Fitting an oversized tire in the stock location
Discussion in 'Wheels & Tires' started by gosolo, Dec 22, 2017.
  1. Dec 22, 2017 at 7:47 PM
    gosolo
    gosolo [OP] You Don’t Know Who I Am But I Know Where You Live
    Ray (or maybe Dale)
    NW Oregon
    My new tires are a little bigger than stock at 33.5” and the spare sits really close to the shackles.
    I know several of you have done this and said you tweaked the steel guides that locate the spare between the springs. My question is, how did you bend those guides without heating them or damage to anything else?
  2. Dec 22, 2017 at 8:12 PM
    thetwood
    thetwood New Member
    Louisville, CO
    2017 Blazing Blue Limited CrewMax TRD
    Kings, SPC, Icon Six Speed, Falken Wildpeak AT3w
    I just removed the guides altogether, though I was fitting a 35" tire. Drilled out the bolts (rivets, whatever) using progressively larger drill bits, then used a cold chisel to finish them off. Guides dropped right off. Bit of paint and it was all good.
    Watt maker and Prostar 190 like this.
  3. Dec 22, 2017 at 8:28 PM
    Bannock452
    Bannock452 New Member
    Brandon
    Murrieta, CA
    2016 White Crewmax 4x4 SR5
    King coilovers 35x12.50-18
    Sub’d as this is on my list to get done pretty soon here. Post up some pix when you can.
    I plan to try and find some type of 35” thin tire (35x10.5) instead of a full size 35x12.5 tire but not sure if that is possible so I will keep doing some research.
    gosolo[OP] and Prostar 190 like this.
  4. Dec 22, 2017 at 8:33 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    My 34.5” is squished in there without altering the guide. You should be able to get a 33.5” in there. I’m still going to cut that guide off. Don’t like how it leaves a mark on my tire. Maybe tomorrow.
  5. Dec 22, 2017 at 11:05 PM
    computeruser6
    computeruser6 Gott Mit Uns
    Dirk
    Escondido
    2008 Regular Cab Tundra
    A plasma torch works well to cut the guides out. The only 35x10.5" tire that I've seen are Super Swamper Radials.
  6. Dec 23, 2017 at 3:58 AM
    I have been thinking about do the same thing I run 35/12.5 on mine.
  7. Dec 23, 2017 at 4:46 AM
    boardude
    boardude I am Batman
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    I just cut the guides off with an angle grinder. I was able to stuff an STT Pro tire under there (~35.1") with +2 CB shackles. I have to kinda kick the tire foward towards the diff while raising it in place for it to fit and clear everything. It's tight but it works... for now lol
    bmw345, grave, equin and 4 others like this.
  8. Dec 23, 2017 at 6:19 AM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    I did get it installed but it’s so close to the shackle on the driver side, I believe it will rub when off-road. I’m gonna leave it for now and will take the truck out this weekend and see how it does. If there’s room to cut the rivets with a peanut grinder that is the way I will go (if I need to).
    I’m sure glad to have a spare rim that matches.
    Prostar 190 likes this.
  9. Dec 23, 2017 at 6:29 AM
    Probably could use an air hammer to remove the rivets.
  10. Dec 23, 2017 at 6:48 AM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    My ears hurt just thinking about that! lol
    I’ve got good ear muffs though...
  11. Dec 23, 2017 at 6:53 AM
    I know what you are saying just thought if you had a good one they go through a rivet like butter and work great in tight places.
    gosolo[QUOTED][OP] likes this.
  12. Dec 23, 2017 at 7:08 AM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Yeah, truly said. I’m just sure that confined area with all the sheet metal around will be like an echo chamber. Putting a metal bucket over my head and hitting it with a hammer, like
    Ketchumj and Prostar 190 like this.
  13. Dec 23, 2017 at 7:09 AM
    :rofl:for sure.
