first gen tundra A/C
Discussion in '2nd Gen Tundras (2007-2013)' started by Ihatecarissues, Aug 11, 2025 at 6:54 PM.
  1. Aug 11, 2025 at 6:54 PM
    Ihatecarissues
    Ihatecarissues [OP] New Member
    2001 tundra limited access cab 4WD V8
    my truck doesnt blow cold and AC button flashes i know im not getting any voltage to my compressor... but when i jump it with 12V it enages... i checked my freon levels and there sitting around 120 obviously without the AC running but i tried jumping my high low sensor but still nothing and i tried bypassing the heater relay and nothing. I know my ambient air sensors are well grounded. One thing I did notice was a gray wire going close to that connection for the compressor i think its a bypass but it gets low voltage...
  2. Aug 13, 2025 at 10:20 PM
    Dalandshark
    Dalandshark Infected with 5G
    Northwest
    2007 Tundra SR5 5.7 Longbed
    Eibach Level Lift, DIY SAIS preventer, headers.
    Try replacing the ac relay with OEM only. I think some first gen’s use the heater relay but others have a separate one.
  3. Aug 14, 2025 at 3:37 AM
    tmac58star
    tmac58star New Member
    Black 1st generation Tundra SR5 Access Cab
    Have you tried the 1st Gen forum?
    grave likes this.
  4. Aug 14, 2025 at 6:30 AM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    Make sure also the ground wire on the compressor is not loose
