First Toyota Truck from SoCal
Discussion in 'New Member Introductions' started by RiverTundra, Sep 16, 2017.
  1. Sep 16, 2017 at 6:55 PM
    RiverTundra
    RiverTundra [OP] New Member
    A
    2017 White Tundra SR5 Double Cab
    Black grille with white hood bulge. AR901 Wheels. Nitro Grappler 2 LT265/70/r18 tires. Chrome exhaust tip. Spray in bed liner. Black side steps. K&N Filter.
    Just purchased a 2017 Toyota Tundra 5.7L SR5 Double Cab in White and three days in I love it. Had 4 miles on it and actually had to have the passenger rear tire sensor replaced already which was a bummer, but I hope that will be it. I manage a company that is heavy into Lean Manufacturing and I have studied Toyota's history and TPS extensively so it was almost natural for me to go with Toyota when my wife and I decided to upgrade from our 10 year old Nissan Pickup (what a difference). I do have 100s of questions so finding this forum was a blessing. Spent about 3 hours so far reading threads and its like drinking from a fire hose. Couple of questions that I have that I haven't found answers for.
    Q1The stock wheels that came with the truck I think are hideous. Since the truck is white I was hoping to find a matte or satin black wheel to contrast and match the step. I also plan on swapping out the grill in the near future. I've been to several shops including America's tires and a couple of local shops. Was hoping to get wheels that I could run the stock tires on for a year and thought I had it all figured out until one of the shops "educated" me. The manager explained to me that I would have to move up to a 20" wheel because the SR5 has a larger brake set up and the aftermarket wheels in the 18" range will rub on the calipers. He showed me where the stock wheel has a depression on the inside that allows the wheel to turn without rubbing. Actually made sense to me, but in reading all these forums I don't see the same concern mentioned (even on the introduction email forum link). Does anyone know if this is true? If it is true and I have to move to a 20" would love some recommendations. I was looking at an American Racing AR901 with Nitto tires (although I may need to wait a bit to bite off the $2000 it appears it will set me back). I didn't get the impression that he was just trying to upsell me because he actually recommended I wait a year or two for the stock tires to wear out. We will be using the truck for towing and also long runs out to the river so I am concerned about gas mileage (yeah I know I'm screwed), road noise and ride. Thoughts?
    Q2 - On several other threads I see that there are some backorders on black pro grills. Any recommendations on where to shop for a new grill in black?
    Q3 Does anyone have this bedrail kit or other recommendations? https://trdshop.carlocktoyotaoftupelo.com/oem-parts/toyota-bed-rails-6-5-pt27834072
    Sorry for the long post, but excited and ready to get working on it.
    TundraTss, Sunnier, blue16 and 3 others like this.
  2. Sep 16, 2017 at 7:13 PM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Welcome from Colorado.
    I have after market 18"s and no rubbing on caliper. Just make sure wheels are hubcentric.
    For PRO grills @Roman is your guy.
    I have answers for #3 sorry :(
    Roman, RiverTundra[OP] and T-Rex266 like this.
  3. Sep 16, 2017 at 7:17 PM
    Welcome from CO!
    RiverTundra[OP] likes this.
  4. Sep 16, 2017 at 7:43 PM
    duece292
    duece292 Appalachian American
    Greg
    Green Bay, WI
    Welcome from WI. You should be fine with aftermarket 18's, AR901's are a sharp rim. If you had the TRD big brake kit you'd need 20's. Not sure on the grill. Roman is the parts guru and he'd be able to help you with the cargo rails as well. There is a thread on making cargo rails out of uni-strut.
    Roman and RiverTundra[OP] like this.
  5. Sep 16, 2017 at 7:51 PM
    RiverTundra
    A
    That's good to know. I will try another shop. Based on the design of the wheel it made sense and he claimed I had an upgraded brake set up. I don't see anywhere on the paperwork where I have an upgraded system. Nothing visually indicates it to me either. Sounds like Roman is the man, so I will have to reach out to him.
    Roman and duece292[QUOTED] like this.
