First time towing boat
Discussion in '3rd Gen Tundras (2022+)' started by scruff1221, Jun 29, 2023.
  1. Jun 29, 2023 at 6:49 PM
    scruff1221
    scruff1221 [OP] New Member
    Ryan
    2022 Tundra Trd Off-road
    Will be towing boat 16ft express for the holidays
    anything I need to turn on or off?
    I know with all the backup sensors could cause a few issues
  2. Jun 29, 2023 at 6:59 PM
    Jim the Jarhead
    Jim the Jarhead New Member
    2017 SR5 4X4
    Overdrive.... I tow a 18' . 4500lbs total w trailer, fuel bla bla bla. Turn on tow/haul button for sure. Ur gtg!
  3. Jun 29, 2023 at 7:43 PM
    22whatwedo
    22whatwedo New Member
    The Open Road
    22 SR5 TRD OR Army Green
    Save your trailer in the settings, then go have fun. The manual explains it better than me, but it will be a joy towing it I predict
  4. Jun 29, 2023 at 7:48 PM
    Pmac
    Pmac New Member
    South of Portland, OR
    2019 CrewMax TRD Off-road
    Some trailers have surge breaks, a 16’ boat may not. But if it does, backing up, if it presses the brake cylinder, can cause the brakes to set on. Say backing up a slight incline. Those type of brakes usually have a manual switch on the trailer tongue you can turn to disable it. Just a Tiger trap I fell into early on.
  5. Jun 30, 2023 at 3:25 AM
    DMackler
    DMackler New Member
    Dustin
    Burleson, Texas
    2023 Celestial Tundra CM TRD OR
    As others said, set the trailer up in your gauge cluster and use tow/haul mode. For the small of a boat you shouldn't need the tow+ setting. Make sure you hit the button on the left side of the dash that turns off the rear auto braking. Even with the truck knowing it's connected to a trailer, they will occasionally auto brake when backing. RCTA automatically gets disabled when a trailer is connected.
  6. Jun 30, 2023 at 4:47 AM
    Gaston
    Gaston New Member
    Gary
    SE MI
    2021 White Tundra SR5 CM TRD Sport
    The surge brakes are disabled when the reverse lights are on. There is a manual override to the surge brakes when being towed around a service yard or something and the wiring isn't connected, on mine it's a small flat piece of metal that goes into a slot to prevent the tongue from compressing and applying brake pressure.
    Hella Krusty likes this.
  7. Jun 30, 2023 at 6:30 AM
    TundraLtdCO
    TundraLtdCO New Member
    Daniel
    2022 Tundra Limited TRD
    First time towing our 27’ travel trailer was a breeze. The torque is fantastic and I don’t think I went over 2500 rpm’s once (going up Hwy 24 (towards Woodland Park, CO)…
  8. Jun 30, 2023 at 6:47 AM
    2mchfun
    Most importantly, don't forget it's back there! One simple mistake can be really bad, and I have seen many plain ugly incidents that could have been totally prevented.
  9. Jun 30, 2023 at 5:21 PM
    6thyota
    6thyota New Member
    23 TSS Tundra
    Be sure to plug the lights in and put it in tow mode. Mine backed up fine but locks up if you open the door to look behind you or if you drop the tailgate to see the boat if you launch on a steep ramp.
  10. Jun 30, 2023 at 5:48 PM
    Hella Krusty
    Hella Krusty New Member
    Thats what your mirrors are for :)
    Mattedfred likes this.
  11. Jun 30, 2023 at 6:32 PM
    Paul Moll
    Paul Moll New Member
    Paul
    Idaho
    2023 1794 TRD off-road
    Make sure the rear plug is in the boat before launching :facepalm:
    Durtywrench likes this.
  12. Jun 30, 2023 at 6:39 PM
    Read the manual's towing section. It has all that info in it.
  13. Jun 30, 2023 at 6:55 PM
    catalac
    catalac New Member
    16ft? I think you’ll be ok, lol.
  14. Jun 30, 2023 at 7:28 PM
    6thyota
    6thyota New Member
    23 TSS Tundra
    Maybe they’ll make a mirror that can see over the steep ramp on the 24 models ??
