First Gen Wheel Spacers
Discussion in '1st Gen Tundras (2000-2006)' started by MrAristo, Aug 6, 2020.
  1. Aug 6, 2020 at 6:11 PM
    MrAristo
    MrAristo [OP] Hounty Bunter
    South FL
    ‘01 4X4 Limited TRD
    How goes it friends..
    I’m looking at getting either Bora or Spidertrax wheel spacers, thinking 1.5-2.5inches. I have ZERO issues with spacers, my Lexus already has smaller 25mm H&Ms all the way around, going on 8k miles. Being this is an older truck w 240k miles, and known to have LBJ issues, should I be weary of that much spacing and potential failure? Or any other excess suspension wear? I do plan on getting all new OEM LBJs with the level kit, so do you recommend just waiting as opposed to doing this on all-stock suspension?
    Lastly what do you guys prefer of those two brands? I'd also like to see some shots if you've got spacers on (preferably stock suspension). THANKS. :D
  2. Aug 6, 2020 at 6:33 PM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    Wheel spacers, just like low offset wheels, will cause more strain on your ball joints, bearings, etc.
    Now that doesn’t mean it’s dangerous. Lots of people run spacers and offset wheels, me included. Just be careful.
  3. Aug 7, 2020 at 4:27 AM
    revtune
    revtune New Member
    Dane
    Houston Texas
    2006 Tundra 4.7 AC 2wd
    2006 Tundra: Stock air intake 3 inch catback Magnaflow 13742 2.5 inch front lift 1.5 inch rear blocks 2014 sr5 4Runner wheels (17x7) 1.5 inch hub centric wheel spacers p285/70/17 Nitto Terra Grappler G2 Weathertech floor liners
    I run 1.5 inch spacers on my 2006 tundra and they’ve been working good. It pushes the tires right to the edge of the TRD flares.
    MrAristo[QUOTED][OP] likes this.
  4. Aug 7, 2020 at 4:35 AM
    revtune
    revtune New Member
    Dane
    Houston Texas
    Bora and spidertrax are great brands. Here is another one I would suggest looking at.
  5. Aug 7, 2020 at 7:10 AM
    Professional Hand Model
    Hand Protectors
    Try doing push ups 3 different ways.
    1) With hands straight under your shoulders (stock).
    2) With hands under your nipples. No example for this.
    3) With hands spaced wider than shoulders.
    Report back on which one is the easiest and which one tears your shoulders. With that being said, I like the look of 1.25” spacers and believe thats the minimum spacer for or first gen. Not arguing here but let your shoulders tell you the truth about spacers (which look cool) and how they effect your lower ball joints.
    MrAristo[OP] likes this.
  6. Aug 7, 2020 at 8:38 AM
    I've got 130k miles on my 16X8 American Eagle 589 wheels with 4.5" backspacing (came off a Chevy) and 1.25" wheel spacers. Have run 265/75/16 tires. 5100 level setup. No issues to report. Looks good to me. I've got the huge TRD flares so this brings the tires out of hiding and to the edge of the flares. Done lots of heavy towing and some mild off roading with no trouble.
  7. Aug 7, 2020 at 9:07 AM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    my American Racing 16x8s with roughly 4.5in of backspacing sites just inside the flares. This is how it should've come factory. :facepalm:
    MrAristo[OP] and revtune like this.
  8. Aug 7, 2020 at 10:48 AM
    revtune
    revtune New Member
    Dane
    Houston Texas
    Don’t forget to order some these too.
  9. Aug 7, 2020 at 2:48 PM
    MrAristo
    South FL
    ‘01 4X4 Limited TRD
    I went ahead and ordered 1.5” Spidertrax, coming in on Monday. Looking forward to how it’ll look. Main reason again, I have 17” FJ wheels, not much backspace, and thinking ahead for when I get my 3” level soon.
    Let me see
    Tried it and nowboth of my rotator cuffs have torn! But good news is I got the example :cool:
    For some reason I like the silver nuts, matches my silver diff nut lol
  10. Aug 7, 2020 at 3:08 PM
    Dog
    Dog sit!
    Rocky Mountain high...
    2006 SR5 AC 4x4 TRD-OR
    3 push ups in a row? What kind of freakish highly-trained olympian are you? :benchpress: :rofl:
  11. Aug 7, 2020 at 3:27 PM
    Hand Protectors
    I didn’t even want to get into 1 finger push ups. :rofl:
  12. Aug 7, 2020 at 4:11 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Why would you need ET lugs if your using the same rim. Your not changing the thickness of the mounting surface on the rim.
