First oil change gen3
Discussion in '3rd Gen Tundras (2022+)' started by Tundra4ME!, Mar 9, 2025.
  1. Mar 9, 2025 at 6:45 PM
    Tundra4ME!
    Tundra4ME! [OP] New Member
    Isaac
    2025 white TRD off road crewmax
    None
    I just purchased this gen 3 and have got different thoughts on first oil change because of the turbos, any ideas ? Should I do 1000k first change?
  2. Mar 9, 2025 at 6:46 PM
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5 3UR-FE
    ATF Cooler
    Yes.
    Raven67 and oddhours like this.
  3. Mar 9, 2025 at 6:47 PM
    lapoolboy
    lapoolboy New Member
    I did one at 500 miles. Will do second one at 1500 and then every 5000 thereafter.
    Tundra4ME![OP] and oddhours like this.
  4. Mar 9, 2025 at 6:58 PM
    Tundra4ME!
    Isaac
    None
    Ok, thank you guys- just want to get the first one right because I can’t go back in time and slip an oil change in
  5. Mar 9, 2025 at 7:53 PM
    1794LE
    1794LE New Member
    Shane
    2024 Blueprint
    I did 500, 2k, 5k, and every 5k thereafter. Most think it’s overkill but I thinks it cheap insurance and prevention. I may never know if it matters but when adding it in to the overall cost, it’s minor in the big picture
    eddiefromcali likes this.
  6. Mar 9, 2025 at 7:54 PM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    That's my plan too. 800, 2k, 5k and every 5k after.
  7. Mar 10, 2025 at 6:43 AM
    303Gen3
    303Gen3 Old enough to know better. Young enough to try
    Golden Colorado
    '23 MGM SR5 CrewMax 4x4
    Nitrogen filled tires!
    I'm pretty sure you meant 1K and not 1000K! If you wait until 1000K I'm pretty sure you won't need another oil change!
    I did one at 1500 miles, one at 5k and every 5k after.
  8. Mar 10, 2025 at 8:16 AM
    389 24/7 125k on the gen3
    Oregona
    2022 TRD OR
    Nada
    I did all the early & preventative oil changes
    on every brand new toyota (& 1 corvette) I purchased over the past 20 years
    (2006 xb, 2008 xb, 2009 xrunner, 2011 xb, 2012 frs, 2012 tacoma, 2018 rav4, 2021 taco)
    When I got the 2022 tundra I was very busy framing a home, so I opted to follow the manual & go with every 10k OCI to save my precious time in 2022
    & I never did the 500, 1000, & 1500 mile early oil changes
    I currently have 125k on my gen3
    Have done 12 total oil changes in 3 years
    Did a blackstone analysis at 120k
    Looking good with 10k OCI & no early oil changes
    I prefer being in the driver seat rather than under the tundra
    To each their own, but I'm happy with the 10k OCI...I remember a dude on tacoma world with gen2 taco with 360k miles & 10 total oil changes....his OCI was 36k, that's wild!
    Tundrastruck91 likes this.
  9. Mar 10, 2025 at 8:22 AM
    Stillen-Will
    Stillen-Will New Member
    Will
    I'd agree. changing oil is cheap compared to having to replace a motor.
  10. Mar 10, 2025 at 9:01 AM
    JH8473
    JH8473 New Member
    2025 Tundra SR5
    None
    I'll do my first oil change when Toyota replaces the engine around 10,000 miles.
  11. Mar 10, 2025 at 9:10 AM
    PWRGENgasturbine
    PWRGENgasturbine New Member
    Thomas
    2025 Tundra limited wind chill pearl
    I did mine at 2,500 all highway driving. I used the wrong size piece of hose on the oil filter drain and it got inside the front crossmember which is taking forever to drip out even trying to flush it out with Brake cleaner. I used 3/4 heater hoes without measuring it whereas it takes 5/8 hose on the filter drain. I also found the front air valance was in the way to remove the oil filter so after doing the work I found out in the manual that you have to shut the engine off and pull the wiper selector to mist so the valance deploys so you can reach the bolts on the bottom engine cover. I'm pretty sure my lack of being prepared was the cause for the wrong hose size and not reading the Dead Sea scrolls aka the manual to find information to make it more simple.
  12. Mar 10, 2025 at 6:16 PM
    jaxadam
    jaxadam New Member
    I’m with you. I’ve always just done what Toyota recommends and if it’s 10k it’s 10k. Never had a single issue on three different Tundras.
    Linesman likes this.
