[FIXED] 2008 Tundra CM 4x4 5.7L - Engine Code P0102
Discussion in '2nd Gen Tundras (2007-2013)' started by xunil76, May 4, 2021.
  1. May 4, 2021 at 4:21 PM
    xunil76
    xunil76 [OP] New Member
    TX
    2008 Toyota Tundra Crewmax Limited 4x4
    So yesterday i was driving home from the store, and as i was accelerating from a red light, all of a sudden the throttle cut out on me, felt almost like the brakes had been applied. after a second or two, it did let me continue to drive, although the idle was rough and the truck lacked power. there was a CEL on the dash as well with the VSC light on also. i had driven about 10 mins to the store, idled for another 10 mins or so at an ATM machine, and it was only after leaving the ATM and taking off from the red light that this occurred, so it had plenty of time to warm up.
    When I scanned the code, it was P0102 - Mass or Volume Air Flow Circuit low Input
    I've already checked to make sure there are no air leaks anywhere from the air box to the throttle body.
    I've pulled the MAF out (carefully) and cleaned it really good with some CRC MAF cleaner (i did not physically touch any of the wires with anything other than the spray from the MAF cleaner)
    I've cleaned the throttle body really good with some TB cleaner and a shop rag to get all the buildup off (there wasn't much).
    There are no vacuum leaks on any of the hoses on the top of the engine.
    There are no cut/frayed/corroded wires on the wiring harness that plugs into the MAF.
    so ruling all of that out, these are the other options that i was able to find as possible causes:
    faulty MAF sensor
    faulty PCM
    faulty MAP sensor
    clogged catalytic converter
    faulty air injection pump
    Truck has 133k miles on it.
    anyone know of a way to narrow down the issue a little more, preferably inexpensively?
    I don't know of anyone with a 5.7L Toyota engine who is willing to let me try out their MAF or MAP sensors to see if that's the cause.
  2. May 4, 2021 at 4:30 PM
    jdg1982
    jdg1982 New Member
    Florence, Colorado (From Louisiana)
    2017 Magnetic Gray Tundra SR5 4x4
    My check engine light came on when I "I've pulled the MAF out (carefully) and cleaned it really good with some CRC MAF cleaner (i did not physically touch any of the wires with anything other than the spray from the MAF cleaner)" I disconnected the negative on the battery. It came back on, but I just drove it for a couple days and the light went off.
    I think it's because the MAF thinks there's a foreign object or substance on the MAF.
    I'm not a mechanic in any way though.
  3. May 4, 2021 at 4:53 PM
    audiowize
    audiowize New Member
    Paul B.
    2008 Tundra SR-5 4x4 5.7
    Borrow a scan tool that has live data and let us know what the MAF is reporting at idle. If the scan tool can log data, try slowly revving up the engine and see what the MAF data does. It should also slowly increase.
    How are your short term and long term fuel trims?
  4. May 4, 2021 at 5:21 PM
    xunil76
    TX
    I have the Torque Pro app that connects thru bluetooth to an OBD-II module, readings at idle are in the attached screenshot.
    STFT1 = Short Term Fuel Trim, Bank 1
    LTFT1 = Long Term Fuel Trim, Bank 1
    STFT2 = Short Term Fuel Trim, Bank 2
    LTFT2 = Long Term Fuel Trim, Bank 2
    The MAF reading does not change at all when I rev the engine. LTFT2 changes from -0.78 to just plain 0, all the other fuel trims stay the same.
  5. May 4, 2021 at 5:25 PM
    audiowize
    Paul B.
    If the MAF is giving you a reading but not changing when you rev up the motor, I would go ahead and swap it out for a new (OE) one.
    xunil76[OP] likes this.
  6. May 4, 2021 at 8:13 PM
    xunil76
    TX
    good call, replaced the MAF sensor and all is well....thx for the assist
