First Gen AC Rear Seat Delete
Discussion in '1st Gen Tundras (2000-2006)' started by Voss, Dec 26, 2020.
  1. Dec 26, 2020 at 4:47 PM
    Voss
    Voss [OP] Dust in the wind
    Valod
    2003 AC TRD 4x4
    Sup fellas. So thinking my next project will be a rear seat delete. Amazing how much space opens up without the seats no one can actually sit on.
    Removed the seats and came across these 2 plastic boxes on the rear wall behind the seats. I would like to remove them so I can make shelves/storage compartments there. Anyone know what they are and what they do? Hate to remove only to find out they serve a purpose. There isn’t any wiring to them and they’re empty inside.
    MNtundra likes this.
  2. Dec 26, 2020 at 4:54 PM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Those I believe are the cab vents. There to help with ventilation and make it easier to shut the doors.
  3. Dec 26, 2020 at 4:56 PM
    Voss
    Valod
    2003 AC TRD 4x4
    That explains the thin flap that opens only outward.
    Thanks
  4. Dec 26, 2020 at 5:36 PM
    Professional Hand Model
    Hand Protectors
    They are the ‘Exhausters’. Lets the Air Mojo Flow properly. If you block them off, then your HVAC System will not operate as efficiently.
  5. Dec 26, 2020 at 6:26 PM
    jskeyes2
    jskeyes2 New Member
    Jeff
    Carlsbad, CA
    2005 Limited AC
    ADS Shocks 35” Yokahama M/T
    Following. I am going to do the same thing. Putting in shelves and plat form for overland fridge. Please share what you come up with.
    MNtundra and Voss[OP] like this.
  6. Dec 26, 2020 at 6:47 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    This short video explains exactly what was stated above. Voss, unfortunately you can't remove those vents. I'm excited to see your build though as I need to do the same for my dogs.
    https://youtu.be/Rl5y42t8O7w
    N84434 and Voss[OP] like this.
  7. Dec 28, 2020 at 12:10 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    You can leave the top covers off and build around them. You may have already noticed how loud your truck is without the back seat, you can use sponge and cut little ice cube sized pieces to stuff in the holes to muffle it. It will still be loud but less loud, and will still allow air flow.
  8. Dec 28, 2020 at 2:46 PM
    Voss
    Valod
    2003 AC TRD 4x4
    Good stuff thanks
    Tundra2 likes this.
  9. Dec 28, 2020 at 3:30 PM
    Stuck in the '00s
    Stuck in the '00s Experienced member
    Mikey
    SE Wisconsin
    2004 Phantom Gray DC 4X4 Limited Tundra
    Western plow, custom bed
    Depending on what/how you build and insulate, you could end up with a quieter cab...
  10. Dec 29, 2020 at 7:11 AM
    Voss
    Valod
    2003 AC TRD 4x4
    Actually hoping it will be quieter. Ordered some sound deadening mats. Should be enough for the back and a good portion of the floor.
  11. Dec 29, 2020 at 8:32 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Sound deadening is good but finding a way to muffle those boxes will be key.
    Tundra2 and Voss[QUOTED][OP] like this.
  12. Dec 29, 2020 at 8:33 AM
    Voss
    Valod
    2003 AC TRD 4x4
    Will be taking your advice with the sponge as well.
    Tundra2 likes this.
  13. Dec 29, 2020 at 9:04 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    My backseat is out, and perhaps it's because I added Noico, but I don't think the road noise is too bad. Definitely louder, but not to the point that it bothers me.
  14. Dec 29, 2020 at 9:48 AM
    Voss
    Valod
    2003 AC TRD 4x4
    Noico is what I ordered. What’s that one bolt in the middle of the back wall? Anyone know if I can remove it?
    Darkness likes this.
  15. Dec 29, 2020 at 10:32 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Thats just there to start conversations. You should be able to remove it, I think it might be for adding baby seats or something. I removed the hooks and things that you see along the top of Erik's wall, I was planning to use those to secure a board but eventually threw the seat back in there instead.
    Sunnier and Voss[QUOTED][OP] like this.
