first brake job upcoming..
Discussion in '2nd Gen Tundras (2007-2013)' started by kittscreeknc, Apr 22, 2020.
  1. Apr 22, 2020 at 4:24 PM
    kittscreeknc
    kittscreeknc [OP] New Member
    2012 Toyota Tundra
    Hey ya'll. I have a 2012 5.7 that making sounds like its time for brake job. Not looking to break the bank but need advice on general duty replacement pads and rotors. Truck occasionally pulls a trailer but mainly construction service work. Thanks in advance
    TT
  2. Apr 22, 2020 at 5:22 PM
    Rph74
    Rph74 New Member
    Springfield,MO
    2007 Tundra Crewmax Limited Silver/Redrock
    Having owned several Toyota’s, I’ve become a fan of just sticking to the OEM pads. They’re squeak and dust free and aren’t too expensive. $78 before tax and shipping at Toyota parts of Olathe.
    If you have to do aftermarket, I’ve had good results from Akebono pads on my European cars. They were dust free too.
    Tundyfundy likes this.
  3. Apr 22, 2020 at 5:23 PM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
  4. Apr 22, 2020 at 6:57 PM
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    I'm running Raybestos EHT3 pads and rotors all around. Bonus for coated rotors in the rust belt. Tad over $200 off Rock.
  5. Apr 22, 2020 at 9:18 PM
    Jwood562
    Jwood562 New Member
    2013 Tundra 4x4
    3" Suspension lift 18" method roost 35x12.5x18 ridge grapplers 2020 sequoia LED headlights
    I just did a full front brake job. Pads, rotors, new calipers and lines.
    having warped some aftermarket rotors in the past. Go with OEM rotors.
    As far as pads stick either oem or a decent aftermarket name like stop tech.
    Remember, once you are in there you might as well do it all at once.
    so before you start, crawl under there and get a visual of all your hoses and hard lines and order them ahead of time.
    I replaced my hard lines for $8 and add stainless hose lines for $40. Piece of mind and new products for $48
  6. Apr 23, 2020 at 5:18 AM
    Dr_Al
    Dr_Al New Member
    Al
    Where do you live? If you are up north and things are rusty then get loaded calipers. You'll have to bleed the system but it'll be much better than dealing with the pins that hold the pads in place. If you don't get calipers then at least buy new pins. I personally have never bought the drilled or slotted rotors. I have spent a little extra on the coated ones to protect against rust.
