First AR15, buy or build?
Discussion in 'Guns & Hunting' started by Mwray8909, Apr 3, 2019.
  1. Apr 3, 2019 at 9:29 AM
    Mwray8909
    Mwray8909 [OP] New Member
    Chino Valley
    18 TRD offroad cement CM
    Hey there folks,
    I'm about to get my first rifle but I'm also not in a hurry.
    First I'm in California for at least the next year. But will be moving to AZ or CO.
    Secondly (or thirdly) Do I build or buy? I'm more then capable and very patient.
    Thanks for you guys time!
    Badger Co-Op and BTBAKER like this.
  2. Apr 3, 2019 at 9:34 AM
    smslavin
    smslavin New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    sorry. this place sucks anyway. you don't want to move up here.
  3. Apr 3, 2019 at 9:40 AM
    conlons26
    conlons26 High speed dirt mobile
    Raleighwood, NC
    2018 Quiksand Limited CM
    King 2.5's, Toytec shackles, FN BFD 18", 295/70r18 NItto Ridge Grapplers, Dirty Deeds 8" SS, no more chrome, 17' pro grill, Husky mats, TRD Pro shifter + 15hp...
    AR15 and build it just the way you want... just like if you could mod your truck from the factory. You can certainly get a very good rifle for a great price from many shops but building it you will learn how it functions and how to work on it with a minimul investment in a couple specialized tools. Save the AR10 for your 2nd build...you wont stop at one. You will most likely use the .556 more than the .308 way cheaper to shoot.
  4. Apr 3, 2019 at 9:40 AM
    Mwray8909
    Chino Valley
    Wrong
    DCslick and smslavin[QUOTED] like this.
  5. Apr 3, 2019 at 9:42 AM
    smslavin
    smslavin New Member
    Hudson Valley
    Some stuff
    i tried :cool: :cheers:
  6. Apr 3, 2019 at 9:42 AM
    Mwray8909
    Chino Valley
    Don't worry I wont bring CA B.S with me. We go to CO yearly at least.
  7. Apr 3, 2019 at 9:44 AM
    Mwray8909
    Chino Valley
    I kinda figured as much with going .556 first. Would you suggest going 80% or just get a decent lower(I don't know what constitutes as a decent lower)
    Prostar 190 likes this.
  8. Apr 3, 2019 at 9:46 AM
    Backslider
    Backslider Thirsty...
    Tooele, UT
    Build it. It seems intimidating until you remember that you played with Legos as a kid and there are alot of great resources available online. It's an easy process, when you build your first rifle you can literally watch a YouTube video and just follow along step by step.
    Make sure you have the following tools:
    Torque wrench capable of up to 100ft/lbs
    A good set of gunsmithing punches, I recommend Wheelers
    Roll pin punches, I recommend Wheelers
    A vice
    A hammer with a nylon and hard plastic or brass side
    AR armorer's wrench
    AR specific upper and lower vice block
    I would also recommend your favorite gun oil, and something more tacky like your favorite gun grease (can be really helpful holding pins and springs in the right place)
    There are some specialty tools that you can get, but you'll get along fine with what is listed here.
    conlons26 likes this.
  9. Apr 3, 2019 at 9:49 AM
    Backslider
    Tooele, UT
    Get a milspec lower. Don't get an 80% lower (you need to drill holes and finish the lower).
    Anderson is good and cheap.
    AeroPrecision make a number of products that are slightly more expensive, but are of a very high quality and include some features to make your build easier. Do a bit of research here.
    FYI, AeroPrecision is a company that makes lowers for a bunch of other companies.
    FrogmanTundra, rons23 and conlons26 like this.
  10. Apr 3, 2019 at 9:53 AM
    Mwray8909
    Chino Valley
    Building seems daunting to me simply because I dont understand what parts I need, how to choose the right barrel, or gas block or tube, or really what any of it means. Even after watching videos it's a lot of info.
    but like I said I'm patient.
  11. Apr 3, 2019 at 9:53 AM
    conlons26
    Raleighwood, NC
    Ive built a number but never done an 80%...know some people that do but you can get a perfectly good mill spec lower for under $50 these days and not fuss with drilling any holes or milling anything...that is other than in the peoples republic of California...not sure what you have to do there. I've done a number with palmetto state armory lowers, they run specials all the time, and the fit and finish has always been good. You want something fancy check out aero precision, make some nice components, ive done a couple with their uppers and they are super nice and not outrageously priced.
  12. Apr 3, 2019 at 9:57 AM
    Backslider
    Tooele, UT
    You need to decide caliber and length.
    Length will determine the length of barrel, gas tube, and handguard. It will also determine the weight of your recoil buffer. Other than this you can almost get whatever you want.
    If you get a mil spec lower, all other parts should be mil spec as well.
    https://ar15buildersforum.com/
    Is a great resource for all of this information.
  13. Apr 3, 2019 at 9:58 AM
    smslavin
    smslavin New Member
    Hudson Valley
    Some stuff
    zcarpenter92 and Mwray8909[OP] like this.
