First stab at cargo holder
Discussion in '2.5 Gen Tundras (2014-2021)' started by jsundin, Oct 2, 2014.
  1. Oct 2, 2014 at 5:56 PM
    jsundin
    jsundin [OP] New Member
    Jeff
    2014 Bronze Tundra Limited
    None
    Took a 2/4 that was accidentally cut in two 48" parts for another project and turned it into this. I will either grab another and raise its Height or do it again with a 2/6. It will keep tools, and small things from rolling away.
  2. Oct 4, 2014 at 6:16 PM
    g-ma g-pa
    g-ma g-pa New Member
    2014 Tundra SR5 5.7
    Nice I used a 2x12 added about a 1/4" on ends
  3. Oct 7, 2014 at 8:17 PM
    jsundin
    Jeff
    None
    Can you post pix of your 2/12 setup!
  4. Oct 15, 2014 at 6:44 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
  5. Oct 16, 2014 at 6:37 PM
    SuperWhite14
    SuperWhite14 New Member
    Travis
    Kansas
    2014 White Tundra
    ColoradoTJ and Patriot like this.
  6. Oct 23, 2014 at 6:51 AM
    Patriot
    Patriot Member
    Western NC, “Boondocks”
    perfect. I will be picking one up. Thanks!
  7. Mar 27, 2016 at 6:51 PM
    Ryan Mc.
    Ryan Mc. New Member
    Ryan
    Mission Viejo
    2015 Toyota Tundra SR5 Double Cab 5.7L
    Hand made bed divider, bed d-rings
    I made my own out of a 2x8. Made a fixture to drill holes across the top with two adjustable side pieces.
  8. Mar 27, 2016 at 9:01 PM
    csuviper
    Broomfield, CO
    I like the adjustability side to side. I'm guessing the 2x4 is slid into the slot in the bed.
  9. Mar 28, 2016 at 3:52 PM
    AMRE2ME2
    AMRE2ME2 New Member
    2016 DC 4x4 Limited TRD
    I have a factory bed divider that came with my 07. If anyone is interested, let me know.
  10. Mar 28, 2016 at 6:07 PM
    Some good ideas in this thread. Winning
    NewImprovedRon likes this.
  11. Apr 14, 2016 at 9:09 AM
    ChucklesToy
    ChucklesToy Retired
    Chuck
    Georgetown , TX
    2024 Honda Ridgeline Black Edition
    Sent you a PM...I might be interested if you still have it
  12. Nov 22, 2016 at 1:52 PM
    jwm9289
    jwm9289 New Member
    How much? is that OEM Toyota?
  13. Nov 22, 2016 at 4:44 PM
    jwm9289
    jwm9289 New Member
    I had the same one on my Tacoma, I will be getting this for the Tundra.
    Thanks,
  14. Mar 24, 2019 at 11:52 PM
    dargdb2012
    dargdb2012 New Member
    2019 Midnight Black Tundra SR5 XP
    Another item on my to do list.
  15. Apr 3, 2019 at 11:54 AM
    CaptSpaulding
    CaptSpaulding ...ain't nothin but nothin
    Jake
    2010 White DC 4x4
    Adding my budget cargo organizer, thank you for the inspiration @jsundin and @Ryan Mc.
    Somewhat rushed the build to make a 4 day Mohave Trail trip. The setup survived heavy offroading and will be detailed with more d-rings, metal Simpson ties for durability, and coated with bedliner.
    Designed to carry two 5 gallon gas cans, 7 gallon water container, floor jack, and provide added support for the dual tire carriers. I added a peice of superstrut between the tires and used that to mount the cargo system to the bed.
  16. Apr 3, 2019 at 12:00 PM
    apwisher
    apwisher New Member
    Everett, WA
    2007 CM SR5/TRD 4x4 White
    canopy, TRD Sway, audio
    I had one of those receiver-based shelf/storage things that I modified (made flat on bottom) that fits perfectly back there. It makes a nice low basket in the back.
    CaptSpaulding likes this.
  17. Apr 3, 2019 at 12:11 PM
    Berdine
    Berdine Voodoo Sport
    Binghamton, NY
    2020 VooDoo Blue Trd Sport
  18. Apr 3, 2019 at 12:23 PM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
  19. Apr 3, 2019 at 1:11 PM
    CaptSpaulding
    Jake
    2010 White DC 4x4
    Looks great!
  20. Apr 3, 2019 at 2:49 PM
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    Thanks! Pretty cheap to do, PT lumber, metal bracket, and black opaque deck stain to weatherproof. The factory grooves make it easy, just slide it out when you want the whole bed.
  21. Apr 3, 2019 at 6:21 PM
    CaptSpaulding
    Jake
    2010 White DC 4x4
    Oh, I forgot to note that the 7 gallon aquatainer busted apart within minutes. D-rings are the way to go.
    I also didn't secure a hefty Eucalyptus log well enough and after about 2 hours of trail running...I ended up with a big dent from the pounding. Will be adding a firewood container of some sort as well.
    V2 in the works
    Mountun Goat likes this.
  22. Aug 3, 2019 at 9:09 PM
    Harlan_2nd Gen
    Harlan_2nd Gen New Member
    2007 XSP Double Cab
    Bed cover LED Low Beam, High Beam
    Still have it?
  23. Aug 4, 2019 at 5:28 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
  24. Aug 4, 2019 at 6:20 AM
    dalejunior
    dalejunior New Member
    2018 BBP TRD Limited Crewmax
    Do you know if this works under the factory tonneau cover?
  25. Aug 4, 2019 at 1:11 PM
    biebs96
    PA
    Here’s mine... 2x4 hinged in the middle with a locking pin on the backside. Two plastic ammo boxes screwed on. One for tie downs, one for bungees and rope.
    Yes I totally over complicated something very simple for no reason... but kind of for a reason.
    1- the length of the board that fits width-wise in the truck, is slightly too long for the bed to shut the tailgate (without storing the board on an angle)
    2- folds up for storage if I need to utilize more bed space.
    3- all of the over complication led to many beers to be enjoyed.
    Mountun Goat, Fiesta346 and _khaki_ like this.
