Flasher relay: install 2019 relay in 2017 for 3 blink lane change
Discussion in '2.5 Gen Tundras (2014-2021)' started by yosh2000, Feb 5, 2021.
  1. Feb 5, 2021 at 11:10 PM
    yosh2000
    yosh2000 [OP] New Member
    Denver
    '17 MGM CM Tundra
    I have a 2017, work field truck is a 2019 or 2020. Work truck has 3 blink lane change flasher relay.
    Anyone know if I can swap the relays to get 3 blink lane change in my 2017?!
  2. Feb 5, 2021 at 11:17 PM
    619Tundra
    619Tundra New Member
    San Diego, Caifornia
    2017 Black Tundra Double Cab SR5
    What is 3 blink lane change?
    TTund16 likes this.
  3. Feb 5, 2021 at 11:24 PM
    yosh2000
    Denver
    '17 MGM CM Tundra
    tap flasher stalk and it blinks 3 times for lane change. seems all vehicles, but tundras and some other toyota vehicles, have had this feature for the last 10 years!! but thats why we love our tundras!!
    Mountun Goat and Tundyfundy like this.
  4. Feb 6, 2021 at 4:34 AM
    biebs96
    PA
    Following.
  5. Feb 6, 2021 at 4:46 AM
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    Ooo I would like this upgrade on my 2nd gen if possible too. :popcorn:
  6. Feb 6, 2021 at 4:48 AM
    You can adjust that with Techstream or the dealership can change that for you.
  7. Feb 6, 2021 at 8:37 AM
    yosh2000
    Denver
    '17 MGM CM Tundra
    You can change flasher relay hardware with software? That doesn't sound right?
    Have you done that?
  8. Feb 6, 2021 at 8:44 AM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    99% sure it’s in the ECU, not the relay.
  9. Feb 6, 2021 at 8:46 AM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    I don't think the relay has anything to do with the number of times the signal flashes. As @Jim LE 1301 and @RainMan_PNW said, there are ECU/software settings that can be used to change it. You'd need the stalk that has the two signal positions (bump for lane change, click for turn) and the compatible ECU.
    Mountun Goat likes this.
  10. Feb 6, 2021 at 8:56 AM
    RainMan_PNW
    Casey
    Clark County, WA
    I don’t have time ATM, but you could start with the wiring diagrams (hit the link in my signature) to compare the turn signal circuits in the two years.
    from there, you’d need to start researching part numbers for the various components...I don’t know that the stalk itself really is any different, but for sure the ECU because the number of blinks is a setting you can change in techstream
  11. Feb 6, 2021 at 10:46 AM
    I have not, mine does it 3 times. If you do a search you will see others have done what I posted.
  12. Feb 6, 2021 at 11:14 AM
    tttrdpro
    tttrdpro Former Naval Person
    SWGA
    2024 GMC 2500 AT4
    In progress…
    You can also change this with Carista, I changed mine.
    yosh2000[OP] likes this.
  13. Feb 6, 2021 at 1:46 PM
    yosh2000
    Denver
    '17 MGM CM Tundra
    Great, thanks. I guess I didn't use the correct search terms or some thjng. I try to search again.
  14. Feb 6, 2021 at 1:50 PM
    RainMan_PNW
    Casey
    Clark County, WA
    It will only work on 2018 and newer... they changed that when they added in all the TSS stuff.
  15. Feb 6, 2021 at 3:21 PM
    Nick T
    Nick T New Member
    Nick
  16. Feb 6, 2021 at 4:05 PM
    Kung
    KG, VA
    Same. I changed mine to 7 blinks.
  17. Feb 6, 2021 at 5:18 PM
    yosh2000
    Denver
    '17 MGM CM Tundra
    Gotcha. That's why I thought it would be a flasher relay itself. Didn't realize something like that would be in the ecu? Thanks.
  18. Feb 6, 2021 at 5:20 PM
    yosh2000
    Denver
    '17 MGM CM Tundra
  19. Feb 6, 2021 at 5:26 PM
    :hattip:
    RainMan_PNW likes this.
  20. Feb 6, 2021 at 7:09 PM
    PeakIT
    PeakIT Old Member
    Utah
    2019 OR Tundra Double cab
    Coachbuilder 3” shackles, King extended travel, SPC upper arms, 5:29 gears, FN FX rims,35"tires, leer shell, grill
    I changed my 19 to blink 4 times with Carista software app and the OBD2 wireless adapter. Tech stream can do it .
    also turned off my trucks annoying seatbelt chime
  21. Feb 6, 2021 at 7:17 PM
    yosh2000
    Denver
    '17 MGM CM Tundra
    2017 here.
    Glad I don't have all the TSS stuff, but want 3 blink flash!!
  22. Feb 6, 2021 at 8:37 PM
    fatbastard79
    fatbastard79 New Member
    Huntsville, Alabama
    2017 Tundra Limited 4x4
    Soon...
    Is there a way to do this on a 2017? My 2015 Camry has this and I hate not having it
  23. Feb 6, 2021 at 8:53 PM
    RainMan_PNW
    Casey
    Clark County, WA
    OK - here is the 2016-2017 EWD and the 2018-2021 EWD for the Turn Signal and Hazard Light circuits. I have NOT gone over these with a fine-toothed comb, but in a quick 60-second comparison, I'm seeing two major differences:
    1. The 2016-2017 has a different turn signal switch than the 2018-2021. The newer one contains an additional circuit (CR) - not sure what that circuit is.
    2. The 2016-2017 uses a dedicated flasher relay, which then sends the actual turn signals out to the individual lights and to the signals in the "combination meter" (gage cluster). The 2018-2021 does not have a dedicated flasher relay, and instead this is integrated into the "combination meter" which is also the guts behind a whole pile of other systems and circuits.
    This tells me you would need at least to switch out the signal switch wand and the combination meter...and then start re-routing wiring based on sending wires from the flasher relay to the combo meter instead...and then start troubleshooting errors you get for other circuits integrated into the gage cluster that it might be expecting to see and is not seeing.
    yosh2000[OP], Scud and TRDFerguson like this.
  24. Feb 7, 2021 at 4:34 PM
    yosh2000
    Denver
    '17 MGM CM Tundra
    Yeah, not gonna happen!! Thanks for those file and info, I appreciate it!
  25. Feb 8, 2021 at 7:46 AM
    fatbastard79
    Huntsville, Alabama
    Soon...
    Yeah, that's way more work than I'm willing to do for that. Guess I'll have to get used to doing it manually...
