First Oil Change Timing
Discussion in 'General Tundra Discussion' started by dlos, Apr 24, 2019.
  1. Apr 24, 2019 at 7:49 AM
    dlos
    dlos [OP] Truckin'
    2019 Cement Off-Road
    Mods Mods Mods....
    I am probably overthinking this one, new '19 Tundra, 4300 miles at present, have a trip coming up from central NC out to the Smokies next Tues-Sunday. If I don't get a change in before the trip I will definitely go over 5k miles, maybe up to 6k by the time I'm back home.
    Get it done before trip with less than 5k miles?
    OR
    Wait until I get back with whatever is on the odometer? How will Toyota view this option?
    TIA
  2. Apr 24, 2019 at 7:51 AM
    TundraTSS19
    TundraTSS19 New Member
    San Antonio, TX
    2020 Tundra TSS SR5 Crewmax 5.7L
    LED step bar light strips
    Do it now. Won't hurt it one bit .Especially since you know you're going on a trip. I change mine every 5k regardless of the 10k extended drain interval. I'm OK spending a little extra having cleaner oil more often.
    dlos[OP] likes this.
  3. Apr 24, 2019 at 7:51 AM
    teedubbya
    teedubbya I like fat booty
    Austin TX
    2019 trd pro voodoo 4runner
    Before
  4. Apr 24, 2019 at 7:58 AM
    KnuckleHD
    KnuckleHD New Member
    2018 Tundra CM Limited- Cement
    I’d do it before the trip but if you don’t have the time, then do it when you get back. You’re not going to hurt anything. Not sure what you mean by how Toyota will view the option? They won’t change your oil until 10k, unless you want to pay for it out of pocket. As for your scheduled maintenance, they don’t care about 1k. I’ve come in at 1k above/below, it’s all the same.
  5. Apr 24, 2019 at 8:02 AM
    ncorry
    ncorry New Member
    Nic
    Little Rock, AR
    2019 CM SR5 TSS
    I'm pretty much in the same boat as OP (2019 CM, 4,.500 miles). My 5.7 is the non-FFV engine, and I just pulled the manual and it says first oil change is at 10K miles.
  6. Apr 24, 2019 at 8:12 AM
    dlos
    dlos [OP] Truckin'
    Mods Mods Mods....
    I just called the nearest Toyota Dealer service department - Advisor I spoke to said oil doesn't get changed at 5k, wait until 10k, but you can bring it in and we'll top off fluids, rotate tires and do multipoint inspection - wtf?
    Sticker inside truck says 5k.....confused by dealer response, would like it changed since it's the first 5k on a new motor. Guess I'll try another one or go elsewhere.
  7. Apr 24, 2019 at 8:28 AM
    Nike21
    Nike21 New Member
    2018 SR5 CrewMax TSS 4X4 Black Beast
    FFV is 5k. I'd change it before I left.
  8. Apr 24, 2019 at 8:35 AM
    dlos
    dlos [OP] Truckin'
    Mods Mods Mods....
    Got an appointment with the other dealership in my area, should have just called them first but the other one is close to my office, oh well. No problems with the place I got an appointment, have a sticker that says 5,000 miles first change and that matches what it says in my Toyota Owners account as well.
