First Gen frame interchange
Discussion in '1st Gen Tundras (2000-2006)' started by t.mcginley.jr, Oct 16, 2021.
  1. Oct 16, 2021 at 1:16 PM
    t.mcginley.jr
    t.mcginley.jr [OP] New Member
    Hi all,
    Just purchased an 01 Tundra 4.7L/auto 4wd with 170k on the clock. Got it for a good price knowing full well it needed a frame. I looked into the recall but it looks like one of the PO's took it in years ago and they did that BS coating that obviously didn't work.
    Anyway, I did some research on here and see that although the 2000-06 Tundras are the same generation, the 00-02, 03-04, and 05-06 had different body style changes. Does anyone know if the frames changed from year to year?
    I found a super clean frame at the junkyard from an 2005 v6 2wd version. Comparing it to mine, all the body mounts, suspension mounts, etc. seem to be identical. The only exception is the crossmember where the trans mounts up 2wd vs 4wd, but that part can be swapped out since it just bolts up. I need to actually take measurements of mine and compare it to the junkyard one, but was hoping someone on here had any experience swapping frames between years.
    Thanks!
  2. Oct 16, 2021 at 4:14 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
  3. Oct 16, 2021 at 5:08 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Technically it should bolt up if they’re from the same cab configuration. As you said the crossmember will need to be moved though
  4. Oct 16, 2021 at 5:53 PM
    t.mcginley.jr
    That's what I was hoping to hear. I still took measurements and will be checking them against the junkyard frame tomorrow. I'm confident it will work but want to make sure
  5. Oct 16, 2021 at 9:14 PM
    Dave8699
    Dave8699 Trackrat
    David
    NJ
    04 Tundra AC, 2014 Tundra 1794 Crew Max
    Whole truck Raptor liner in olive green, leer camper cap, 5100 with OME, Wheelers AAL and Firestone Air bags.
    I'm assuming that's a big project to change out a frame.
  6. Oct 17, 2021 at 2:51 AM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Frame replacement procedure from Toyota attached if it is any help to you.
  7. Oct 17, 2021 at 3:53 AM
    t.mcginley.jr
    Thank you sir! That will definitely help.
  8. Oct 17, 2021 at 7:42 AM
    NetGnome
    NetGnome New Member
    NJ
    2003 RC V8 4wd, 2007 Sequoia V8 4wd
    Removed lots of rust.
    Some of the parts kits in the Toyota frame replacement instructions are no longer available.
  9. Oct 17, 2021 at 4:21 PM
    t.mcginley.jr
    As far as I can tell the frames are identical minus the transmission subframe. All my measurements lined up. I'm heading back to the junkyard tomorrow to finish pulling the frame.
    Today after I measured everything and it checked out I started getting it ready. Pulled the motor and trans out, steering rack is out, bed and fuel tank are off, rear axle/leafs are out. Just need to get the cab off!
    bmf4069 likes this.
  10. Oct 18, 2021 at 3:45 PM
    t.mcginley.jr
    Got the 2005 Tundra frame home and in the garage today. It will probably be a few weeks or more but I'll update this thread when it's hopefully all back together.
  11. Oct 18, 2021 at 4:04 PM
    Forgive me if I missed where you said you already planned to do so, but while you got that joker exposed like it is, you may want to shoot the hell out of it with a basic rust protection coating, like the CRC one, although I'm sure @FirstGenVol will probably have other suggestions.
  12. Oct 18, 2021 at 4:42 PM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    Do you have pics of the other truck and the frame?
  13. Oct 18, 2021 at 5:37 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Where are you located? Are those doors from that Access Cab any good? May have to make a pilgrimage...
  14. Oct 18, 2021 at 5:47 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    If that was me, I'd pay to have the frame go through a galvanized dip to be worry free in the future. Regardless, still looking forward to seeing the build.
    Subscribed. :popcorn:
    Tundra2 and 2mchfun like this.
  15. Oct 18, 2021 at 5:49 PM
    RR60
    RR60 New Member
    2003 SR5 Tundra long bed
    That frame does look really good.
    Tundra2 likes this.
  16. Oct 18, 2021 at 6:01 PM
    2mchfun
    Sandblast and spray with cold galvanizing compound, then marine epoxy coat.
  17. Oct 19, 2021 at 7:34 AM
    t.mcginley.jr
    This is what I'm working with on my truck, the body is super clean it's just the frame that is trash. One of the steering rack mounts actually broke away from the crossmember.
    Darkness likes this.
  18. Oct 19, 2021 at 7:37 AM
    t.mcginley.jr
    I'm in Wilmington, NC. The donor truck is at Cape Fear Pick N Pull here in town. The drivers side front door is pretty messed up but the rest were decent.
  19. Oct 19, 2021 at 7:38 AM
    2mchfun
    Damn lucky you didn't wreck due to steering issues.
    t.mcginley.jr[OP] likes this.
  20. Oct 19, 2021 at 7:39 AM
    t.mcginley.jr
    I hadn't mentioned it yet, but yes I fully intent to clean and coat the frame while I have it bare like this. After taxes I paid $350 for the frame, which was a steal.
  21. Oct 19, 2021 at 7:41 AM
    t.mcginley.jr
    Tell me about it, I didn't actually see that part of it before I drove it home. No wonder the steering felt sloppy and the alignment is way off.
    bmf4069 and 2mchfun[QUOTED] like this.
  22. Oct 19, 2021 at 8:04 AM
    rock climber
    That's amazing and kind of gross how clean the body is and how bad the fame is
  23. Nov 4, 2021 at 4:02 PM
    t.mcginley.jr
    Update, I finally managed to get the body off the frame. It took a few days of work but I managed to do it while leaving the engine and trans in the body still :thumbsup: I might have to make a separate thread about how I did it. Definitely seems like less work this way.
  24. Nov 4, 2021 at 6:00 PM
    Desert Dog
    Desert Dog Nobody rides for free
    2001 SR5 AC 2WD 4.7l
    Bilstein 5100's, SPC UCA's, ATS HD leaves
    You're making it look easy, gotta hear this.
  25. Nov 4, 2021 at 9:15 PM
    empty_lord
    05 rollover special
    yea thats how we do them at work.. engine support for the engine and a chain fits some holes in the body that supports the rear of the trans. works great. dont have to touch coolant, a/c, etc
    Darkness and shifty` like this.
  26. Nov 5, 2021 at 2:10 AM
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5 3UR-FE
    ATF Cooler
  27. Nov 5, 2021 at 4:20 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    We need more pics. We like pics.
  28. Nov 5, 2021 at 8:43 AM
    Talk about a damn money shot. Holy crap! Quality content.
    Definitely take more pics. And, honestly, I've got serious shop envy. I'd kill to have a shop space big enough for a 2-post. :(
    The one friend I had nearby with a lift he'd use to work on his p-cars moved to Daytona a few years back. Been back-on-the-floor ever since.
    Which reminds me. I need to buy a better quality creeper.
    the red and Darkness like this.
  29. Nov 5, 2021 at 9:26 AM
    daveeasa
    David
    Some dudes impress! Nice truck too!
  30. Nov 5, 2021 at 5:38 PM
    empty_lord
    05 rollover special
    i do suggest a ratchet strap in the back of the cab.. it stops the cab from wanting to teeter totter if you bump into it.... it can end bad if it falls
    the red likes this.
