First Oil Change Questions
Discussion in 'General Tundra Discussion' started by Tchase, Jul 17, 2021.
  1. Jul 17, 2021 at 8:25 AM
    Tchase
    Tchase [OP] MostlyLurk
    Buckley WA
    2019 White Tundra Limited
    In work
    Mods please move this if it's in the wrong forum topic
    I've done hundreds but this is the first on the Tundra and my Toyota care is up.
    I'd would love to have the Jowett set up, but near as I can tell he's not been fabricating lately. So I figured I'd buy just what I need to get by and not buy the OEM metal oil filter cap, I'll just wait for the Jowett.
    I am just a little confused on the Fumoto valve. It looks like the Jowett comes with one (or the option to have one). Also it looks like guys are installing the valve on the drain pan.
    So my question(s) are:
    1. Does it make sense to have a 2 valves, one on the filter and one on the pan?
    2. If I'm putting one on the pan should it be the shorter nipple? I can see wanting the longer one at the oil filter, but I'm not keen on seeing a longer nipple sticking out of the pan.
    3. Any known issues with any of the filter elements? I was considering going with an after market and not the OEM (just because of lead times)
    4. Lastly if you have the valve on the filter (either the Jowett or the OEM metal) you would not need the oil filter drain hose? hose https://www.amazon.com/gp/product/B005R3SSUY?smid=ATVPDKIKX0DER
    Is that a correct assumption?
    Sorry if this has been asked, I haven't been able to find the answers.
  2. Jul 17, 2021 at 8:40 AM
    I have the Fumoto valve with the longer nipple, works like a charm.
    I wanted the Jowett filter housing with the valve but he gave me the run around for about 1 year. Don't waste the money or time trying to get it. Get the metal Toyota one and the hose kit you listed above, it will work great.
  3. Jul 17, 2021 at 9:14 AM
    Tchase
    Buckley WA
    In work
    Thanks, so you have the valve on your pan with long nipple?
    And no valve on the filter just using the drain hose?
    I could put the valve on the metal filter but it’s not really needed (over kill)?
  4. Jul 17, 2021 at 9:31 AM
    Yes & Yes
    When you switch from the plastic housing to the metal housing (both Toyota) you have to put the center strainer from the plastic one into the metal housing.
    Tchase[QUOTED][OP] likes this.
  5. Jul 17, 2021 at 10:09 AM
    Tchase
    Buckley WA
    In work
    Thank you!
  6. Jul 17, 2021 at 4:38 PM
    :hattip:
  7. Jul 17, 2021 at 5:29 PM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
