Flat leaf springs
Discussion in 'Suspension' started by MC Mike, Apr 4, 2016.
  1. Apr 4, 2016 at 5:07 PM
    MC Mike
    MC Mike [OP] New Member
    Central NY
    2015 tundra SR5 TRD
    Fuel Pump 20x9 wheels with 33x12.5 Federal tires. 3/1 lift level kit from off road and TRD PRO grill and hood bulge
    I have a 2015 tundra with a 3/1 level kit. My rear springs are just about flat. No U shape to them. Anyone know why?
  2. Apr 4, 2016 at 6:07 PM
    Any pix to have a better idea?
  3. Apr 4, 2016 at 6:13 PM
    Ditto^^.....Seriously Mike, If you have the time, take some pics. Curious as to what gave you the 1" lift in the rear. This should be an easy fix.By the way, who did the 3/1 and do you know the brand? The more info you can give , the better.
  4. Apr 4, 2016 at 7:10 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I'm going to guess that it's a block between the axle and the bottom leaf spring, that seems to be the most common small lift. Flat springs are pretty much the norm as well, they ride better. The 1st generation Tacomas rear springs even had a negative arch, all the off-roaders were like WTF? It also allow for droop, a leaf pack with a huge arch is really only going to allow for flattening (compression), they're not going to arch much more. A flat(er) spring is going to arch both positive and negative.
    Black Wolf likes this.
  5. Apr 17, 2016 at 11:55 AM
    dirtydeeds
    Keith
    USA
    more than I can list here
    They're flat from the factory. They also angle it slightly up from front to rear. This makes it smoother as well.
  6. Apr 17, 2016 at 5:03 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Yep Tundra and Tacoma rear leaf springs are pretty much flat from the factory. Just what they do.
