Floor Jack and Lighting
Discussion in 'General Tundra Discussion' started by DesertWanderer, Sep 4, 2022.
  1. Sep 4, 2022 at 1:14 PM
    DesertWanderer
    DesertWanderer [OP] New Member
    2004 White Tundra
    Hello. I am one of those weird people who likes to carry a floor jack in his truck, primarily for tire changes. I have a 3 ton "Daytona" from Harbor freight which is great in my garage but it is a little heavier (OK, a lot heavier) than I would like for mobile use. I have 3 other floor jacks (US General, Harbor Freight, 1.5 to 2 ton) that are aluminum frame and a hell of a lot easier to lift. Should the aluminum frame jacks be up to tire changes on my 2004 Double Cab 2WD? Do you have better choices?
    I also would like better headlights (brighter). Any ideas there?
    Thanks to all!
  2. Sep 4, 2022 at 3:09 PM
    thearborbarber
    thearborbarber New Member
    SoDak
    2018 Tundra SR5
  3. Sep 11, 2022 at 8:50 AM
    41bigdawg
    41bigdawg Let the BIG DAWG Eat
    Robert
    Tennessee
    2013 Tundra DC 5.7
    Magnum front, Iron Cross rear bumpers, SB Cold air intake and Gibson Metal Mulisha exhaust, Fender flares, Tow mirrors, 18" Outlaw wheels, 12k Smitty X2O winch, Tech 12v auto start, Firestone Air Bags, Pedal Commander, Devil Horns, etc...
    texasrho83 likes this.
  4. Sep 11, 2022 at 10:03 AM
    Sunnier
    Sunny
    San Diego, CA
  5. Sep 11, 2022 at 11:18 AM
    VWTim
    VWTim Mid-Travel Crew
    Corvallis, OR
    I'm interested in seeing any photos of how people have them mounted in their beds, specifically the 1.5 size models without a bed cage.
    I have a HF 1.5T and build a skid plate. So far I have the handle mounted with quick fist clamps off the bed rails (actually half-strut) and looking to mount the jack over the pass fender well.
  6. Sep 12, 2022 at 5:58 AM
    DoublePro
    DoublePro New Member
    For those that don’t want to carry a big heavy jack around, is there a bigger factory option style scissor lift jack? I once had a flat tire on the side of the road, got my OEM spare tire off, jacked up the truck with the OEM jack, it didn’t reach! I was lucky someone pulled over and offered his floor jack.
  7. Sep 12, 2022 at 6:27 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Bowzer and DoublePro like this.
  8. Sep 17, 2022 at 10:38 PM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    2021 Tundra DC, 2022 4R, 2007 FJ
    Magnuson Supercharged, Dobinson Lift, 315/70r17 on Rockwarriors, Heftyfab bumper, Dirty Deeds 3” race exhaust
    AB71BCAE-7793-4DE1-8A2F-3B1ADCD8FC90.jpg 417E5F73-AFED-48D4-B968-10521C6B781F.jpg I looked into safe jacks alot and other options they are pretty good. I came up with an alternative I’m trying out which is 6x6 post offset bases bolted together with the OEM jack on top, similar to other peoples use of a block of wood but lighter. Using 5 right now and it weighs just 2 extra lbs and fits under the seat next to the stock jack.
    2mchfun, DoublePro and bulldog93 like this.
  9. Sep 18, 2022 at 7:16 AM
    Solid Snake
    Solid Snake The Anciet of Mu Mu
    West TN
    2006 AC 4x4 V8
    I keep a 2-ton floor jack (AC Delco) in my bed mounted tool box.
  10. Sep 18, 2022 at 7:32 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I have a 2 ton offroad jack and 6 ton bottle jack with numerous blocks of wood. I also carry a pair of jack stands and wheel chocks.
  11. Sep 18, 2022 at 7:56 AM
    Terndrerrr
    Terndrerrr 925000 miles to go
    Music City
    6UR-FE
    I just had a flat on the highway. I patched it and re-inflated it on the side of the road. Barely a 10-min job, and most of that time was spent waiting on my compressor to do its job. I did not need to jack up the truck and swap tires.
    You’ll still need to swap tires if you tear the sidewall, but for simple tread punctures, the compressor and tire repair kit I carry weigh maybe 5-6lb and occupy a small space in my toolbox. Pics here.
    Maybe a taller bottle jack and a solid plank of wood would work if you have a lifted truck that has rendered your factory jack too short.
    e30cabrio, reywcms and bulldog93 like this.
  12. Sep 18, 2022 at 11:17 PM
    07 Tundie
    07 Tundie Shadowfax
    SC
    2007 DC 4.7L 4x2 SR5 Super White
    I have a 12 ton bottle Jack from HF in my back seat. Works well when I’ve needed it.
