Flares for Tundra that look like the Tacoma TRD Off-Road flares
Discussion in '2.5 Gen Tundras (2014-2021)' started by Terndrerrr, Nov 5, 2020.
  1. Nov 5, 2020 at 10:48 AM
    Terndrerrr
    Terndrerrr [OP] 924000 miles to go
    Music City
    6UR-FE
    Does a version of this exist for the Tundra?
  2. Nov 5, 2020 at 10:58 AM
    18" TRD Off Road Wheels
    Looks like the Bushwacker smooth ones to me.
    Generally speaking, if it's a "stock" Toyota fender flare then it's Bushwacker.
  3. Nov 5, 2020 at 11:01 AM
  4. Nov 5, 2020 at 11:30 AM
    Terndrerrr
    Music City
    6UR-FE
    Thanks! It seems like for what I want to do suspension-wise, I’m going to need new UCAs, which means I’ll need spacers or aftermarket wheels that stick out, and I’ll probably have to remove mud flaps
    GODZILLA likes this.
  5. Nov 6, 2020 at 7:59 AM
    PeakIT
    PeakIT Old Member
    Utah
    2019 OR Tundra Double cab
    Coachbuilder 3” shackles, King extended travel, SPC upper arms, 5:29 gears, FN FX rims,35"tires, leer shell, grill
    The only issue with these is they sometimes rub thru the paint, but even factory mudflaps do that
  6. Nov 6, 2020 at 8:00 AM
    I've heard tell of those issues. Most just recommend using some PPF under the flare.
  7. Nov 6, 2020 at 11:57 AM
    cquilichini
    cquilichini New Member
    Bushwackers OEM Look
  8. Nov 7, 2020 at 2:22 PM
    Mxvet90
    Mxvet90 New Member
    Bushwhacker oem style flares. I think Toyota markets these as oem. Look at Sparks Parts, they even do color matching for certain colors.
  9. Nov 7, 2020 at 3:00 PM
    cquilichini
    Here a pic of mine with the Bushwackers oem style
    Tundra1078, InsaneAuto86 and GODZILLA like this.
  10. Nov 7, 2020 at 3:16 PM
    Mxvet90
    Mxvet90 New Member
    I think they complete the look of the Tundra
    junior, MillMatter and cquilichini like this.
  11. Nov 7, 2020 at 9:27 PM
    70 FJ40
    70 FJ40 New Member
    Max
    '16 Tundra SR5 TRD 4X4 Double Cab
  12. Nov 8, 2020 at 4:34 AM
    Hvactech24
    Hvactech24 MGM
    Kentucky
    2013 Rock warrior double cab
    2-1/2” front leveling kit, spider trex wheel spacers, line-x bed liner, change all lights over to led bulbs interior, exterior, and headlights. All bulbs are from headlight revolutions, RCI skid plates. RCI running boards
    EZ Flares – The Original Universal Flexible Foam Rubber 1-Inch Fender Flares
    by EZ Lip
    Learn more: https://www.amazon.com/dp/B071G6FGM6/ref=cm_sw_em_r_mt_dp_ys-PFbQTFK3YQ?_encoding=UTF8&psc=1 I installed these a few years ago and really like them. Have had no problems with them and they come in different sizes. I went with the 1.5” but the package shows 1” on them Just giving you guys another idea without speeding $400.00 or more for a good look. Make sure to order 2 packs that will be enough to do both sides. I did take go up under the inside of the plastic inner fender well so you had to remove all the plastic clips that way it sticks good to the metal and then the inner fender well those back over top of it and the clips go back through it and They will never come back off.
  13. Nov 10, 2020 at 11:57 AM
    dgmtld
    dgmtld New Member
    Saskatchewan, Canada
    2019 Tundra Crewmax SR5 Off Road Cement
    Just had Bushwacker flares painted to match and installed. They were black out of the box. They were the smallest ones I could find as I like a sleek look. I like the EZ Flares posted by Hvactech24 too.
    coexplorer and GODZILLA like this.
  14. Nov 10, 2020 at 3:42 PM
    coexplorer
    coexplorer New Member
    Graham
    Those looks really good. When they showed up were they flat or glossy black? How much further do they stick out?
    I would need to get some other black pieces over all the damn chrome on my limited.
  15. Nov 11, 2020 at 9:42 AM
    dgmtld
    dgmtld New Member
    coexplorer likes this.
  16. Nov 11, 2020 at 10:46 AM
    Baja Fundra
    Baja Fundra New Member
    2020 Quicksand Tundra TRD Offroad
    those look really good, I always liked the flares on the Tacoma and wondered why Toyota didn't put similar ones on the Tundra
  17. Nov 11, 2020 at 12:39 PM
    Zeke82
    Zeke82 New Member
    2018 white dc 8' bed tundra
    I run these same flares. The fitment is ok but the gasket that comes with them for the edges sucks. I hade to modify the bracket on the front flares to work on my 2018. Gonna change out the gasket at some point. For the $ they're ok.
  18. Nov 11, 2020 at 12:43 PM
    coexplorer
    Graham
  19. Nov 11, 2020 at 12:54 PM
    Marcstryd
    Marcstryd New Member
    Marc
    2016 White Platinum Tundra
    TRD pro suspension TRD pro exhaust
    These are OEM flares
    TrucksRCool likes this.
  20. Nov 11, 2020 at 4:59 PM
    70 FJ40
    70 FJ40 New Member
    Max
    Thanks for the info. Is the gasket a piece that goes between the flare and the fender? What are you thinking you'll use as a replacement gasket?
    I'd really like to find something that fits well and is good quality that is small. Just don't care for the ones that stick way out. These trucks are wide enough as it is. It would be nice if bushwacker had some small ones.
  21. Nov 11, 2020 at 5:53 PM
    Zeke82
    Zeke82 New Member
    Yeah the gasket between flare and fender. I ordered some flare gasket on Amazon. Just search for fender flare gasket on Amazon. There is a few options for new gasket.
