First Tundra for me.
Discussion in 'New Member Introductions' started by midmstundra2020, May 13, 2024.
  1. May 13, 2024 at 12:06 PM
    midmstundra2020
    midmstundra2020 [OP] New Member
    2020sr5
    Have to catch up on 2020s...its my first Tundra. But own other Toyotas that have been very good vehicles for me. This will be "RV" use vehicle for the family so want to learn all I can.
  2. May 13, 2024 at 12:08 PM
    OldGuy03
    Jay
    CO
    12 MGM DC RW
    Welcome from CO.
    Check out the towing threads to start.
  3. May 13, 2024 at 2:39 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
  4. May 13, 2024 at 3:48 PM
    SD Surfer
    Bruce
    So Cal
    Welcome from San Diego.
    I have a 2019 & tow a smallish travel trailer @ 5,500 lbs.
    They're towing beasts but the payload rating is pretty low, and will be your limiting factor. How big is your RV?
    My '19, your '20, no longer have the external transmission cooler like they used to. A topic of much discussion, many threads, and may or may not be an issue depending who you ask. Some are adding coolers, some monitor temps, some tow in S4 & Tow/Haul per the manual, some just put it in drive and go. Not hearing about a rash of transmission failures as of yet. Do your research and use your better judgement.
    Let's see the new to you Tundra!
  5. May 13, 2024 at 5:27 PM
    Welcome from NY.
