Flex Fuel issues
Discussion in '2.5 Gen Tundras (2014-2021)' started by etchesketch63, May 1, 2015.
  1. May 1, 2015 at 11:59 AM
    etchesketch63
    etchesketch63 [OP] New Member
    2014 TUNDRA TSS
    AFE COLD AIR, FLO-PRO CAT BACK DUALS
    1st, no badging so why flex fuel? 2nd, cannot SC flex what gives?
  2. May 1, 2015 at 12:04 PM
    chphilo
    chphilo Tundra addict
    Western PA
    Welcome to the forum. Is there something inside the fuel door that indicates that the vehicle is ff? You can supercharge it (Sparks does it, as far as I know) but there is no warranty associated with the supercharger for ff vehicle.
  3. May 1, 2015 at 2:11 PM
    tat2ude39
    tat2ude39 MYota
    Robert
    San Tan Valley, AZ
    2021 Tundra SR5 Crewmax ~ ARMY GREEN
    It will note FFV on dealer paperwork and gas cap notes E85. I'm with you there... I went the lesser route and just added the AFE Momentum 2 and a throttle body spacer. Too early though to note significant gains for mileage, but I do feel a little extra UMFFFFF at times, and a throaty~er sound when getting on it.
  4. May 1, 2015 at 5:28 PM
    AxelsHumanDad
    AxelsHumanDad Get off my lawn.
    KAIG, NW of The Frozen Tundra
    2015 CM Platinum
    Some suspension tweaks
    My dealer told me not to put the supercharger on my until the warranty is up. :(
    Take that for whatever it means.
  5. May 1, 2015 at 6:26 PM
    Mike Tread lightly.
    south carolina
    Ffv and supercharger?
    All I can say is good luck there is reason im saying that and toyota says no warranty. I might expand this later on the work around you can do to make it work but still warranty is gone really I dont recommend it.
  6. May 1, 2015 at 6:29 PM
  7. May 1, 2015 at 11:58 PM
    tat2ude39
    tat2ude39 MYota
    Robert
    San Tan Valley, AZ
    If there's a SC available for your year and Toyota does the install, there are no warranty issues. I've asked on the 15's and no SC for flex fuel, yet. It is available though for non FFV which @TRDPRO1 has done. Any other forms of SC out there would most likely void warranty on engine. There was a link I posted in one of my other posts stating though that a warranty can't be voided solely because you add an aftermarket part. They, Toyota, would have to prove whatever aftermarket work or part added was the direct cause of said problem.
    TRDPRO1 likes this.
  8. May 2, 2015 at 8:38 AM
    TRDPRO1
    TRDPRO1 New Member
    Ed
    Seattle, WA.
    2015 TRDPRO in inferno
    TRD Supercharger, ESP storage, Toyo M/T's, Bestop NX power boards, Line-X bed liner, Thule rack
    Here is the front page of the SC install manual, states......OE vehicle calibration must be verified before SC install.
    tat2ude39[QUOTED] likes this.
  9. May 4, 2015 at 11:04 AM
    etchesketch63
    2014 TUNDRA TSS
    Well......just received feed back from Sparks TRD, S/C will fit FFE but must use Unichip to tune since NO FLASH from Toyota or TRD, engine & power train warranties voided.
    TRDPRO1 likes this.
  10. May 4, 2015 at 4:37 PM
    TRDPRO1
    TRDPRO1 New Member
    Ed
    Seattle, WA.
    Agreed, you can install a supercharger on a ffv but warranties are voided.
  11. May 4, 2015 at 5:40 PM
    Mike Tread lightly.
    south carolina
    This makes me wander if toyota will quit supporting flash firmware on the ecms soon. If this is the case the supercharger Might be eol soon in trd line up.