  16. Dec 29, 2020 at 11:11 AM
    Voss
    Valod
    2003 AC TRD 4x4
    Lol cool thanks
  17. Dec 31, 2020 at 2:51 PM
    Voss
    Valod
    2003 AC TRD 4x4
    Got the air flow box super covered. Also used the mat that was in there before as an extra layer.
    Since no back seats, took out the seatbelts... one less rattle on the trails.
  18. Jan 3, 2021 at 5:09 PM
    Voss
    Valod
    2003 AC TRD 4x4
    Progress report so far...
    Finished with the prep work/sound dampening. Pretty time consuming. I was expecting it to be a 2-3 beer job but turned out to be a 9ish beer job. I did double it up tho and did a good portion of the floor. It’s quieter now than it was before which is nice. Makes me want to do the whole cab eventually.
    Cut this little section off for a pretty even line for the wall shelving.
    Here’s what the frame of the shelf looks like. Leaving the bottom open for air flow and think I’ll put a couple small vents on the shelf as well.
    What it’ll look like eventually. I want to spray everything with Bed liner before putting it all together.
    Pic of the top section. Shelves will be bolted on the bottom to the seatbelt bolts and the top will hold the shelving against the wall. 2 pieces, just easier that way.
  19. Jan 3, 2021 at 5:14 PM
    jskeyes2
    jskeyes2 New Member
    Jeff
    Carlsbad, CA
    2005 Limited AC
    Looking good! I am not following how you connected / will connect to the back wall? I have gone as far as sound deadening the back wall
    Voss[OP] likes this.
  20. Jan 3, 2021 at 5:27 PM
    Voss
    Valod
    2003 AC TRD 4x4
    The front section/face of the shelving is a little longer than the framing section.
    The part that extends beyond the shelf framing will bolt on to the 4 nut sections the seatbelts would bolt to...
    The top will hold the selves against the wall once bolted on to the wall...
  21. Jan 3, 2021 at 5:33 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Nice work!
  22. Jan 3, 2021 at 5:33 PM
    Voss
    Valod
    2003 AC TRD 4x4
    Thanks
  23. Jan 3, 2021 at 5:59 PM
    jskeyes2
    jskeyes2 New Member
    Jeff
    Carlsbad, CA
    2005 Limited AC
    Gotcha, thanks. I digging into mine next week.
    Voss[QUOTED][OP] likes this.
  24. Jan 6, 2021 at 5:13 PM
    Voss
    Valod
    2003 AC TRD 4x4
    Back wall shelf complete. I like how it turned out. Now for the base.
  25. Jan 21, 2021 at 8:33 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Voss, did you just drill right into the cab to attach that? I know you used the existing seat belt holes at the bottom right? What did you do up top?
  26. Jan 21, 2021 at 8:56 AM
    Voss
    Valod
    2003 AC TRD 4x4
    Screwed into the existing holes on top section as well. Took out the hooks the seats would hang on and used those holes to screw the top into.
    FirstGenVol[QUOTED] and jskeyes2 like this.
  27. Jan 21, 2021 at 8:57 AM
    jskeyes2
    jskeyes2 New Member
    Jeff
    Carlsbad, CA
    2005 Limited AC
    What's your connection plan for the bottom shelf in front of the one on the wall?
  28. Jan 21, 2021 at 9:30 AM
    Voss
    Valod
    2003 AC TRD 4x4
    Haven’t completed the bottom section yet but there are existing holes where the current storage areas are I’m planning to use.
    So far I got 2 mounting locations and wondering if 2 would actually be enough. Will use a bolt and locknut.
    I’m worried about the attachment locations being too close to the latch openings. Work in progress, I’ll post more on base once complete/closer to completing.
    01erionracing likes this.
  29. Jan 21, 2021 at 9:34 AM
    jskeyes2
    jskeyes2 New Member
    Jeff
    Carlsbad, CA
    2005 Limited AC
    I was looking at those holes too, but seemed somewhat thin, but I think still workable. I had made a platform that utilizes with the seat pulled up (bottom) and I connected turnbuckles to the hooks on the back seat, as well as d rings I added to the front seat bottoms (seat bolts) that I used to connect.
  30. Jan 21, 2021 at 9:39 AM
    Voss
    Valod
    2003 AC TRD 4x4
    Post a few pics. Want to see what others have come up with.