  6. Sep 16, 2017 at 8:06 PM
    onetohunt
    onetohunt New Member
    Marvin
    2016 Magnetic Gray Tundra TSS
    Welcome from the Show Me State!!
  7. Sep 16, 2017 at 8:10 PM
    duece292
    Greg
    Green Bay, WI
    I've only run into a rub issue one time trying to put Mickey Thompson 17's on a Tacoma but haven't had any problems with 18's on Tundras. If you have any doubts ask to have the rim prefitted on the truck. My shop does this and I would think most shops would do it as well. If for some reason a rim wouldn't work they're pretty easily returned as long as a tire hasn't been mounted. As far as I'm aware, Tundra brakes are the same across all of the trim levels and the TRD big brake kit is strictly an order only option...i could be wrong however. I'm sure others will chime in.
  8. Sep 16, 2017 at 8:34 PM
    nishibot
    nishibot Just2havnfun
    Perris, CA.
    2017 Tundra CM 4x4 TRD Off Road MGM
    Welcome from SoCal
  9. Sep 16, 2017 at 11:20 PM
    Agitated1
    Agitated1 Newish Member
    Los Angeles
    2017 Tundra Crewmax TRD 4x4 Quicksand
    TRD Pro Grill King Coilovers with compression adjuster Tint 5% Rear, 30% front and 70% windshield Husky X-Act Floor liners BA Muffler 8in standard system Truck Covers USA retractable bed cover Yakima bed rails
    Welcome from So Cal (Eagle Rock)!
    @Roman is where I got my Pro Grill from but you might want to call Toyota Glendale and speak to Nathan. He's a pretty cool guy with good prices as well. The last I heard he had some Pro grills in stock.
  10. Sep 17, 2017 at 9:07 AM
    porkitt
    porkitt New Member
    Ian
    Tundra Pro Cement
    DAP Tune ESP Storage RCI Skids Icon Rebound ABS Guards AVS Vent Visor FRAC Harness 50 Cal/Antenna X BFG KO2 HID Extra Light Bar White Knuckle Off Road Sliders BAK Industries Revolver X2 Oh Shit Handles Pop and Lock LED Internal and Reverse Lights LED Footwell lights Tuffy Storage Console organizers Viper Alarm and Remote Start
    Another welcome from SoCal
  11. Sep 17, 2017 at 9:44 AM
    Marty McFly
    Morty McBoonJug
    And another welcome from SoCal :hattip:
  12. Sep 17, 2017 at 9:52 AM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Welcome from So Cal also.
  13. Sep 17, 2017 at 1:17 PM
    Welcome from Texas! For Q#2 check your local Craigslist OfferUp 5mile n letgo areas that's how i found my TRD Pro grille and Amp research bed step and weathertech floor mats if your looking to colormatch front n rear bumper end caps u can vinyl em or plastidip em unless u like chrome
  14. Sep 17, 2017 at 1:50 PM
    Sunnier
    Sunny
    San Diego, CA
    Hi, Neighbor! I agree with you about your stock wheels; anything you do will make your new truck even better. I'm pretty new here myself, so no better recommendations than these ^ above. I have totally changed my mind, though, about buying a PRO grill straightaway; lotta people here doing plastidips that turn out great, can be "undone" if you change your mind or, in my case, allow you to buy other stuff first.
  15. Sep 17, 2017 at 2:48 PM
    CM-LENNY
    CM-LENNY No Complaints
    San Diego, CA
    2015 4x4 CrewMax SR5
    PRO shocks, 37's Nitto G2's 4:88 diffs, few other mods
    Welcome from San Diego. I see no issues with you running any 18" aftermarket wheel. A few companies make 17's that fit our calipers. I would hit up another shop for another opinion. Keep in mind if keeping the stock tires for a year or two, try to find a wheel that is similar width and offset as your steel wheel so the tire wheel combo doesn't look to funky. Good luck with all and enjoy that new river truck......:thumbsup:
  16. Sep 17, 2017 at 5:43 PM
    Gibzki
    Gibzki New Member
    14 White Tundra DC TRD 4X4
    Bakflip Tonneau Cover Fibermax Amp Power Step Moto Metal M0961 Pro Comp Xtreme M2 295/55R20 2 8" Rockford Fosgate Punch Alpine MRP-M500 Mono Power Amplifier LED headlight, foglight, reverse light, license plate light, cargo light, map light, dome light, vanity and footwell Magnaflow 15304 with black tip
    And another welcome from SoCal!