  14. Apr 3, 2019 at 9:59 AM
    Mwray8909
    Chino Valley
    I plan to use mil spec. 16in barrel. .556
  15. Apr 3, 2019 at 9:59 AM
    Backslider
    Tooele, UT
    I used to build ALOT of ARs, but have slowed down a lot lately. My last build was a rifle length 5.56 with APs "Desert Mad Dragon" builder set.. I have a box full of parts that I could probably put together a couple full builds with the exception of a couple pins, springs, and maybe a trigger group.
    Mwray8909[OP] likes this.
  16. Apr 3, 2019 at 10:00 AM
    conlons26
    Raleighwood, NC
    when you start researching, watch a few videos and you will see what is needed...its seriously not hard... the hard part is picking out what parts you want, there are literaly 10's of thousands options...
    Mwray8909[QUOTED][OP] likes this.
  17. Apr 3, 2019 at 10:01 AM
    Backslider
    Tooele, UT
  18. Apr 3, 2019 at 10:01 AM
    KLLVMDCL
    KLLVMDCL New Member
    Brandon
    Austin, Texas
    2017 Super White DC SR5
    Build a 15. 10s aren’t as uniform as 15s(dpms, sr20, etc.) all uppers don’t fit with all lowers, hand guards, etc. 308 is a hell of a good time, but the experience from building a 556 will make you’re 308 down the road that much better.
  19. Apr 3, 2019 at 10:03 AM
    Max Power
    Max Power Groovy Member
    2018 SR5 TRD Off Road
    TRD Dual Exhaust TRD Rear Sway Bar
    I'd go with the AR-15. Building is fun, there's definitely a feeling of accomplishment, and you might be able to get everything put together for cheaper than if you bought one off the shelf. Price everything out. There are plenty of good vendors online who you can buy functional uppers and parts kits from. You should also keep in mind when building or buying as to how much shooting you're going to be doing. If it's your first rifle of this type, I'd go for something more modestly priced.
  20. Apr 3, 2019 at 10:07 AM
    Mwray8909
    Chino Valley
    Yeah, it is going to be my first AR. So I dont want to go nuts on price. I want to keep it close to the $800 mark
  21. Apr 3, 2019 at 10:41 AM
    conlons26
    Raleighwood, NC
    Don't forget to same $$ for a good optic...you can build a sweet rifle for $800 but to get even a descent red dot your probably about $160+
  22. Apr 3, 2019 at 10:50 AM
    Gotyour6
    Gotyour6 New Member
    Fairport, NY
    2019 Tundra Pro
    ar15.com is a great resource
    Max Power likes this.
  23. Apr 3, 2019 at 10:54 AM
    saybng
    saybng Just a member.
    Gary
    Ventura CA
    16 Tundra 1794 CM in BLACK!
    I would build it the way you like, also determine if you want piston or gas, I went piston with my 15 and gas with 10, you have lots of options, turners having spring specials at the moment for lowers..
  24. Apr 3, 2019 at 10:57 AM
    Aero Precision M4E1 upper and lower.
  25. Apr 3, 2019 at 11:24 AM
    Mwray8909
    Chino Valley
    I haven't even started looking into optics yet. I was considering just running flip ups at first.
    I will take a look at those!
    See I didnt even know piston was an option.
  26. Apr 3, 2019 at 11:44 AM
    Mwray8909
    Chino Valley
    As in I need to come collect from your parts bin right lol
  27. Apr 3, 2019 at 11:47 AM
    Backslider
    Tooele, UT
    You might also check out something like Palmetto State Armory. I don't know about now, but they used to sell builder kits. That might be a good choice for your first build.
    My first AR was purchased as a complete rifle, but I wanted to change a lot so I pretty quickly took it apart. This is a good option to consider too.
  28. Apr 3, 2019 at 12:52 PM
    equin
    equin Texarican Tundra
    Ed
    DFW, TX
    I’ll join the “build-it” consensus. I built my first one and found it very fun and therapeutic, but I did it the easy way by building a stripped lower and then mating it to a complete upper. It still helped me better understand how it works and how to take it apart and fix or replace parts if needed. Plus, it’s a satisfying feeling when you take that first shot at the range knowing you built it.
    Backslider likes this.
  29. Apr 3, 2019 at 1:01 PM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    Colorado is banning all AR15 rifles.
  30. Apr 3, 2019 at 1:05 PM
    mattyd170
    mattyd170 New Member
    Albuquerque, NM
    2020 Tundra Limited Crewmax with Leer shell. Calvary Blue
    TRD Front Suspension, Bilstein Rear, TRD rear sway bar kit, 35" tires, working on stereo.
    AR's are super cheap right now. Just buy one. You can get a Smith and Wesson M&P 15T for like 800 bux. I have seen others for as cheap as 579. I built a spikes lower up as a totally tricked out gun, doesn't shoot that much better than my stock 15T duty gun. Or what I would do is buy one, then buy a lower and start building one, then you have 2 and 2 is better than 1. :)
    porkitt and Rex Kramer like this.
