Flashing lights of doom
Discussion in '2nd Gen Tundras (2007-2013)' started by sbtgrfan, Dec 26, 2022.
  1. Dec 26, 2022 at 6:43 AM
    sbtgrfan
    sbtgrfan [OP] New Member
    Stephen
    Chattanooga, TN
    2023 SR5 TRD Sport 4x4 CrewMax Midnight Black Metallic
    Good morning,
    As I was driving on the interstate on Friday after about a 4 hour drive, I randomly had lights come on. My CEL is on, VSC light on, traction control flashing and 4lo flashing. Years ago I had this issue but it went into limp mode. I replaced the SAIP. This time, same lights but no limp mode. Is this the SAIP again or something else? The only error code I get is P0101- Mass or volume air flow sensor A circuit range/performance. If it’s the SAIP I’m just going to get the bypass kit but wanted to make sure it is in fact the SAIP.
    Thanks!
  2. Dec 27, 2022 at 10:56 PM
    Dank
    Dank New Member
    2010 Black Tundra 4wd
    Do not know if this will help. Had problems going into and out of 4lo and 4high. Same lights would flash as yours. Took it to my mechanic and he did a realignment on the 4wd stability control. Never knew there was such a thing. No problems since!