    TundratrdF and MrAristo[OP] like this.
  13. Aug 7, 2020 at 5:12 PM
    revtune
    revtune New Member
    Dane
    Houston Texas
    You need these when connecting the spacer to the hub, especially for the front, because the oem studs are pretty short. These offer more thread engagement.
  14. Aug 7, 2020 at 5:28 PM
    FrenchToasty
    Mo
    Bone stock
    Ok, that makes more sense now
  15. Aug 7, 2020 at 5:31 PM
    Hand Protectors
    I think the lack of using these specific nuts is where people go wrong from the readings about spacers on our 1st Gens Tundras.
  16. Aug 7, 2020 at 5:54 PM
    MrAristo
    South FL
    ‘01 4X4 Limited TRD
    Appreciate the input on that. These coming in on Sunday.
  17. Aug 7, 2020 at 6:37 PM
    The tire shop that originally mounted my spacers referred to them as "deep shank conical seat" lug nuts. Then use the lugs that are recommended for your wheel to bolt it up to the spacer. Use a torque wrench for both.
  18. Aug 10, 2020 at 5:32 PM
    MrAristo
    South FL
    ‘01 4X4 Limited TRD
    Here’s how she looks. Considering removing flares, would def enhance spacing more :rolleyes: also thanks to @revtune for some useful tips!
    BEFORE
    710BC5D2-2C72-47CC-8F72-67D2F3795CC6.jpg 8A1249BC-5045-4881-B45D-741E890B7695.jpg
    AFTER
  19. Aug 10, 2020 at 6:04 PM
    revtune
    revtune New Member
    Dane
    Houston Texas
    It looks good!
    I was under the assumption you got the “hub centric” spacers.
  20. Aug 10, 2020 at 7:17 PM
    Mine are not Hub centric either. I'm 14 years in with no issues to speak of. Some Wheels are "lug centric" anyway.
  21. Aug 10, 2020 at 7:20 PM
    MrAristo
    South FL
    ‘01 4X4 Limited TRD
    @revtune I actually just checked, the stock # for these spacers is WHS005, and Spidertrax claims these are “hub centric” on their site. They do fit around the hub tbh, but don’t have that lip... mind fucked.
  22. Aug 10, 2020 at 7:23 PM
    So, My spacers are hub centric themselves to the vehicle. They do not have the raised hub lip for the wheel to center on. But my wheels came off of a Chevy truck, not sure the center bore would match anyway. I've never tried them without the spacers.
  23. Aug 11, 2020 at 4:52 AM
    Hand Protectors
    I’m having a Flat Earth Moment. Is the earth flat?:frusty:
  24. Aug 11, 2020 at 4:53 AM
    Hand Protectors
    Post up a pic of yours for comparison.
  25. Aug 11, 2020 at 6:32 AM
    revtune
    revtune New Member
    Dane
    Houston Texas
  26. Aug 11, 2020 at 6:37 AM
    Two different hub spacer types. With the "lip" on the wheel mounting surface that allows for "hub centering" of the wheel. If the wheels are designed to be hub centered, this keeps the shimmys away. The second type has no lip. The spacer itself is hub centric if the center bore matches the hub of the vehicle, but with no lip, you can't "hub center" the wheel to the spacer with these. Also if you are running a different wheel bore, these allow for that. If the wheels are designed to be lug centric, then the lugs are what centers the wheel.
  27. Aug 11, 2020 at 8:34 AM
    MrAristo
    South FL
    ‘01 4X4 Limited TRD
    @KNABORES super useful stuff man
    Spoke with the shop, they’d take back long as I get something else. Looking to get custom 2” HUB CENTRIC spacers... what you think fellas?
    Dannydirtyfingers and Dog like this.
  28. Aug 11, 2020 at 8:44 AM
    Hand Protectors
    I think it looks good as it is. I like your look, but am spacer hubaphobic. :rofl:
    Anymore might look like a Chevy wannabe, but it doesn’t matter what anyone thinks but you.
    BTW, how is it driving/handling?
    MrAristo[QUOTED][OP] and Dog like this.
  29. Aug 11, 2020 at 9:04 AM
    I think the wheel well spacing looks great on yours. A wider wheel or tire would put you closer to or outside the the fender lip. Any more spacer and you will be hanging out.
  30. Aug 11, 2020 at 6:22 PM
    Dog
    Dog sit!
    This.
