Fluid Film rust preventing frame and undercarriage spray
Discussion in 'Detailing' started by Pudge, Aug 21, 2019.
  1. Aug 21, 2019 at 12:40 PM
    Pudge
    Pudge [OP] Super Secret Elite Member #7
    CT
    2015 Blue Ribbon Platinum
    I have used aerosol cans of fluid film for a few years on my truck, lawnmower, snow blower and various things around the house. I decided last year to get a gallon of it and a spray gun for my compressor. I just did my while undercarriage with a very thick coat and used about 3 quarts. I was really surprised how well the gun worked, even with my small pancake compressor. There was absolutely no drips or clumps, the fluid fill came out in a nice fog pattern and covered really well. I can try to get some pics of the frame later, about half way thru the project a thunderstorm hit so I finished up in the garage, and made a huge mess. The only downside is overspray but it really wasn't as bad as I thought it would be.
    VRC, rons23, 316KS_Runner and 6 others like this.
  2. Aug 21, 2019 at 1:11 PM
    Kerch71
    Kerch71 Surgical Precision
    Mechanicsville VA
    Can this be applied over surface rust? Or does your undercarriage need to be pretty rust free before applying?
  3. Aug 21, 2019 at 2:29 PM
    Pudge
    CT
    You apply it right over surface rust. Ideally I would treat any rust then spray this on, but here in CT that's a never ending battle. The fluid film creeps and penetrates (giggity) into every area you spray. It's safe to spray on anything, I try to keep it away from exhaust but other than that I just spray away. While it is not a rust converter, it does seem to penetrate under surface rust and somehow clean it up. I also use it under the hood of the truck, I use a brush to hit al the body ground bolts, battery terminals, and also spray onto inner fenders and any other sheet metal. I also coat the back side of any body panels that I can reach from under the truck (most of the inside bed panels can be sprayed), inside the tailgate, you can remove plastic plugs on rocker panels and doors and spray in there too.
    GODZILLA, Backslider, NUDRAT and 3 others like this.
  4. Aug 21, 2019 at 2:32 PM
    Pudge
    CT
    Eventually it turns to a shiny black look.
    Its a great lubricant too, so I'm not shy getting it on suspension components, springs, and other moving parts.
    Wallygator, VRC, P-Factor and 5 others like this.
  5. Aug 21, 2019 at 2:37 PM
    Pudge
    CT
    Be prepared to wash your truck after you spray this stuff. The overspray is very light and gets up in the air. It's pretty slippery too so I don't recommend applying in your garage, and if you do, throw a tarp down. I started in my asphalt driveway but thunderstorms forced me into the garage, now I'm degreasing the floor lol
    NUDRAT, TheBeast and NewImprovedRon like this.
  6. Aug 21, 2019 at 2:50 PM
    BeachyTundra
    BeachyTundra New Member
    Brandon
    Spokane
    2017 MGM 5.7L DC, Bilstein 5100s
    I was literally thinking about this exact thing the other day when I crawled into my fender to replace my fogs, and found that I was missing a bolt because it had rusted all the way through....2017, I shouldn't have that much rust already :(
    NUDRAT, Pudge[OP] and Kerch71 like this.
  7. Aug 21, 2019 at 2:50 PM
    Kerch71
    Mechanicsville VA
    Wow, looks great! Appreciate the info. Definitely gonna give it a try.
    Pudge[OP] likes this.
  8. Aug 21, 2019 at 2:54 PM
    Pudge
    CT
    The aerosol cans work well, it just started getting expensive. This little gun and my compressor worked great. Apply it once a year before winter everywhere you can get it and your truck will be in pretty good shape no matter what mother nature, or the department of transportation throws at you. It does leave an oily film on everything so dust and crap sticks to it, but that seems to form a nice protective layer that the salt brines can not get through.
    GODZILLA and NUDRAT like this.
  9. Aug 21, 2019 at 3:13 PM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Would be good to see pics of the process.
  10. Aug 21, 2019 at 3:14 PM
    BeachyTundra
    Brandon
    Spokane
    If you don't mind, what type of gun did you use, and how big was your pancake compressor? I think this is something I could knock out fairly quickly after a good underbody clean-up
  11. Aug 21, 2019 at 3:16 PM
    Pudge
    CT
    I got the gun on Amazon, its specifically for fluid film or wool wax. I got it last year but I'll try to find the link. I have a 6 gallon, 150psi compressor, it ran pretty much non stop while I was spraying but it always had plenty of pressure behind it.
    BeachyTundra likes this.
  12. Aug 21, 2019 at 5:13 PM
    Pudge
    CT
    Still pretty thick in some areas, it should start to flow and clear up in color over the next day or two. I really wish I could put the truck on a lift to do this, I may invest in some ramps, that would help a little. I will likely hit it again with a lights spray on problem areas before the snow flies.
    Tundra2, FirstGenVol and Backslider like this.
  13. Aug 21, 2019 at 5:17 PM
    Pudge
    CT
    It never dries which is what makes it effective, and it does not drip, you can see some drips in some of the pics, those are water drops, it's been pouring rain here for the last few hours and I had to take it out in the rain. Eventually it does wash off from just regular driving in rain and snow, some areas quicker than others, some spots it was still coated from when I last sprayed 2 years ago.
