First Gen 2002 Tundra with 17 inch Wheels
Discussion in 'Wheels & Tires' started by SteveT, Sep 12, 2022.
  1. Sep 12, 2022 at 4:16 PM
    SteveT
    SteveT [OP] New Member
    LugNutz
    2002 Tundra SR5 Access Cab
    None yet. Just good ole maintenance
    Hey guys - I have a 2002 Toyota Tundra SR5 Access Cab with stock 16" wheels and stance. I'm very interested in going with the TRD 17" OEM wheels, PTR20-35110-GR'.
    My stock wheels are stamped as 7jx16 ET15 with 265/70-16 stock tires. I am looking to go with the 17" wheels and 265/65-17 tires which would result in virtually identical installed diameter and width.
    My concern comes to offset. Mine are 15mm and the new ones are 4mm, which means 11mm toward the negative side. Would you believe that this 11mm change would clear without any stance mods, spacers, etc. ? I might level at some point but just want to get the setup installed first.
    Greatly appreciate your thoughts... Steve
