First Truck Looking for AfterMarket Installer
Discussion in 'Texas' started by skan, Jan 21, 2020.
  1. Jan 21, 2020 at 7:42 AM
    skan
    skan [OP] New Member
    2007 Toyota Tundra CrewMax
    275 60r20 toyo open country at3 on vision seven 20*9 +12 offset
    Purchased my first truck yesterday. Stopped by at CarToys in Plano to get a quote to install a radio (Halo9 ifxl259), backup camera (echomaster pcam-dpllp-n) and potential front camera AudioVox ACA800 with 4year complete warranty - 2200$ before taxes and Remote start with Security Clifford (DERSS9756) with installation 800$. As i am new to the truck world i asked them for their most economical recommendation and those are the numbers- are these systems so pricey to have them installed ? are these numbers considered economical in the truck world ?
    Any recommendation for local shop in DFW area that i can start going to them regularly.
  2. Jan 21, 2020 at 8:32 AM
    paradizecityz
    paradizecityz New Member
    Richmond, TX
    2022 Tundra TRD Off Road
    Is this something you want someone to install for you or do you mind doing it yourself?
  3. Jan 21, 2020 at 8:35 AM
    skan
    I am not sure how complex it is to be to do it as DIY. I have never done any DIY in a car/truck before.
  4. Jan 21, 2020 at 8:38 AM
    paradizecityz
    Richmond, TX
    Same here but I just learned as I go and it's pretty fun. I'm not confident enough to touch like suspension but electrical, I'm good with.
    Also, there's companies that sell "Plug and Play" kits so it also helps with that.
    Check out Tech12Volts section for remote starter and also audio upgrades
  5. Jan 21, 2020 at 8:47 AM
    You can DIY alarm/remote start plug and play in 30 minutes max for around $200.00......very simple install.
  6. Jan 21, 2020 at 8:52 AM
    skan
  7. Jan 21, 2020 at 9:35 AM
    gdiep
    gdiep I like cookies
    Syracuse, New York
    2014 Red Tundra CM SR5
    I installed the Fortin remote start offered by Tech12Volts a few weeks ago. It took me about 1 hour, but I was doing this in my driveway in Central NY with temps around 30, so I was being slow and careful so I wouldn't break any plastic clips on the panels in my truck. If I were in Dallas, I could probably cut about 15-20 mins off of the timeframe. Everything was easy to install and works as advertised. Costs about $200. This forum has DIY guides for installing this remote start, head units and backup cameras as well. Just do a little search. Then, you can look at the guides and see if you are handy enough to DIY.
  8. Jan 21, 2020 at 9:47 AM
    I installed the Compustar remote. The hardest thing was removing the screws on the plastic steering column.
  9. Jan 21, 2020 at 10:20 AM
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
    As others have said, the tech12volts remote start is plug and play. Not sure if he has one for a 2007 but shoot him a message and he will help you out. Also, if you were to buy your headunit off of crutchfield they offer to create the wiring harness for you making the halo plug and play as well. Then its just a matter of running the camera wires.
  10. Jan 21, 2020 at 11:37 AM
    skan
  11. Jan 21, 2020 at 11:49 AM
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    Try non caps???? But others with all the info you need will chime in.
  12. Jan 21, 2020 at 11:54 AM
    SouthWestGA
    SouthWestGA New Member
    Here is the CORRECT email address for James the resident audio/video/alarm guy on the forum
    tech12volt@gmail.com
  13. Jan 21, 2020 at 11:54 AM
    skan
    Yes, i did use non-caps
  14. Jan 21, 2020 at 11:55 AM
    Black@Blue19
    Ken
    SE Texas
    ^^^^^^^^ I knew someone could help you.
  15. Jan 21, 2020 at 11:56 AM
    SouthWestGA
    Also for less than $2,200 I’m pretty sure Tech12v can get you set up with a completely new sound system and remote start too
    james is the bomb
    if you can use a screwdriver and read directions you can DIY
