First Oil Change
Discussion in '3rd Gen Tundras (2022+)' started by riotkayak284, May 18, 2023.
  1. May 18, 2023 at 7:05 AM
    riotkayak284
    riotkayak284 [OP] New Member
    Will be doing my first oil change this weekend. About 2200 miles on it.... Will be using Costco oil and Toyota filter..... Just old school and don't want the original oil in for 10K.
    Aerindel, Piki and Mattedfred like this.
  2. May 18, 2023 at 12:46 PM
    tinman831
    tinman831 New Member
    DFW
    2023 Windchill Pearl 1794
    Don’t forget tubing for the oil filter drip tray.
  3. May 18, 2023 at 12:48 PM
    gearnuts
    gearnuts New Member
    Joel
    Greer, SC, United States
    what is this for?
  4. May 18, 2023 at 12:56 PM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    you stick it on the end of the drip tray/funnel and divert the oil away from the crossmember and directly into a container.
  5. May 18, 2023 at 1:07 PM
    ToyoMon
    ToyoMon New Member
    2022 White Tundra SR5
    There's a spout right under the oil filter. Put this tube on the spout before pulling off the filter. It will help cleanly drain the oil and divert it into your oil pan.
    https://www.amazon.com/dp/B01MXFB3PZ
    Start at the 5:15 mark. Lower the air dam and remove the skid "carpet" to make it a lot easier to access.
    https://youtu.be/nuxXy9Y4IZ4
    gearnuts[QUOTED] likes this.
  6. May 18, 2023 at 2:10 PM
    gearnuts
    gearnuts New Member
    Joel
    Nice, thanks for that tip! I guess you just rest the filter on the catch and it drains out there or is it just for the drip when you unscrew? Haven't done mine yet but this will come in handy! Guess the TRD skid has to come completely off too, no access to the filter otherwise. I bought the Toyota oil filter, dang that thing looks tiny!
    raylo and ToyoMon like this.
  7. May 18, 2023 at 4:30 PM
    Rcflyersd
    Rcflyersd Wingnut
    Mark
    Dakota
    01 Tundra SR5, 02 Sequoia SR5, 23 Tundra Limited double cab
    At least they went back to a spin on oil filter rather than the cartridge filter on the previous 3UR 5.7 and 1UR 4.6
  8. May 18, 2023 at 5:53 PM
    tinman831
    DFW
    When you unscrew the oil filter, a decent bit of oil will spill out. It's not just a couple of drops.
  9. May 18, 2023 at 5:58 PM
    Aerindel
    Aerindel New Member
    Montana
    I gotta say.....this forum has the craziest combination of posts for one forum ;)
    Its great, just funny, on one end we are trying to hold together our 23 year old trucks with duct tape and spit....and on the other people are getting their first oil changes.
  10. May 18, 2023 at 5:59 PM
    gearnuts
    gearnuts New Member
    Joel
    Yes especially at that angle! I was just curious if y’all are draining the filter there or quickly bringing it out and vertical. I will figure it out on my first change I suppose, nice they added the catch drain though.
  11. May 19, 2023 at 9:26 AM
    Tom976
    Tom976 New Member
    Tom
    Yes the skid plate has to come off. TRD has the metal one, otherwise its a fabric one. Once I saw the fabric one I went out and bought an aftermarket one that has a trap door to get to the filter without taking everything off. Works well.
    If you do your own oil changes, a fomuto valve will help too. That replaces the drain plug on the oil pan. Get oil nice and warm the easily drain it. Less mess.
    Mattedfred likes this.
  12. May 20, 2023 at 4:46 AM
    riotkayak284
    Hey Tom what skid plate did you get?
  13. May 20, 2023 at 5:41 AM
    raylo
    raylo not so new member
    Frederick, MD
    Yeah, these things are crazy small. My Triumph motorcycle has bigger, and the filters for our 20 HP riding mowers look almost identical to the Tundra's. Have to be careful not to mix them up. The ones that say Toyota are for the Tundra so if I have had my coffee I'll get it right. ;-)
  14. May 20, 2023 at 8:49 AM
    Tom976
    Tom976 New Member
    Tom