  14. Aug 21, 2019 at 5:23 PM
    TXMiamiFan
    Jose
    So you just spray everything? No need to cover anything?
  15. Aug 21, 2019 at 5:28 PM
    Mnorris1206
    08 tundra
    I wonder of this is the same kinda stuff toyota had used on my frame. But they did tell me it wont come off and now a yr later I can see it would have to be scraped off I think.
  16. Aug 21, 2019 at 5:41 PM
    Pudge
    CT
    Yup I spray everything, I have read a few things about how fluid film might causes certain types of rubber to swell but I have never seen an issue.
    Tundra2 and TXMiamiFan[QUOTED] like this.
  17. Aug 21, 2019 at 5:45 PM
    Pudge
    CT
    As it gets closer to winter, and when I need to rotate my tires I will spray again. Itll be nice to hit the wheel well areas when the wheel is off. Also I need to drop the spare tire and spray the subframe and underside of the bed in that area, I got all the rest of the floor done today, just not above the spare. I also made a little extension hose thing that i can use to spray up in the rockers and lower doors, there are little rubber access plugs that can be pulled and replaced after spraying.
    NUDRAT likes this.
  18. Aug 21, 2019 at 5:57 PM
    TXMiamiFan
    Jose
    Don’t forget to spray the brake rotors :rofl:
  19. Aug 21, 2019 at 6:11 PM
    bsktball55
    bsktball55 New Member
    Ryan
    Missouri
    16 Tundra TRD Pro
    Bakflip MX4 Toneau cover Esp storage Audio system (Helix speakers, JL audio amp and sub) Front windows and windshield tinted LED interior and bed lights
    I do mine in November before we start getting any snow. Does it the last two years and I don't have a speck of rust on my frame even though they salt our roads like crazy anytime it starts drizzling in the winter.
  20. Aug 21, 2019 at 6:16 PM
    Pudge
    CT
    Good tip buddy, they do get pretty rusty. :rofl:
  21. Aug 21, 2019 at 6:18 PM
    Pudge
    CT
    I missed a year and it shows. I'm hoping this coat will help me turn back the clock a little. I did it the first winter I had it but missed last year. Amazing how much damage the salt brine causes and how quickly it does it
    Tundra2 and NUDRAT like this.
  22. Aug 21, 2019 at 6:21 PM
    bsktball55
    Ryan
    Missouri
    16 Tundra TRD Pro
    I had a rusting frame on my Tacoma so I plan on being pretty religious about it especially since I plan to keep it for another 8 or 9 years.
    Pudge[QUOTED][OP] likes this.
  23. Aug 21, 2019 at 6:33 PM
    TheBeast The Beach
    someone prepping for some of that NE winter :)
  24. Aug 21, 2019 at 6:36 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Fluid Film is a great product. We only get salt once or twice a year here and I still get under my truck with fluid film. It's worth the time to ensure my frame doesn't rot.
    Tundra2, jpink, NUDRAT and 1 other person like this.
  25. Aug 21, 2019 at 6:41 PM
    Pudge
    CT
    Me too, first my 99, then my 08. Both rotted thru. The 99 got bought back for the same i paid for it 5 years earlier, and Toyota have me cash towards my 08. I drove the 08 for 8 years, it needed a new frame so I just traded it towards my tundra, and got $7k less than I paid for it 8 years earlier. Rusty frames suck but the resale values were amazing nonetheless. The tundra I baby much more than I did my tacos.
    NUDRAT likes this.
  26. Aug 21, 2019 at 8:36 PM
    nvrgvup444
    nvrgvup444 New Member
    KCMO
    2015 Dbl Cab Limited - Blue Ribbon
    Bilstein 5100 all corners, Toytech Shackles, Nitto Ridge Grapplers, Completely new sound system that sounds great but didn't cost an arm and leg, front camera, front receiver hitch
    I've been using cans... cans and more cans. Was thinking of buying the spray gun. Would you consider the spray gun a more effective way or is it more of a spray and pray type of situation? I know it's got to be more cost efficient over the long run, but can you hit where you aim?
  27. Aug 21, 2019 at 9:01 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
    drop the spare tire to better get the bed floor & bed cross supports for it (& the spare tire reel). (edit - should'a read through LOL)
    Tundra2 likes this.
  28. Aug 21, 2019 at 9:10 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    I used cans last year as I couldn't take it to be sprayed. I got the little hose that goes with the cans. Don't forget to spray into the nose in particular of your hood.
    Tundra2 and Pudge[QUOTED][OP] like this.
  29. Aug 21, 2019 at 9:57 PM
    Yzed608
    Yzed608 New Member
    Wisconsin
    I was wondering the same thing, it looks similar. I have the OEM rust protectant stuff too, there's tons of dirt and whatnot stuck on it now, but seems to have prevented rust where they sprayed. You definitely can't just wipe it off.
    Mnorris1206[QUOTED] likes this.
  30. Aug 21, 2019 at 10:29 PM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    I definitely need to do this, I moved to Sparks and last year was my first year in the snow and i didn't like it.
