First time Tundra owner. Which lift to get?
Discussion in 'Suspension' started by Riseabove23, Jan 15, 2018.
  1. Jan 15, 2018 at 5:03 PM
    Riseabove23
    Riseabove23 [OP] New Member
    2018 TRD Sport
    Thanks in advance for the recommendations. Just purchased a 2018 Tundra TRD Sport. I'm thinking I want to run either 37's or 38's with a 22" rim. What are some recommendations for lift size and set-up?
    Prior to this I had an F-250 with 8" lift and 38's. I have no idea how to set up the Tundra but I want to do it right.
    Troynjade and Black Wolf like this.
  2. Jan 15, 2018 at 5:07 PM
    Welcome from CO. 37s or 38s??? You will hear from someone shortly no doubt...
    rons23 and Riseabove23[OP] like this.
  3. Jan 15, 2018 at 5:10 PM
  4. Jan 15, 2018 at 5:23 PM
    Tundra9831
    Tundra9831 New Member
    just so you know at that lift height the Toyota Safety Sense stuff may not work correctly....I'm not sure we've seen a 2018 that high yet
    Riseabove23[OP] and zcarpenter92 like this.
  5. Jan 15, 2018 at 5:30 PM
    blue16
    blue16 New Member
    steve
    Mesa AZ
    2016 tundra
    Welcome from AZ
    Riseabove23[OP] likes this.
  6. Jan 15, 2018 at 5:50 PM
    Welcome from Texas
  7. Jan 15, 2018 at 5:56 PM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    Why 22s? Just asking for rough ride and more expensive tires. I wish I had 18s but chose truck for BFGs
  8. Jan 15, 2018 at 5:57 PM
    Grumpy Uncle
    Pat
    CO
    Welcome from CO.
  9. Jan 15, 2018 at 6:00 PM
    Welcome from Ohio!
  10. Jan 15, 2018 at 6:07 PM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Welcome from Colorado
  11. Jan 15, 2018 at 6:57 PM
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    Welcome
    GNTundra and Riseabove23[OP] like this.
  12. Jan 15, 2018 at 7:11 PM
    Darth Tundra
    Curt
    17 CM TRD Black
    Welcome....from Orygun
  13. Jan 15, 2018 at 7:12 PM
    Darth Tundra
    Curt
    17 CM TRD Black
  14. Jan 15, 2018 at 7:13 PM
    Casper3
    Casper3 New Member
    Jay
    CT/OH
    2017 Super White 5.7 SR5 TRD off road
    Welcome from Ohio
  15. Jan 15, 2018 at 7:14 PM
    Shawn P
    Shawn P New Member
    Shawn
    2018 Tundra SR5 Crewmax
    I also have a 2018 Tundra and I stopped into the dealer today to ask a few questions. When I asked about a 3-1 lift (leveling) kit and how it would affect the warranty, they told me it would void the warranty. They also said if I had this kit installed it would produce a lot of faults, which would affect the way the truck drives. It sounds a little far fetched and I need to reach out to Toyota tomorrow, just to clarify.
    So has anyone lifted a 2018 Tundra yet?
  16. Jan 15, 2018 at 7:18 PM
    boostedtrdpro
    boostedtrdpro voided warranty
    Jeremy
    2024 GMC Sierra 2500HD AT4X 2020 Sequoia TRD Pro 040
    :deadhorse: Welcome from CO!
  17. Jan 15, 2018 at 7:21 PM
    hartebreak
    hartebreak New Member
    2017 Tundra Doublecab
    Welcome aboard!!
  18. Jan 15, 2018 at 7:27 PM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Welcome from So Cal
  19. Jan 15, 2018 at 7:42 PM
    Riseabove23
    2018 TRD Sport
    Well I'm hoping it can be done without too many problems.
