Fitcamx for 2018- 2021 tundras
Discussion in '2.5 Gen Tundras (2014-2021)' started by Jtundra81, Mar 29, 2022.
  1. Mar 29, 2022 at 6:36 PM
    Jtundra81
    Jtundra81 [OP] Just a member
    Joe
    2019 cement tundra crewmax
    Howdy , anyone tried this camera on 2018 -2021 tundras ?
    Dash Cam for Toyota Tundra 2017 2018 2019 2020 2021, Sequoia 2017-2022 Limited SR5 SR Platinum TRD Pro, Fitcamx 4K OEM Style Car Recorder WiFi, UHD Video G-Sensor, Stealth Look, Plug & Play, 64GB Card https://www.amazon.com/dp/B09Q8WB6S6?_encoding=UTF8
    If yes , how do you like it ? Any issue with Toyota safety sense and dynamic radar cruise control ?
    Thanks
  2. Oct 30, 2022 at 7:13 AM
    Rbbfpe
    Rbbfpe New Member
    Just wondering if you ended up going with this. I am considering this one and wanted to know if there are any issues.
  3. Oct 30, 2022 at 8:49 AM
    Jtundra81
    Joe
    I ended up getting a garmin and plug and play usb to mirror to power it , I will send you links when I get home , works perfectly
    Rbbfpe[QUOTED] likes this.
  4. Oct 30, 2022 at 10:10 AM
    mustangr2
    mustangr2 New Member
    I have it. I like that it looks oem. The app is pretty basic. It doesn’t interfere with any of the oem radar and such. Only real problem was getting it snap into the oem slots but eventually got it.
  5. Oct 30, 2022 at 10:13 AM
    Jtundra81
    Joe
    Here are the links on what I have now
    Garmin Dash Cam Mini 2, 1080p,... https://www.amazon.com/dp/B09FWH6CQK?ref=ppx_pop_mob_ap_share
    And used dongar adapter to power it
    Dongar Technologies Dash Cam... https://www.amazon.com/dp/B07DMW3DML?ref=ppx_pop_mob_ap_share
    bulldog93 and Rbbfpe like this.
  6. Oct 30, 2022 at 12:59 PM
    Rbbfpe
    Rbbfpe New Member
    I have seen this and originally was going to go this route. However, I do like the OEM look of the Fitcamx. Now I'm researching a way to tap into the power that's above the center console to hide the wiring better. Seems like it should be pretty easy to do, but I want to make a plug and play harness and I'm struggling to find the connectors I need. I found half of the puzzle with this https://www.toyotapartsdeal.com/oem/toyota~housing~connector~f~90980-12370.html. Now I need the other end to make the harness. I haven't found a good part number for that, yet.
  7. Nov 17, 2022 at 8:34 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Did you use the dongar to the back of the mirror and leave the one connector empty? Don't need to mess with the headliner right?
  8. Nov 22, 2022 at 8:34 PM
    Jtundra81
    Joe
    Dongar will plug directly to mirror ,plug and play no need to do anything , you will have an available usb plug to power garmin , I can’t see it is there , I am happy I went with it
  9. Jan 2, 2023 at 5:09 PM
    French Avocado
    French Avocado Double Entundra
    Utah / Wyo
    I got this from Santa and just tried to download the App but got this message:
    anyone else have this problem?
    Is this a Chinese spyware?
  10. Jan 2, 2023 at 8:05 PM
    Avi8or
    Avi8or New Member
    Johann
    MO
    2020 Limited Crewmax
