Fitment issue with Truxedo Pro X15
Discussion in 'Tonneau Covers, Caps and Shells' started by blair_b1, Aug 2, 2020.
  1. Aug 2, 2020 at 5:50 PM
    blair_b1
    blair_b1 [OP] New Member
    Blair
    2014 Grey Tundra 4.6
    Picked up one of these yesterday and installed it while out at the camper. Front seal and rails went on no problem. Putting the roll onto the bulkhead didn't go over well - had to push out the rails to snap the locks into place. Rolled it out to close and the length seemed too long as per pic 1. Have to force the first side snug than push out to be able to close the end and snap shut. Does close but annoying to do. Tailgate is not flush after shutting - possibly just to seal. Anyone have issues like this?
  2. Aug 25, 2020 at 2:20 PM
    sotex
    sotex Sic 'em Bears!
    Jeff
    San Antonio, TX
    2020 White Tundra SR5 Double Cab 4x2 SX
    Where did you buy it? I wonder if they could help. I'm shopping for one myself.
  3. Aug 25, 2020 at 2:23 PM
    Doctor Flex
    Doctor Flex Just browsing...
    Utah
    2020 White 1794 TRD
    TRD Pro skid, Line-X, Tonneau, drivers grab handle, wireless charger, RB 20's, TRD Pro wheels, Gator Liners.
    A few more pics might be helpful of the cab portion of the bed. I have the cheaper version and had it also on a few Tacomas, and they took a bit to perfectly adjust the spacing and angles of the side rails. The Tundra one doesn't fit quite as good (more gaps) but a litle extra foam weather seal fixed it right up. I wonder if it is just tightened down a touch skeewompus.
  4. Aug 25, 2020 at 2:28 PM
    RitcheyRch
    RitcheyRch New Member
    Richard
    Santa Clarita, CA
    TRD Lowered and Supercharged
    Could it be the incorrect cover?
  5. Aug 25, 2020 at 2:29 PM
    Doctor Flex
    Utah
    2020 White 1794 TRD
    That's true too. Maybe wrong MY or bed size?
  6. Aug 25, 2020 at 2:32 PM
    sotex
    Jeff
    San Antonio, TX
    Overall I prefer the look of that fabric compared to other soft tonneaus. However, there seem to be some good alternatives for quite a bit less (Access Vanish, Tyger T1, and Gator ETX).
    blair_b1[OP] likes this.
  7. Aug 25, 2020 at 2:44 PM
    Tosa
    Tosa New Member
    2014 Platinum Crewmax
    I had similar issues. Looks like your rails could slide a little more towards the front of the truck. I also had to trim down the pad in the back to kepep pressure off the tailgate. From looking at the pic your weather seal is shut in there as well, this takes up extra space. With this cover you seem to have to shut tailgate first and then close cover in top of it. Here are some pics from mine, hope this helps. 23CC6710-116C-4D08-B136-7E4777D3A342.jpg12BAD7E7-B3F4-4E1E-9ED9-5D3EAB747903.jpg
    blair_b1[OP] and RitcheyRch like this.
  8. Aug 25, 2020 at 2:44 PM
    Doctor Flex
    Utah
    2020 White 1794 TRD
    Seems like it would be more puncture resistant too. Not sure how it compares to the vinyl covers from a weather standpoint (water permeation).
    sotex[QUOTED] likes this.
  9. Aug 25, 2020 at 3:19 PM
    NCSkeeter
    NCSkeeter New Member
    2019 Silver Tundra Crewmax 4x4 1794
    TRD Rear Sway Bar, Truxedo X15 Tonneau Cover, Toyota OEM Bed Mat
    Try closing the tailgate before latching the cover. The weatherstripping is folding under the cover rather than laying on top of the tailgate as it should.
    just realized is doesn’t seem like the rail is tightened down to the bed either. Seems to be a big gap between the top of the bed side and the rail.
  10. Aug 25, 2020 at 6:04 PM
    blair_b1
    Blair
    Ohh - the seal should flap over the top of the tailgate?
  11. Aug 25, 2020 at 6:06 PM
    blair_b1
    Blair
    I took it to where I purchased it and they mentioned some covers come with shims. They just put some rubber to bring the rails up and it helped but not 100% that I would like. Overall - I'm enjoying it more as the days go by. Such a low profile compared to the Lo Pro. Those look like trash to me now every time I see one :rofl: sorry
  12. Aug 25, 2020 at 6:09 PM
    NCSkeeter
    Think so. I recall reading that in the install info.
  13. Aug 25, 2020 at 6:16 PM
    blair_b1
    Blair
    I just went out and switched it - shut the tail gate first than snap the cover shut. I kind of liked the way I had it - it stopped the tail gate from rattling but that end of the tonneau cover was sitting a bit higher which I didn't like. I bought the tail gate seal so maybe I'll put that on and hopefully doesn't rattle.
  14. Aug 25, 2020 at 6:19 PM
    blair_b1
    Blair
    I did take it in to where I purchased it and they shimmed it up so it wasn't sagging in. I guess that was the problem? I thought I had it slid forward all the way - but maybe this weekend I should go over it again. It seems to be holding up the way it is but I'll check it out.
  15. Aug 25, 2020 at 6:22 PM
    blair_b1
    Blair
    Someone slid through the intersection where I park and hit the box and it had to be redone - I'm wondering if they just rigged the new box side on and left it out of spec. I'd have to measure mine than get measurements from a truck that hasn't been hit.
  16. Aug 26, 2020 at 2:01 PM
    DIYDad
    DIYDad New Member
    2020 Tundra 1794
    Sorry, to say - that could be your problem.
    I have the same cover, and it fits perfectly. no sags, no interference. I have the rails shifted a bit further toward the cab than you do, and I close the cover first, then the tailgate.
    No rattles, no leaks.
    Looking closer at your pics what's that aluminum colored L-shape bracket? That is not the hardware that came with mine.
  17. Aug 26, 2020 at 2:04 PM
    DIYDad
    DIYDad New Member
    2020 Tundra 1794
  18. Aug 27, 2020 at 5:54 PM
    Tosa
    Tosa New Member
    I provided pictures of my install for reference and yes you are correct ihave the rails and I added an custom made aluminum L-bracket to stiffen it up. It shuts alot easier now. It used to flex quite a bit prior to adding this bracket.