  20. Jan 15, 2018 at 7:50 PM
    Riseabove23
    2018 TRD Sport
    I've seen some new lifted Tundras on my dealerships lot. I need to give them a call and ask who they use and how it relates to the warranty. When we bought my wife's Wrangler last year, we used the same company who does the dealerships lift kits, off road packages, etc. We went with them because the dealership honors the factory warranty if purchased through them. I know most Jeep dealerships would still do the warranty work but we didn't want to take any chances of getting shafted.
  21. Jan 15, 2018 at 7:55 PM
    Riseabove23
    2018 TRD Sport
    Preference I guess. I definetly don't want 18" rims. I've ran 20's with 38's before and the ride wasn't that bad to me. So now I'm thinking a bigger rim. I like the way 22's look. I'm still doing initial research, no decision yet.
  22. Jan 24, 2018 at 10:42 PM
    Tundra1794E
    Tundra1794E New Member
    Victoria B.C Canada
    2014 tundra 1794
    I as well like the look of the 22's did you decide what lift to get and what one will work for the 37's?
  23. Jan 27, 2018 at 9:38 PM
    Troynjade
    Troynjade Beast mode 5.7
    Troy
    Wa
    2008 Toyota Tundra
    7" procomp lift, 3" body lift. Amp research powerstep, 22" fuel rims, 38" nitto tires, Custom leather seat covers black with red stiching, alpine inz928 deck, 2x10" subs, 1500 watt alpine amp, 400watt amp for door speakers. Procomp Traction bars, fuel grille, Black headlight housing with 6000k hid, rear airbags, rear and front camera, k&n air intake, 40" light bar. Rear under bumper led light bar. Prodigy trailer brakes. 5.29 Nitro Gears. Auburn Posi Rear End. Dirty Deeds Budget Dump.
    I have 38s on a 22" rim I liked my 37s better a little smoother and I have stock 4.30 gears so once I change my gears the 38s will react to the throttle better. My lift was done years ago with 7" pro comp lift with a 3" body lift. It actually drives very smooth with that combo, there are alot better choices now out there for a lift then when I put mine together.
  24. Jan 27, 2018 at 10:33 PM
    UTAHRTK
    UTAHRTK New Member
    SOCAL
    2017 MGM Tundra TRD CM
    Dirty Deeds 8" standard exhaust, King 2.5's/Bilstein 5160's, Built Right UCA,s, Method 701's, TOYO ATIII 35x12.5x17, TRD LED headlights, Pro Grill
    Recommend contact Ekstrom - you can search this site and find info.
  25. Jan 28, 2018 at 6:58 AM
    Steve6
    Steve6 New Member
    Tucson
    Welcome from Arizona. It seems that some of the '18 Tundras have problems with the Toyota Safety Sense (TSS) system and the Pre Collision System (PCS) throwing codes; the problems have been reported here on lifted as well as stock trucks. Based on what several members have mentioned on this forum, it appears that the PCS error code is related to the Airbag ECS in that the problem was fixed after the dealer replaced the Airbag ECS.
    Toytec lifts has also posted that Toyota has advised them that it is OK to lift the new Tundras but that the truck needs to maintain some forward rake (.75 - 1 inch) in order for the TSS to work properly.
    There are several other threads about the issue on the forum and there are a number of other members on here who are more knowledgeable about the issue.
  26. Jan 31, 2018 at 2:16 PM
    Riseabove23
    2018 TRD Sport
    Looks like I'm going with BDS 7", Pro Comp Pro Runner flares, 22x12 Fuel Couplers and 37" Toyo Open Country
    Set up for next week, just hope its the right decision.
  27. Jan 31, 2018 at 4:59 PM
    Troynjade
    Troy
    Wa
    2008 Toyota Tundra
    Put a body 3" lift with the 7" pro comp, thats what I have have, originally I had 37's but, you can fit 38× 13.5. The only drawback is the power loss between the 37 to 38's. Other than that is looks awesome...
  28. Feb 21, 2018 at 8:59 AM
    hollandhunter
    hollandhunter New Member
    2017 SR5 CM 4x4
    Well how did it turn out? Did you get it done?
