Fluctuating oil pressure...Normal?
Discussion in '2nd Gen Tundras (2007-2013)' started by csuviper, Aug 25, 2015.
  1. Aug 25, 2015 at 6:08 AM
    csuviper
    csuviper [OP] Moderator Staff Member
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Noticed my oil pressure gauge go from just under half to about 3/4 when accelerating. Is this normal? If not what could be the cause?
    https://vimeo.com/137246935
  2. Aug 25, 2015 at 6:29 AM
    Oil pressure sensor/oil filter bypass? I know my oil pressure will go up a little when accelerating which makes sense. Could try monitoring with a oil pressure gauge to check pressure levels at idle and work your way up in RPMs.
  3. Aug 25, 2015 at 6:32 AM
    csuviper
    Broomfield, CO
    Posted video. Thought it was normal just seems like it's jumping up higher than I thought.
  4. Aug 25, 2015 at 7:01 AM
    LOTSOFTOYS
    LOTSOFTOYS Toyota Whisperer
    Jace
    Mile high
    2005 Tundra DBL cab
    Yes normal. U should see first gens oil pressure gauges
    Wilbur and T-Rex266 like this.
  5. Aug 25, 2015 at 7:21 AM
    csuviper
    Broomfield, CO
    Ok that's a relief. Checked with the Tundra community, confirmed its a non issue and now ready to go have some fun.
  6. Aug 25, 2015 at 8:39 AM
    My mark is just a tad below the half mark on start up and goes just a tad over when accelerating. Toyota tech @LOTSOFTOYS did my oil change.
    This would have been a good question to post ask the Toyota mechanic ;)
    TNTundra08 and Black Wolf like this.
  7. Aug 25, 2015 at 10:19 AM
    TNTundra08
    TNTundra08 New Member
    Blake
    2008 DC 4x4
    3/1 lift. 20x9 Method standards, machine face. 305/55/20 nitto trail grapplers
    Mines the same as Sean's. Yours fluctuates a lot conparitively speaking
  8. Aug 25, 2015 at 10:56 AM
    Mike Tread lightly.
    south carolina
    Lol.. yep. idle is almost like no oil pressure at all at times.
    LOTSOFTOYS[QUOTED] likes this.
  9. Oct 11, 2017 at 10:53 AM
    TheBeast The Beach
    haha..just noticed that this morning too....and i went straight to tundras.com for my answer :)
  10. Oct 11, 2017 at 10:57 AM
    tomsinamerica
    tomsinamerica New Member
    Tom
    Wilmington, NC
    White 2016 Tundra DC ltd
    better to have too much than too little! When you gas it and it drops... that's the time to panic
  11. Oct 11, 2017 at 6:48 PM
    JTP
    JTP The Big Black Moose
    Sterling, Alaska (Formerly DFW Texas)
    The Big Black Moose
    TOTALLY NORMAL
    Higher pressure indicated at higher RPM = good thing
    Lower pressure indicated at low RPM = good thing
    Its all a very good thing ;)
    If it drops to zero when your driving thats a very bad thing :(
    Had that happen in an Forest Service single engine airplane that I was flying once, not a good feeling at all.
    I immediately pulled the throttle to ided and glided 23 miles and made it to an airport. The right side and the bottom of the airplane looked like what the Exxon Valdez must have looked like, oil EVERYWHERE after I landed. Someone had tried welding up the oil cooler and their welding skills were not all that great. :( When I pulled the dip stick the next morning the engine still had 3 of the 6 quarts of oil left in it (good thing).
    If I had left the power in it would have blown all of the oil out of it and toasted the engine. Changed the oil cooler, topped it back off with oil, cleaned up one heck of mess, and flew it back to my base. No damage at all to the motor.
