Fixing up a T100
Discussion in 'Other Toyota Vehicles' started by kenomouth64, Oct 5, 2017.
  1. Oct 5, 2017 at 1:54 PM
    kenomouth64
    kenomouth64 [OP] New Member
    Tetrus
    2007 Toyota Tundra Sr5 4x4 (TRD Off Road) Crewmax 5.7L
    Hold the Line! If you are not holding the line, abandon your ship. Destruction is inevitable without more to hold the line!
    I purchased a 1998 Toyota T100 at a really good price yesterday. When I bought it I knew that it would need some TLC. I bought it as a daily driver so that I stop putting so many miles on the Tundra.
    However one of the major issues I have found SO FAR is there is a MAJOR rear differential fluid leak. I know where it is coming from, I just don't know the name of the seal. It is leaking at the point where the driveshaft enters into the rear differential.
    Would that just be a called a "Rear differential Input shaft seal"? If not what is it called so I can order the part from Toyota?
    Also it looks pretty straightforward to change out, are there any surprises I should expect?
  2. Oct 5, 2017 at 1:58 PM
    kenomouth64
    Tetrus
    It looks like it has been going on for a while. Haha!
    The guy said it seeps a little from the rear differential. In either case i still got a good deal...
  3. Oct 5, 2017 at 2:31 PM
    kenomouth64
    Tetrus
    Rear differential pinion seal?
  4. Oct 5, 2017 at 5:23 PM
    kenomouth64
    Tetrus
    @ColoradoTJ
    Would this be a Pinion seal most likely?
  5. Oct 5, 2017 at 5:54 PM
    Pinion seal. It is like 11-20.00 depending where you get it.
    Lube it up good and use a seal install tool so you don't tear it or install it crooked. You can rent them for free at your local parts store.
  6. Oct 5, 2017 at 6:27 PM
    kenomouth64
    Tetrus
    Perfect, that is great information, I would not have used the tool (or even have known it existed) if you did not mention it. Thanks
  7. Oct 5, 2017 at 7:19 PM
    Lets see T100 how many miles?
  8. Oct 5, 2017 at 7:45 PM
    kenomouth64
    Tetrus
    It has 221,000 Miles. I will post some pictures up after it is cleaned. :)
  9. Oct 5, 2017 at 8:04 PM
    Baja Mike
    Baja Mike Baja Aficionado
    South Bay, Ca.
    2016 Tundra TRD 4x4 SR5 white
    LED interior lights, Baja Designs foglights, Baja Designs S8 hood bulge light bar, LED bed lights, Baja Designs S8 amber bar in bumper on Rago Fab mounts, AMP Research bedstep, Switch Pros sp-9100, tinted door windows
    You're gonna need a pressure washer and a priest to clean up under there.
    Thee_Oddball and kenomouth64[OP] like this.
  10. Oct 5, 2017 at 9:14 PM
    kenomouth64
    Tetrus
    Right! I could not tell it was that bad when I was looking at it because the rain was poring down and it was in the parking lot of a concrete manufacturer. Luckily I consider it a relatively small issue, as long as they have never drove it extremely low on differential fluid, if they have that rear end might go out, still a relatively cheap fix.
    I already bought several cans of engine degreaser and laid out my 'old clothes' for the job. I figure i will power wash it first to make the job easier/cleaner. The transfer case might be leaking as well... Looks like I am going to have a busy weekend.
    No hunting for me!
  11. Apr 5, 2018 at 2:09 PM
    RPusers5567
    RPusers5567 New Member
    I found this forum because i'm restoring(to some degree) my 1997 T100. It may be this part right here...
    Part No.90311-44006 SEAL, OIL
    (FOR REAR DIFFERENTIAL CARRIER)
    Replaced By 90311-44007 Manufacturer Toyota. This genuine Toyota part is guaranteed by Toyota's factory warranty.
