fitting wide wheels on tundra
Discussion in '2.5 Gen Tundras (2014-2021)' started by inklou, Oct 20, 2022.
  1. Oct 20, 2022 at 8:12 AM
    inklou
    inklou [OP] New Member
    2015 Toyota Tundra
    stock
    Hello so I recently bought a 2015 Toyota Tundra sr5 trd off road and I'm looking to buy new tires and I would like for them to stick out from the wheel well and still be on stock height anybody have anything similar or is this even possible?
  2. Oct 20, 2022 at 9:11 AM
    Welcome aboard sir! There is a thread with pics of wheel tire setups that probably has what you are looking for. Short answer is yes, but so many variables to each setup.
  3. Oct 20, 2022 at 9:13 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    stock wheel offset is +60, you can run wheel spacers on the stock wheels, 1.5 inch spacer to kick the tires out. Or, if you get new rims, something in the +18 to +25 offset will stick the rims/tires out about 1.5 inches. Either one should not be much of an issue to fit with stock tires.
    Lots of info on setups and pics here https://www.tundras.com/forums/wheels-tires.18/ and make sure to check out the stickies at the top.
  4. Oct 20, 2022 at 9:14 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Welcome from TX!
    Search is your friend.
  5. Oct 20, 2022 at 9:18 AM
    Tundra'25
    Tundra'25 Well-Known Member
    Wincent
    Southern California
    Welcome to the forum, from SoCal
    I'm sure it's possible, but you're going to need to need to do some cutting and hacking. It greatly depends on how much negative offset, or 'poke', you desire
    More wide = more cutting
  6. Oct 20, 2022 at 11:19 AM
    RedGreen
    RedGreen New Member
    2018 SR5 4x4 DC LB
    Out of curiosity, why do you want stickout? Is this just a looks thing or does it serve some functional purpose?
