First time changing oil...Overfilled...then check engine light appeared
Discussion in '2nd Gen Tundras (2007-2013)' started by Newb2, Nov 11, 2024.
  1. Nov 11, 2024 at 11:41 PM
    Newb2
    Newb2 [OP] New Member
    2007 4wd 4.7 liter Texas Edition
    Branded title
    Hello All,
    First time here. I think maybe I messed my first truck up bad. Changed my oil for the first time and overfilled it. Drove 30 miles then truck started getting sluggish. Drained the oil via oil plug to appropriate level after figuring out what I did. Next day started truck up and white smoke came out but not too much. Same for the day after that. Day 3 and truck had a hard time starting. Had to jump start it ( new battery and its good ). Check engine light came on. Codes P0340 and P0345. Camshaft Position Sensor A bank 1 and 2. Just learned what a camshaft sensor is. Not sure why this would trigger that?
    Should I change the camshaft sensor and see if that helps or maybe some engine cleaner? Maybe some new spark plugs?
  2. Nov 12, 2024 at 1:02 AM
    Leo's first
    Leo's first TRUCK GANG
    Groton ma
    How much did you overfill the oil?
    Did you clear the codes?
  3. Nov 12, 2024 at 4:15 AM
    red61cj5
    red61cj5 New Member
    wv
    2017 Limited DC Inferno
    you're 100% sure you drained oil plug and not transmission? They are sort of close together.
  4. Nov 12, 2024 at 4:24 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Welcome from LA (Lower Alabama)! You came to the right place for learning.
    Newb2[OP] likes this.
  5. Nov 12, 2024 at 7:05 AM
    AZBoatHauler
    So.Arizona
    This. How much oil did you put in?
  6. Dec 14, 2024 at 6:27 PM
    Newb2
    Branded title
    Yes, I am positive I found the right one because when I bled it, it was black and smelled and felt like oil. Also I checked the manual and youtube.
  7. Dec 14, 2024 at 6:29 PM
    Newb2
    Branded title
    The code disappeared on it's own. I overfilled it by 5 qts.
    Leo's first[QUOTED] likes this.
  8. Dec 14, 2024 at 6:35 PM
    ToyotaDude
    ToyotaDude Member
    2003 Tundra AC V8 4x4
    Considered pulling a plug to see if fouled?
  9. Dec 14, 2024 at 6:38 PM
    Newb2
    Branded title
    Just bought a few tools so now I 'm going to do just that. Thank you for the encouragement in the right direction.
  10. Dec 15, 2024 at 12:06 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Not being a dick but I'm genuinely curious as to the process of how you overfilled by that much.
    TacomaTRD4x402 likes this.
  11. Dec 15, 2024 at 3:33 AM
    TacomaTRD4x402
    TacomaTRD4x402 New Member
    Southern California
    '18 Tundra TRD Sport 2WD 5.7 Crew Cab MGM
    How do you know for sure that you drained it to the appropriate level?
    I would have just drained it completely, plug it up, then just refill it to the correct amount.
    Edit: Just realized this is a month old post. Everything turn out okay OP?
  12. Dec 15, 2024 at 5:33 AM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    Yeah that would take 2 and a half jugs.
    Do Not keep so much oil on hand and this cannot happen again - well at least not 5 over just 2ish....
    AZBoatHauler likes this.