  14. Dec 23, 2017 at 7:15 AM
    thetwood
    thetwood New Member
    Louisville, CO
    Here's what I did. Dropped the stock spare, then used my cordless drill and a chisel.
    Started with about a 1/8th bit to just get it started, then through the rivet to the frame with a 1/4", then 3/8" and finally 1/2". Could have progressed faster, but each wasn't that hard since it was just taking a bit more out. Two of the four the 1/2" bit took the rivet head off clean. Two I wasn't on center and so just used a metal chisel and hammer (and good ear protection) to finish it.
    Left the top of the rivet in place and touched up with black rustoleum paint. For my 35" tire, I had to push it forward about 1" to get everything to fit the way I wanted. Will turn the bolts on my Toytec shackles around at some point when it's warm again to provide more room, but it's all good for normal driving. Figure if I'm doing anything hard-core I'll drop the spare and put in the bed.
    AggiePhil, equin, TheBeast and 6 others like this.
  15. Dec 23, 2017 at 7:24 AM
    This is something I need to do. I'll also have to reverse my ToyTec shackle bolts too.
  16. Dec 23, 2017 at 8:32 AM
    So a 35*12.50*20 can fit???
  17. Dec 23, 2017 at 9:11 AM
    thetwood
    thetwood New Member
    Louisville, CO
    Yep, with a little work. It's tight, but looks fine once it's done.
  18. Dec 23, 2017 at 9:15 AM
    Fixing to buy same size spare and a steel wheel
  19. Dec 23, 2017 at 9:22 AM
    I am planning on putting a 35 under there also a 35 in a CrewMax bad takes up a lot of space. Lol
  20. Dec 23, 2017 at 9:39 AM
    jc153
    jc153 Speed-ish Glamper
    San Diego
    2009 Tundra Ltd CM 4x4
    TC Front Long Travel, ADV Glass Fenders & Bedsides, TC Spindle Gussets & King LT Coilovers, RCV Axles, DuroBumps, CB Steering & Carrier Bearing Drop Kit, SDHQ ABS Sensor Shields, Rear 3.0 ADS Triple Bypasses w/MCM Fab Under Bed Shock Mount Relocation, SUA Deaver I96HD Springs & TC Shackles, MCM Fab Rear Hydro Bumpstop Kit, Solid Offroad Engine Mounts, 17" Method Standards, 37/12.5/17 Toyo RT's, Nitro 488 Gears w/Auburn LSD, Evil Off Road Bumpers, RCI Skid Plates, White Knuckle Sliders, Dirty Deeds Ind. BAMuffler 8" Catback, Baja Designs Lighting, SwitchPros Controller, Custom PS Cooler Relocation Kit, Custom Dual Battery Setup
    I put my spare 35” Toyo RT in the stock location. It took some work but I got it done. First I had to remove my wide +1 CB shackles and go with some TC shackles. Then I pounded the stock locating ears flat and moved my BA exhaust helmholtz resonator forward and up. The spare clears everything now.6F1ACDC6-234F-4992-A472-42D415E8954C.jpgE5330357-C65F-4AD8-BF51-11923458A1EF.jpg8F401BF4-5766-4536-8AA7-082F9F3DEAFC.jpg
    AggiePhil, equin, TheBeast and 5 others like this.
  21. Feb 13, 2020 at 3:25 PM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    Took it to Custom Offroad Equipment here in OKC. They air-hammered the alignment tabs off and sprayed it for free. Great group of guys over there for anyone in the area.
  22. Feb 13, 2020 at 3:48 PM
    SprinterAE86
    SprinterAE86 New Member
    Ian
    Charlottetown, PE, Canada
    2012 Toyota Sequoia Platinum
    My wheel have a paint chipping off. It's under warranty and I might see if they can sell it to me for a discounted/blemish rate and use it as a spare. I'm thinking on putting 295.70.18's 33.75 to match the rest. Hopefully it will fit with no cutting or modding.
