Floor Jack.....
Discussion in 'General Tundra Discussion' started by smokey0810, Jun 4, 2022.
  1. Jun 4, 2022 at 10:04 AM
    smokey0810
    smokey0810 [OP] New Member
    '03 Tundra SR5 AC 4WD
    Harbor Freight has the 3 ton pittsburgh jack on sale for $119.00. Think its overkill for a 3-ton for my Tundra, currently have a 1.5 ton craftsman, but have never lifted the truck with it....Thoughts?
  2. Jun 4, 2022 at 10:09 AM
    Sunnier
    Sunny
    San Diego, CA
    Yes you want a 3 ton. Alcan was recently on sale at Costco and I picked one up to replace my HF 3.0 ton b/c every now and then I hear of failures of the Pittsburgh jacks. That said, if you don’t take shortcuts… Al sways position redundant stands before you work underneath, anything that lifts the truck, lifts the truck.
    Cruzer and FrenchToasty like this.
  3. Jun 4, 2022 at 10:22 AM
    What the!?
    What the!? New Member
    2017 Pro
  4. Jun 4, 2022 at 10:28 AM
    Taco-Spike
    Two Trucks
    Ha! I have a 3 ton Pittsburgh (low profile) from harbor freight and a 1.5 craftsman or maybe an off brand one. I use the Pittsburgh a lot more. Greater range of motion and smoother to use. Only time I use the smaller one is when I need 2 for tire rotation
  5. Jun 4, 2022 at 10:32 AM
    WBW
    WBW Resident lurker
    Bruce
    Surface of the Sun - AZ
    2015 CM Tundra SR5 2WD
    I have two floor jacks. The heavy lifter is a NAPA Professional 3.5 ton. It's very heavy & really stout! I use it at home in the garage or driveway for the heavier lifts such as the trucks.
    I also carry a pneumatic 3 ton unit for the trailer should we encounter a tire issue on the side of the road. IMAG0907.jpg
    This thing is awesome! It's lightweight (hence the trailer usage), has a large surface area base for loose surfaces, and my 10 gallon air tank at 125 PSI will lift both front tires off the ground on my truck exactly once. Got it on Amazon.
    https://www.amazon.com/dp/B01MSWGZ5M
    Trooper2 likes this.
  6. Jun 7, 2022 at 9:32 PM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    I use a Pro Eagle 3-ton jack. You’d probably want a 3 ton to do anything with the Tundra. 1.5 is a bit small.
