First Tundra Radiator Replacement
Discussion in '2nd Gen Tundras (2007-2013)' started by spetznaz, Oct 4, 2019.
  1. Oct 4, 2019 at 11:23 AM
    spetznaz
    spetznaz [OP] New Member
    Hi All,
    picked up my first (2007 2nd gen) tundra. Everyhthing seems solid but the previous owner told me there was a pinhole radiator leak which i can't find...
    In any case i will be replacing the Radiator, water pump, hoses etc... just be on the safe side.
    Truck has 200k+ miles on it.
    Two questions:
    1. Any recommendations on OEM vs aftermarket radiators, if so which brand/model? I understand there are some issues with the integrated tanks on the OEMs? Is it worth to go to aftermarket Alum with alum tank to avoid this issue?
    2. What other preventive maintanance should i consider while i got the radiator out? From both convenience of access and due dilligiance point of view?
    thanks in advance...
  2. Oct 4, 2019 at 11:46 AM
    Trident
    Trident New Member
    2007 Tundra DC 4X4
    The $120 Denso from Rockauto has performed flawlessly in my 2007.
    chugs, YardBird, ColoradoTJ and 2 others like this.
  3. Oct 4, 2019 at 9:55 PM
    spetznaz
    Thanks will check out Denso
    Is there any maintenance that is easy and worth doing while the radiator is out?
  4. Oct 5, 2019 at 5:35 AM
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    Nothing else besides the drive belt and tensioner unless you want to rip into the water pump..
    edit: The drive belt and tensioner can be done without removing the radiator but would certainly be easier without it.
    ColoradoTJ likes this.
  5. Oct 5, 2019 at 10:28 AM
    Dr_Al
    Dr_Al New Member
    Al
    Might as well do the thermostat while you are there.
    15whtrd likes this.
  6. Oct 9, 2019 at 4:48 AM
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    I'd add: since you are already opening the coolant can of worms, open one of the engine drain cocks to get out as much old coolant as you can.
  7. Oct 14, 2019 at 11:12 AM
    chugs
    chugs New Member
    Ciao
    Central Cali
    2007 Tundra Blue Streaker
    Dammit in the same boat leaking rad from somewhere....?! Will check out rockauto as well....
  8. Oct 14, 2019 at 11:14 AM
    chugs
    chugs New Member
    Ciao
    Central Cali
    Location or pix of drain cocks?
  9. Oct 15, 2019 at 4:54 AM
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    There's a video on the youtubes. I did the rad and passenger side drain. Driver side drain is a bit harder to get to. Didn't want to chance stripping a brass bolt. Still used up almost 3 gallons.
  10. Oct 15, 2019 at 8:42 AM
    triharder
    triharder Sorry, Not Sorry
    Jake
    Southern, Maine
    2010 RWB Black
    Billstein 6112/5160's, coachbuilder spacer on driver side/ 20" rockstar wheels/ 33" nitto ridge grappers/SS Brake lines (or as most people write Break), Painted Calipers/Powercoated Tow hooks/pocket flairs/heated seats,bed leds/line-x liner/xtang trifold/tow mirrors/Stereo Work/Compustar Remote Starter/ retrofit Morimoto Minin H1 and switch back LEDs/ plenty I'm forgetting