  13. Dec 2, 2022 at 10:36 AM
    DesertWanderer
    2004 White Tundra
    Hello. I have still not resolved my problem regarding how to jack up my vehicles to change a tire when I am away from home. I have a 2004 Double Cab Tundra, a 2004 Access Cab Tundra Stepside (No ugly Tundra jokes, it has 100,000 miles on it and is in GREAT shape!), and a 2003 Sequoia. All are factory height and will remain that way. I prefer a floor jack but not any of the 100+ pound varieties.
    I am wondering if the jack below will work for tire changes away from home. The 36 pounds of weight sounds cool! My other option is below. It was suggested by reywcms on this site
    https://safejacks.com/collections/bottle-jack-accessories
    Thoughts? You guys have solved all of my other problems, maybe this one as well please?
    reywcms likes this.
  14. Dec 2, 2022 at 10:46 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    I bought the bottle jack version from Harbor Freight 12ton. Less space taken, lighter etc.
  15. Dec 2, 2022 at 10:51 AM
    DesertWanderer
    2004 White Tundra
    Also, FYI, my Stepside Tundra goes in for "Special Service Campaign 70B" service in about a month. Toyota is replacing my lower ball joints even though my Tundra has 100,000 miles on it. Cool! Wonder what else they will say needs replacing?
    NickB_01TRD and reywcms like this.
  16. Dec 2, 2022 at 10:53 AM
    trj
    trj New Member
    Tom
    2020 Tundra SR5 TSS Quicksand
    Like the setup. Yes on bottle jack. It can give you options in situations where you would prefer to jack up the axel instead of the truck.
  17. Dec 2, 2022 at 10:58 AM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
  18. Dec 2, 2022 at 11:00 AM
    e30cabrio
    I also have a compressor & tire repair kit, agreed, when possible that's the faster easier option!
  19. Dec 2, 2022 at 11:58 AM
    VWTim
    Corvallis, OR
    I haven't used that one, but I have the cheaper HF 1.5T jack mounted in my bed with a custom riser and skid plate. I've used it to lift 1 corner at a time without issue, but I wouldn't use it for anything past tire changes.
  20. Dec 2, 2022 at 12:25 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    You'd be able to jack up the rear, 1 side, from under the axle fosho. Not sure if it'd reach the frame to lift the front. One option would be the less expensive, $99, 1.5T Pittsburg racing jack from HF fitted with a jack pad and extension from Pro Eagle. Your end price would be roughly the same and you'd have a good solution. The Pittsburg jack is 3 lbs lighter too. I'm not 100% sure the requisite jack pad from PE works on the HF jack but it did work on one of my Arcan jacks.
  21. Dec 2, 2022 at 12:49 PM
    DesertWanderer
    2004 White Tundra
    Thanks Rey! Looks neat! Do you have the bottle jack laying down when not is use? Does it leak any fluid that way?
  22. Dec 2, 2022 at 1:19 PM
    2mchfun
    A bottle jack with the bleed screw closed snug will not be leaking regardless of the orientation in storage unless there's a major problem with the jack or seals.
    FrenchToasty likes this.
  23. Dec 2, 2022 at 1:24 PM
    e30cabrio
    I have that on my HF jack, works great. I lift the front on the TRD PRO skidplate middle jacking point.
    831Tun[QUOTED] likes this.
  24. Dec 2, 2022 at 1:28 PM
    GG.Offroad
    GG.Offroad New Member
    Austin
    Westminster, CO
    2023 Tundra Limited Hybrid Lunar Rock
    www.ggoffroad.com
    following... looking for an alternative to lugging my highlift around.
  25. Dec 2, 2022 at 1:29 PM
    2mchfun
    Fwiw guys, pawn shops often have some decent equipment up for grabs. Don't be fooled, negotiate the pricing too!:thumbsup:
    GG.Offroad likes this.
  26. Dec 2, 2022 at 2:55 PM
    GG.Offroad
    Austin
    Westminster, CO
    www.ggoffroad.com
    What have had luck finding at pawn shops if you dont mind me asking?
  27. Dec 2, 2022 at 3:01 PM
    2mchfun
    Guns, scopes, instruments and amps, tools, machinery, fishing gear, camping equipment, rims, etc. Lots of stuff, about 60% under retail in most cases. If it isn't a decent deal, I don't buy it. The idea is, if I need the money back, I can sell it without much, if any loss.
  28. Dec 3, 2022 at 2:56 PM
    e30cabrio
    Harbor Freight has the off road jack available, just ordered one.
    Dawoofles, Sunnier and FrenchToasty like this.
  29. Dec 3, 2022 at 3:02 PM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    Wow, product weight of 70lbs, seems unrealistic for day to day usage for weight/size. Obviously would like one if I changed a flat, same with a full sized air compressor and air tools too haha.
  30. Dec 3, 2022 at 3:06 PM
    Sunnier
    Sunny
    San Diego, CA
    Stolen stuff. Anything a thief can move.
