Fitment Issues
Discussion in 'Wheels & Tires' started by gschenk22, Feb 5, 2023.
  1. Feb 5, 2023 at 9:35 PM
    gschenk22
    gschenk22 [OP] New Member
    2008 Double Cab
    Leveling kit, 35x12.50 Toyo Open Country R/T Trail
    Hello all,
    Currently running a set of 35x12.50 tires on my 08 with stock wheels and a leveling kit. The only issue I'm running into is at just about full lock the tire rubs the sway bar. Not wanting to have to buy new wheels I'm looking to get some spacers. What is the biggest spacer I can run on the stock wheels without having to do a BMC?
    Thanks!
  2. Feb 5, 2023 at 11:04 PM
    Junior 88
    Junior 88 New Member
    Junior
    18 tundra Sr5
    7inch bds on 35s
    Just remove the sway bar.
    gschenk22[OP] and Cue_32 like this.
  3. Feb 6, 2023 at 7:10 PM
    Chad D.
    Chad D. New Member
    Western Oregon
    2018 CrewMax Platinum
    Rubs the sway bar how much? Just a teeny bit, or a lot?
  4. Feb 12, 2023 at 9:30 PM
    gschenk22
    2008 Double Cab
    a pretty good amount once I turn it hard enough
  5. Feb 12, 2023 at 10:06 PM
    Chad D.
    Chad D. New Member
    Western Oregon
    Whelp, OEM wheels are +60mm offset. Seems like the general consensus is that the “perfect” offset for our trucks is in the +25 to +35 range. I’d looks for a spacer in the 1.25” range if rubbing that much. That’ll be equivalent to a +28mm wheel when you’re done.
  6. Feb 19, 2023 at 4:38 PM
    gschenk22
    2008 Double Cab
    Perfect thank you!
