Flat Towing a Tundra
Discussion in '2nd Gen Tundras (2007-2013)' started by Bg4748, May 9, 2021.
  1. May 9, 2021 at 1:01 PM
    Bg4748
    Bg4748 [OP] New Member
    Bob
    I'm looking to purchase a used older Tundra (2007-2010) , either rwd or 4wd. Can either of these be flat towed with a REMCO driveshaft disconnect?
  2. May 9, 2021 at 1:25 PM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    That should work fine. You want to disconnect the driveshaft so the output shaft of the trans dosent spin.
  3. May 9, 2021 at 1:38 PM
    Bg4748
    Bob
    So 2wd or 4wd doesn't matter as long as there is a driveshaft disconnect in place...right?
