First time towing
Discussion in 'Towing & Hauling' started by itundra22, May 28, 2024.
  1. May 28, 2024 at 1:46 PM
    itundra22
    itundra22 [OP] New Member
    2024 MGM Limited Hybrid 4x4
    I'm getting ready to tow a small 5x8 uhaul trailer. This is my first time towing and I will be traveling 200 miles with it. Any first time towing pro tips I should know?
  2. May 28, 2024 at 1:49 PM
    mass-hole
    mass-hole New Member
    No. That trailer wont even bother the truck in the slightest.
    itundra22[OP] and Cpl_Punishment like this.
  3. May 28, 2024 at 1:59 PM
    pwpblue
    pwpblue My ignor list just keeps growing!
    Greensburg,PA
    2023 Toyota Tundra Platinum ADV
    Make sure trailer tire pressure is max. Read the side wall and set them to max psi period and hopefully the axles are in good shape and lubed.
    Two most common issue these listed above.
    itundra22[OP] likes this.
  4. May 28, 2024 at 1:59 PM
    Don't turn sharp. The trailer will cut corners, so pull straight out at intersections and make your turns 90º turns. Especially watch right turns.
    If it's your first time towing a trailer, try to avoid backing if possible. Short trailers are extra squirrely so if you can avoid the hassle I would recommend it.
  5. May 28, 2024 at 3:07 PM
    SD Surfer
    Bruce
    So Cal
    Think ahead, swing wide, remember it's there when making lane changes.
  6. May 28, 2024 at 3:18 PM
    BoulderGT3
    BoulderGT3 New Member
    Glen
    2023 1794 4X4 BP/Saddle ADV Steps
    It’s a 4 wire flat. Know how to turn off the back up sensors. Lower left switch bank.
  7. May 28, 2024 at 3:20 PM
    Hella Krusty
    Hella Krusty New Member
    Just remember you are 10-11 feet longer than normal. Other than that just drive and it will follow you there. If you are putting some weight in it, check the tire pressures. In saying that I never touch any of my trailer or tow vehicle tires in 40 years of driving
  8. May 28, 2024 at 3:21 PM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    Double check the trailer connections. Made the mistake of not checking the trailer tongue once....trailer came off the ball when I hit a dip, maybe 10 miles down the road from uhaul. Safety chains saved me but it was a scare. Truck wont have any issue towing it. Disregard the 55mph notice in your mirror :)
  9. May 28, 2024 at 3:28 PM
    BoulderGT3
    Glen
    20”ish to the top of the ball.
  10. May 28, 2024 at 3:45 PM
    JDR76
    JDR76 New Member
    WA
    2021 1794 TRD OFF ROAD
    The most helpful hint I received when first starting to tow was about backing up. Grab the bottom of the steering wheel. Move the bottom of the steering wheel in the direction that you want the rear of the trailer to go.
    Going forward is easy, just leave yourself extra room.
  11. May 28, 2024 at 4:20 PM
    BoulderGT3
    Glen
    Last thing from me on it. The UHaul's are sturdy and reliable but air ride suspension they are not. Stiff springs and heavy ply tires can turn your stuff into dust if you don't pack well. Take a lille extra time to be certain your stuff will not jiggle to pieces.
  12. May 28, 2024 at 6:44 PM
    ScenicRoute
    ScenicRoute New Member
    2021 Tundra CM Nightshade
    Eibach stage 2 (JUNK), SmartCap, Airbags, CoachBuilder Stuff, Bora spacers, 35” falken AT3W tires.
    Even a small trailer like that can be a handful if improperly loaded! No tongue weight and hang on!
    itundra22[OP] and GODZILLA like this.
  13. May 28, 2024 at 7:47 PM
    This is true.
    @itundra22 be sure you keep plenty of tongue weight to keep the trailer stable.
  14. May 28, 2024 at 7:56 PM
    MT-Tundra
    MT-Tundra Agnostic Gnostic
    Montana
    2002 AC 4wd V8 Limited
    Whew there's a lot, but...the advice I'll reiterate:
    Avoid backing this first time. Park in a way that allows to you pull forward, rather than putting yourself in a position where you need to back up. Longer trailers are actually easier to back than shorter trailers. Every little twitch of the steering wheel will send a short trailer way left or right.
    Turn wide. Exaggerate your turns. Pull several feet farther forward into the intersection then cut the wheel.
    Don't turn the steering wheel full lock either way. You can jacknife and slightly damage the trailer, your bumper, the coupler.
    Load the weight evenly, but if anything have slightly more weight forward. If the back is weighted too much there will be no weight on the tongue and trailer will be super squirrely, even possibly wobble out of control. Ideally you want the trailer tongue pointing just slightly downward, rather than completely level, and certainly not pointing at all up. That tells you the weight is forward, resting on the hitch, providing more stability. Maybe a 10% downward angle from completely flat.
    Drive slow over bumps.
  15. May 29, 2024 at 12:32 PM
    itundra22
    Thank you for all of the input on this fellas.
    pwpblue likes this.
  16. May 29, 2024 at 1:16 PM
    While the turbos are fun, U-Haul trailer tires are generally rated for 55mph. When you look in the rear view mirror, you’ll see the signage on the trailer fenders staring at you. Slow down and take it easy.
    Cpl_Punishment and itundra22[OP] like this.
  17. May 29, 2024 at 1:25 PM
    They placard it that way for liability reasons. The tires are actually pretty good on a uhaul, and they make money having trailers in service. It would make zero sense to run cheap low rating tires that put trailers out of commission or damaged them during high speed failures.
  18. May 29, 2024 at 1:35 PM
    Last one I rented had Regan administration era tires on it.
    Cpl_Punishment likes this.
  19. May 29, 2024 at 1:43 PM
    Oof. Guess I was lucky, or you were unlucky?
    I just ran one to CA and back to WY and the tires were in great shape.
  20. May 29, 2024 at 2:33 PM
    SD Surfer
    Bruce
    So Cal
    That's exactly what my wife said the other day when I was workin' out some sweet new dance moves.
  21. May 29, 2024 at 2:39 PM
    BoulderGT3
    Glen
    I've had pretty good luck too. I think they updated a lot of their fleet towards the end of the pandemic.
  22. May 29, 2024 at 2:59 PM
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
    One that I don’t think has been mentioned. If your trailer does pop off the ball and the trailer is being pulled by the safety chains; don’t freak out and slam on the brakes. Just take your foot off the gas and slowly come to a stop (ie always keep tension on the chains). Happened to me the second time I was towing at like age 17. Left a solid mark in my parents bumper. Learned my lesson
    itundra22[OP] and FrenchToasty like this.
  23. Jun 1, 2024 at 2:39 PM
    itundra22
    Thanks for all input again fellas, I had a successful trip hauling the trailer no issues at!! Managed to get 14.2mpg also so I am satisfied with the performance.
    KNABORES and GODZILLA like this.
  24. Jun 1, 2024 at 5:05 PM
    Glad to hear the trip was a success. :thumbsup:
    itundra22[QUOTED][OP] likes this.