  17. Sep 17, 2017 at 5:48 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Welcome bud. 17's have problems fitting but not 18's.
  18. Sep 17, 2017 at 5:50 PM
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    Welcome from :canada:
  19. Sep 17, 2017 at 6:05 PM
    Wireman
    Wireman New Member
    Hello from Kentucky! Nice truck
  20. Sep 17, 2017 at 8:06 PM
    RiverTundra
    A
    Thanks for the welcome. I was looking at an 18x9 American Racing R901. I think it had a +30 offset (could be wrong). I think the stock tire is a 8" so I thought the 9 wouldn't be awful. I want to at least get a year out of the stock tires. The other thought was selling the stock rims and tires, but I don't think I could get much for them.
  21. Sep 24, 2017 at 10:23 AM
    4x4_Angel
    Bree
    Funky Town, Texas
    2014 SR5 CM Silver Sky
    Welcome from Texas!
    Looks like questions 1 & 2 were answered for ya! You can get the rail system from @Roman also i believe or follow the thread with the uni-struts.
    Nice looking truck!
  22. Sep 24, 2017 at 6:21 PM
    RiverTundra
    A
    I will need to look into the plastic dip. Not familiar with that.
    Sunnier[QUOTED] likes this.
  23. Sep 25, 2017 at 4:50 AM
    k9shag
    k9shag New Member
    Tony
    Midland, NC
    2017 Tundra DC SR5 MGM
    Welcome from NC
  24. Sep 25, 2017 at 8:44 AM
    Viper3G
    Viper3G Why isn't work more like this?
    Rick
    2016 Crew Max 1794 4WD Super White
    Phillips X-treme Ultinon LED H4 bulbs, 3M Color Stable 35 tint on front doors, 3M Crystalline 40 on sunroof, OEM bed liner, OEM running boards, Morimoto fog LEDs, Fold-A-Cover G4 Elite, Husky X-Act Contour floor mats
  25. Sep 25, 2017 at 10:59 AM
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    Welcome from riverside. Ill have some trd(not pro) rims and tires for sale soon that im taking off incase ur intrested
  26. Sep 26, 2017 at 7:27 AM
    RiverTundra
    A
    Hey neighbor. Do you have pics of the rims?
  27. Sep 26, 2017 at 7:43 AM
    fisherman951
    Tony
    2017 crewmax 4x4
    This is what im taking off
  28. Oct 1, 2017 at 12:13 PM
    RiverTundra
    A
    Can you private message me how much you are looking for?
  29. Oct 1, 2017 at 12:17 PM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    Welcome to the family from Las Vegas....
  30. Oct 1, 2017 at 12:25 PM
    RiverTundra
    A
    Completed my first Mods yesterday (okay not really mods..lol). Picked up this toolbox at Harbor freight with Pittsburgh tools. I didn't figure they were the highest quality, but HB offers a lifetime warranty. Fits in the compartment under the rear seat perfectly and for $38 you can't beat it. Wait until next week and use a 20% off coupon. I didn't really need a hammer or wall anchors in my truck, but hey you never know when you will be a friend's house who doesn't have any tools and need to hang a painting or something.
    In regards to actual mods I ordered a pro grill and super white hood bulge. Picked out the wheels I want and plan on ordering them Monday. Went with the AR901 18x9 with 20 offset (black of course). The struggle is whether to keep the stock tires that came with the truck or pick up the Nittos I am eyeing. Hard to stomach tossing (selling for nothing) tires with 250 miles on them. I'm really torn on what to do.
