriage. I avoid electrical connections. They say it is great to prevent corrosion, like if you spray it on your battery terminals AFTER the POS and NEG wires are connected it will prevent corrosion on the terminals, however DO NOT spray it on the terminals before connecting the POS and NEG wires, as it is an insulator and could interrupt the flow of electricity. Based on that, I keep it away from electrical connections BC it seems to seep into areas well.
    It is an excellent lubricant so keep overspray away from brake rotors. Great for household squeeks too.
    For rust prevention they say to spray every fall. One heavy coat, i dont do any prep, just careful of overspray. I use a few rattle cans and sometimes i spread it with a rag. Some guys get really into it and drill holes and spray it in the holes to coat the insides of things. They also can use an air compressor and spray gun to apply it. It has an odor to it so if you spray your truck in the garage amd keep your truck in the garage, your garage may smell for a few days until it dries completely. It dries an off white color, somewhat sticky.
    It also works great as a wheel cleaner believe it or not. Spray it on the wheel, let it sit for a few, then wipe it off.
    I think that's about it...
    Black Wolf likes this.
  7. Apr 6, 2016 at 11:38 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    And it's bad for some types of rubber.
  8. Apr 7, 2016 at 8:15 AM
    YotaDan
    YotaDan New Member
    Grants Pass, Oregon
    I have both the Fluid Film and the MavCoat at home. I do really like the fluid film. It works great. Only downside is the thick yellow residue. So for shocks, coilover or anything nice or that is visible to the eye I have been using the MavCoat on. It is almost like using a clear coat except that it is also a lube, and better a preventing rust and corrosion.
    Wrongside and Black Wolf like this.
  9. Apr 7, 2016 at 8:47 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Going to have to check out this MavCoat. How's it applied? Yeah, that's the reason I only use fluid film on select areas. It's like smearing maple syrup all over your nice truck.
    YotaDan likes this.
  10. Apr 7, 2016 at 11:11 AM
    CMB
    CMB New Member
    Cecil County MD.
    2010 Tundra DC 4X4 SR5
    Not nearly enough room here!
    I use a couple cans of Fluid Film on the underside and under the hood of my Truck every year.Snow Blower chute,impellar,mower deck and everything else that I think needs rust protection and/or long lasting lube.Lanolin Base means no Haz-Mat charge when shipping too.Can't speak about how this product harms rubber.God knows, I've loaded-up gaskets,seals,o-rings and spacer/bushings with it for several years.....no damage yet.
    NewImprovedRon and YotaDan like this.
  11. Apr 7, 2016 at 5:57 PM
    It sounds like a win win with either product.
  12. Apr 26, 2016 at 6:48 PM
    Ericsopa
    Ericsopa Old man and the sea
    And don't forget....Fluid Film is good for treating ringworm on your sheep and goats.:rofl:
    vidman and YotaDan like this.
  13. Aug 14, 2016 at 4:20 PM
    Lee's rig
    Lee's rig Party naked
    Lee
    North nj
    2014 DC and 2014 single cab both 8' bed with 5.7
    To many
    Had it on for a year now . Works great. Stayed the crap out of my rails and under side of the bed. I use an air compressor. One guy said it is lick smearing maple syrup on a new truck. Well yes almost but you don't see it under there and it keeps the frame and bed like new . I don't want my frame looking like these
  14. Aug 14, 2016 at 5:23 PM
    bsktball55
    bsktball55 New Member
    Ryan
    Missouri
    16 Tundra TRD Pro
    Bakflip MX4 Toneau cover Esp storage Audio system (Helix speakers, JL audio amp and sub) Front windows and windshield tinted LED interior and bed lights
    How many cans does it take to spray the underneath of the truck?
  15. Nov 14, 2021 at 3:08 PM
    Il0kin
    Il0kin New Member
    2012 Tundra
    This is an old thread but I'm bumping it because I did mine today. I used 3 cans which was enough to coat the whole frame, trailer hitch, suspension components and a few other areas but not enough to fully coat everything on the underside of the truck. I think next year I will get 4 or maybe even 5 cans so I can do some extra general spraying.
    Old clothes and a TyVek suit, a plastic sheet under the truck, N95 or respirator, latex/nitrile gloves and a hat are all must-haves.
    What I am not sure about is whether I should go wash my truck to get the overspray off? I can't imagine it is hurting anything.
